Topic "Ubuntu Server"
dbrown101
I am trying to use Winscp to config files on my Ubuntu server. after logging in I can view all files but when I try to edit a file I get access denied error.
Permission denied.
Error code: 3
Error message from server: Permission denied
Request code: 3
so i have to open putty and vim all my config changes.
I have looked in the forum and tried the ssh/shell sudo su-command and got another error.
Permission denied.
Error code: 3
Request code: 3
I know there has to be a way to do this with WinScp can someone please help me with this issue.
