server should provide error description
erwin123
I get this notification every time I try to upload files from my pc/laptop to my self built freenas system.
I tried to use the "search" option but I got more than 80 pages each time I searched and I cant file a solution on any of those pages (or I need some glasses)
What I already tried: 1. in the preferences menu I disabled : preserve timestamp
2. I downloaded older version, didnt work...
Wonder if anybody could help me.
Grtz Erwin
Re: server should provide error description
