Topic "with fhgfs_dev file system"
icegood
Not correctly work with subject. fhgfs_dev as i understand (coz it not my comp) means
http://fhgfs.com/cms/
So
1) During uploading say that
"uploading succeful but error while set permissions or timestamp". Only unsetting "preserve timestamp" help for this.
2) (More critical) Instead of file "dummy" to be uploaded only soft link created
../../../full_path/to/file/dummy.filepart and links to nowhere.
WinSCP 4.2.8 build 818 is used.
icegood
Additional info:
1) protocol - sftp (for scp everything works great!)
2) use gui of Commander style
3) server info : "uname -a":
Linux millipede 2.6.18-164.15.1.el5 #1 SMP Tue Mar 16 18:44:51 EDT 2010 x86_64 x86_64 x86_64 GNU/Linux
icegood
. 2010-09-22 18:23:20.312 Copying 1 files/directories to remote directory "/data/p253510/"
. 2010-09-22 18:23:20.312   PrTime: Yes; PrRO: No; Rght: rw-r--r--; PrR: No (No); FnCs: N; RIC: 01; Resume: S (102400); CalcS: Yes; Mask: *.*
. 2010-09-22 18:23:20.312   TM: M; ClAr: No; CPS: 0; ExclM(Yes):
. 2010-09-22 18:23:20.312   AscM: *.*html; *.htm; *.txt; *.php; *.php3; *.cgi; *.c; *.cpp; *.h; *.pas; *.bas; *.tex; *.pl; .htaccess; *.xtml; *.css; *.cfg; *.ini; *.sh; *.xml
. 2010-09-22 18:23:20.312 File: "D:\!test_tasks_on_cluster\results\md\mine\attractive\lennard_jones\blends_AX_YBCZ_with_hb\01\hb_test_1st_fitting_stage\1\res0020000_ex_all_bonds.pdb.gz"
. 2010-09-22 18:23:20.312 Copying "D:\!test_tasks_on_cluster\results\md\mine\attractive\lennard_jones\blends_AX_YBCZ_with_hb\01\hb_test_1st_fitting_stage\1\res0020000_ex_all_bonds.pdb.gz" to remote directory started.
. 2010-09-22 18:23:20.312 Binary transfer mode selected.
. 2010-09-22 18:23:20.312 Checking existence of file.
> 2010-09-22 18:23:20.312 Type: SSH_FXP_LSTAT, Size: 53, Number: 20487
< 2010-09-22 18:23:20.312 Type: SSH_FXP_STATUS, Size: 24, Number: 20228
. 2010-09-22 18:23:20.312 Discarding reserved response
< 2010-09-22 18:23:20.312 Type: SSH_FXP_STATUS, Size: 29, Number: 20487
< 2010-09-22 18:23:20.312 Status code: 2
. 2010-09-22 18:23:20.312 Checking existence of partially transfered file.
> 2010-09-22 18:23:20.312 Type: SSH_FXP_LSTAT, Size: 62, Number: 20743
< 2010-09-22 18:23:20.312 Type: SSH_FXP_STATUS, Size: 29, Number: 20743
. 2010-09-22 18:23:20.312 Opening remote file.
> 2010-09-22 18:23:20.312 Type: SSH_FXP_OPEN, Size: 78, Number: 20995
< 2010-09-22 18:23:20.312 Type: SSH_FXP_HANDLE, Size: 13, Number: 20995
> 2010-09-22 18:23:20.312 Type: SSH_FXP_WRITE, Size: 4121, Number: 21510
. 2010-09-22 18:23:20.343 44 skipped SSH_FXP_WRITE, SSH_FXP_READ, SSH_FXP_DATA and SSH_FXP_STATUS packets.
> 2010-09-22 18:23:20.343 Type: SSH_FXP_CLOSE, Size: 13, Number: 27652
< 2010-09-22 18:23:20.343 Type: SSH_FXP_STATUS, Size: 24, Number: 26886
< 2010-09-22 18:23:20.343 Status code: 0
< 2010-09-22 18:23:20.359 Type: SSH_FXP_STATUS, Size: 24, Number: 27142
< 2010-09-22 18:23:20.359 Type: SSH_FXP_STATUS, Size: 24, Number: 27398
< 2010-09-22 18:23:20.500 Type: SSH_FXP_STATUS, Size: 24, Number: 27652
< 2010-09-22 18:23:20.500 Status code: 0
> 2010-09-22 18:23:20.500 Type: SSH_FXP_RENAME, Size: 110, Number: 27922
< 2010-09-22 18:23:20.515 Type: SSH_FXP_STATUS, Size: 24, Number: 27922
< 2010-09-22 18:23:20.515 Status code: 0
> 2010-09-22 18:23:20.515 Type: SSH_FXP_SETSTAT, Size: 65, Number: 21257
< 2010-09-22 18:23:20.515 Type: SSH_FXP_STATUS, Size: 29, Number: 21257
< 2010-09-22 18:23:20.515 Status code: 2, Message: 21257, Server: No such file, Language:
* 2010-09-22 18:23:20.515 (ETerminal) No such file or directory.
* 2010-09-22 18:23:20.515 Error code: 2
* 2010-09-22 18:23:20.515 Error message from server: No such file
* 2010-09-22 18:23:20.515 Request code: 9
. 2010-09-22 18:23:20.515 Asking user:
. 2010-09-22 18:23:20.515 Upload of file 'res0020000_ex_all_bonds.pdb.gz' was successful, but error occurred while setting the permissions and/or timestamp. If the problem persists, turn on 'Ignore permission errors' option. ("No such file or directory.
. 2010-09-22 18:23:20.515 Error code: 2
. 2010-09-22 18:23:20.515 Error message from server: No such file
. 2010-09-22 18:23:20.515 Request code: 9")
* 2010-09-22 18:23:22.515 (EScpSkipFile) Upload of file 'res0020000_ex_all_bonds.pdb.gz' was successful, but error occurred while setting the permissions and/or timestamp. If the problem persists, turn on 'Ignore permission errors' option.
* 2010-09-22 18:23:22.515 No such file or directory.
* 2010-09-22 18:23:22.515 Error code: 2
* 2010-09-22 18:23:22.515 Error message from server: No such file
* 2010-09-22 18:23:22.515 Request code: 9
. 2010-09-22 18:23:22.515 Listing directory "/data/p253510".
> 2010-09-22 18:23:22.515 Type: SSH_FXP_OPENDIR, Size: 22, Number: 28171
< 2010-09-22 18:23:22.515 Type: SSH_FXP_HANDLE, Size: 13, Number: 28171
> 2010-09-22 18:23:22.515 Type: SSH_FXP_READDIR, Size: 13, Number: 28428
< 2010-09-22 18:23:22.515 Type: SSH_FXP_NAME, Size: 707, Number: 28428
> 2010-09-22 18:23:22.515 Type: SSH_FXP_READDIR, Size: 13, Number: 28684
. 2010-09-22 18:23:22.515 Reading symlink "res0020000_ex_all_bonds.pdb.gz".
> 2010-09-22 18:23:22.515 Type: SSH_FXP_READLINK, Size: 53, Number: 28947
> 2010-09-22 18:23:22.515 Type: SSH_FXP_STAT, Size: 53, Number: 29201
< 2010-09-22 18:23:22.515 Type: SSH_FXP_STATUS, Size: 28, Number: 28684
. 2010-09-22 18:23:22.515 Storing reserved response
< 2010-09-22 18:23:22.531 Type: SSH_FXP_NAME, Size: 121, Number: 28947
< 2010-09-22 18:23:22.718 Type: SSH_FXP_STATUS, Size: 29, Number: 29201
< 2010-09-22 18:23:22.718 Status code: 2, Message: 29201, Server: No such file, Language:
* 2010-09-22 18:23:22.718 (ECommand) Error reading symlink 'res0020000_ex_all_bonds.pdb.gz'.
* 2010-09-22 18:23:22.718 No such file or directory.
* 2010-09-22 18:23:22.718 Error code: 2
* 2010-09-22 18:23:22.718 Error message from server: No such file
* 2010-09-22 18:23:22.718 Request code: 17
< 2010-09-22 18:23:22.718 Status code: 1
> 2010-09-22 18:23:22.718 Type: SSH_FXP_CLOSE, Size: 13, Number: 29444
. 2010-09-22 18:29:30.531 Closing connection.
. 2010-09-22 18:29:30.531 Sending special code: 12
. 2010-09-22 18:29:30.531 Sent EOF message
icegood
Already checked on other ssh client, and it works. So, trouble inside WinSCP
icegood
New facts:
do not work in binary transfer mode only. Also do not work with files of size more than or equal to 102400 bytes.
Checked via
"fsutil file createnew test.txt 102400"
vs
"fsutil file createnew test.txt 102399"
on winxp sp3
So try to disable transfer resume support.
icegood
Yeah, now works. Now i understand at least why 102400 bytes Smile
