Topic "can not change directory"
cu
I'm a new user of winscp. I used sftp protocol to connect to our f secure ftp server. There are four directories there, when I tried to access a directory by doubleclicking its name, I got an error:
Error changind directory to 'xxx'
General failure.
Error code: 4
Error message from server: None (?)
Request code: 11
What is the cause of it?
Cu
I have no idea, the server does not report any cause, as you may see yourself. Are you able to enter at least some directory? Also post a WinSCP log file, if you can.
I found out our server is a fsecure windows nt server, would this affect anything?
The log I have is:
Changing directory to "PostProcessed".
. Getting real path for '/PostProcessed'
> Type: SSH_FXP_REALPATH, Size: 23, Number: 1808
< Type: SSH_FXP_NAME, Size: 151, Number: 1808
. Real path is '///hf1fs1/users1$/server12/support/test/postprocessed'
. Trying to open directory "///hf1fs1/users1$/server12/support/test/postprocessed".
> Type: SSH_FXP_OPENDIR, Size: 74, Number: 2059
< Type: SSH_FXP_STATUS, Size: 9, Number: 2059
< Status/error code: 4, Message: 2059, Server: None, Language: ?
* (ECommand) Error changing directory to 'PostProcessed'.
* General failure.
* Error code: 4
* Error message from server: None (?)
* Request code: 11
cu
I would like to see a full log file or at least I need to know in what directory you were before changing to 'PostProcessed'.
One of my colleague tried winscp with an older version, he said he didn't get this error. I've tried both english and international multilanguage installation with the same problem. After he upgraded to the 3.5 version, he got the same problem. Can we still download the previous version of Winscp somewhere?
cu
Below is the complete log:
. WinSCP Version 3.5.0 (Build 204)
. Login time: 2004~116 U 01:37:23
. Transfer Protocol: SFTP
. Ping type: -, Ping interval: 30 sec; Timeout: 15 sec
. SSH Bugs:
. Proxy: none
. Shell: default, EOL: 0
. Cache directory changes: Yes, Permanent: Yes
. Connecting to 219.73.89.81 port 22
. Server version: SSH-2.0-2.4.0 F-Secure SSH Windows NT Server
. We claim version: SSH-2.0-WinSCP-release-3.5
. Asking user:
. The server's host key is not cached in the registry. You have no guarantee that the server is the computer you think it is. The server's key fingerprint is: ssh-dss 1024 f0:e1:c0:36:c1:19:00:8b:ef:82:6c:76:67:ca:2c:eb
. If you trust this host, press Yes. To connect without adding host key to the cache, press No. To abandon the connection press Cancel.
. Continue connecting and add host key to the cache? ()
. Host key fingerprint is:
. ssh-dss 1024 f0:e1:c0:36:c1:19:00:8b:ef:82:6c:76:67:ca:2c:eb
. Initialised Blowfish client->server encryption
. Initialised Blowfish server->client encryption
! Using username "cui_ftp".
. Session password prompt ()
. Using stored password.
. Sent password
. Access granted
. Opened channel for session
. Started a shell/command
. Using SFTP protocol.
> Type: SSH_FXP_INIT, Size: 5, Number: -1
< Type: SSH_FXP_VERSION, Size: 5, Number: -1
. SFTP version 2 negotiated.
. Getting real path for '.'
> Type: SSH_FXP_REALPATH, Size: 10, Number: 16
< Type: SSH_FXP_NAME, Size: 23, Number: 16
. Real path is '/'
. Listing directory "/".
> Type: SSH_FXP_OPENDIR, Size: 10, Number: 267
< Type: SSH_FXP_HANDLE, Size: 17, Number: 267
> Type: SSH_FXP_READDIR, Size: 17, Number: 524
< Type: SSH_FXP_NAME, Size: 911, Number: 524
> Type: SSH_FXP_READDIR, Size: 17, Number: 780
< Type: SSH_FXP_STATUS, Size: 9, Number: 780
< Status/error code: 1
> Type: SSH_FXP_CLOSE, Size: 17, Number: 1028
< Type: SSH_FXP_STATUS, Size: 9, Number: 1028
< Status/error code: 0
. Startup conversation with host finished.
. Changing directory to "OneTimeFTP".
. Getting real path for '/OneTimeFTP'
> Type: SSH_FXP_REALPATH, Size: 20, Number: 1296
< Type: SSH_FXP_NAME, Size: 145, Number: 1296
. Real path is '///hf1fs1/users1$/server12/support/test/onetimeftp'
. Trying to open directory "///hf1fs1/users1$/server12/support/test/onetimeftp".
> Type: SSH_FXP_OPENDIR, Size: 71, Number: 1547
< Type: SSH_FXP_STATUS, Size: 9, Number: 1547
< Status/error code: 4, Message: 1547, Server: None, Language: ?
* (ECommand) Error changing directory to 'OneTimeFTP'.
* General failure.
* Error code: 4
* Request code: 11
. Changing directory to "PostProcessed".
. Trying to open directory "///hf1fs1/users1$/server12/support/cui_test/postprocessed".
* General failure.
* Error code: 4
* Request code: 11
What version does work? Does it work with SCP or SFTP protocol? You may download older version on Sourceforge.
From the log I believe that WinSCP behaves correctly. It ask server to cannonize path '/PostProcessed' because you enter the PostProcessed directory from the root. The server replies that actual full path is '///hf1fs1/users1$/server12/support/test/postprocessed', but then it refuses to sent a directory listing for it. The responsed full path is rather strange, does it have some meaning on your server?
Also, you have not still answered me, if you are able to enter at least some directory. Thanks.
I can not access any directories. They all gave me the same error message. I don't really know the meaning of the full path on our server.
My colleague didn't say what older version he's using. I will download an older version and let you know if it works.
cu
Thanks in advance. I'm really interested in this.
Other Guest
Hi all,
i'm a new WinSCP user. I have the same problem with f-secure ssh server on windows NT server.
I'll give you more information.
I have tried to log on on my ssh server with psftp. I am able to change directory using this command: cd \dirname. From WinSCP i receive this message:
WinSCP Version 3.5.6 (Build 213)
Login time: Wednesday, April 28, 2004 10:21:49 AM
Session name:
Host name: (Port: 22)
User name: (Password: Yes, Key file: No)
Transfer Protocol: SFTP (SCP)
SSH Bugs: -,-,-,-,-,-,-,-,
Proxy: none
Shell: /bin/bash, EOL: 0
Looking up host ""
Connecting to port 22
We claim version: SSH-2.0-WinSCP-release-3.5.6
ssh-dss 1024 df:5b:1a:db:fd:ba:e6:7f:3c:f3:24:5f:8a:68:27:94
Using username "".
Session password prompt (@'s password: )
Sent password
Access granted
Type: SSH_FXP_REALPATH, Size: 10, Number: 10512
Type: SSH_FXP_NAME, Size: 23, Number: 10512
Real path is '/'
Type: SSH_FXP_OPENDIR, Size: 10, Number: 10763
Type: SSH_FXP_HANDLE, Size: 17, Number: 10763
Type: SSH_FXP_READDIR, Size: 17, Number: 11020
Type: SSH_FXP_NAME, Size: 737, Number: 11020
Type: SSH_FXP_READDIR, Size: 17, Number: 11276
Type: SSH_FXP_STATUS, Size: 9, Number: 11276
Type: SSH_FXP_CLOSE, Size: 17, Number: 11524
Type: SSH_FXP_STATUS, Size: 9, Number: 11524
Changing directory to "VF-ES".
Getting real path for '/VF-ES'
Type: SSH_FXP_REALPATH, Size: 15, Number: 11792
Type: SSH_FXP_NAME, Size: 63, Number: 11792
Real path is '/D:/sftp/vosedc/vf-es'
Trying to open directory "/D:/sftp/vosedc/vf-es".
Type: SSH_FXP_OPENDIR, Size: 30, Number: 12043
Type: SSH_FXP_STATUS, Size: 9, Number: 12043
Status/error code: 4, Message: 12043, Server: None, Language: *
(ECommand) Error changing directory to 'VF-ES'.
General failure.
Error code: 4
Error message from server: None (*)
Request code: 11
Type: SSH_FXP_REALPATH, Size: 15, Number: 12304
Type: SSH_FXP_NAME, Size: 63, Number: 12304
Type: SSH_FXP_OPENDIR, Size: 30, Number: 12555
Type: SSH_FXP_STATUS, Size: 9, Number: 12555
Status/error code: 4, Message: 12555, Server: None, Language: *
General failure.
Error code: 4
Request code: 11
Have you any suggestion?
Thank's in advance.
If the only way how you can enter the directory is "cd \dirname" than it is bug of the server. SFTP specification says that the server must support at least normal slashes (/). So you should be able to enter the directory with "cd /dirname" too. Are you?
Note that it is not forbidden to use backslashes, but normal slashes must be supported!
Anyway, the problem is just the same as it he post above: WinSCP asks server for fullpath to directory you enter. The server replies what that the fullpath is, but subsequently refuses to list its content. I do not understand this.
Does it happen with every directory on your server?
Can you create a test account for me?
BTW, I have deleted your duplicate post.
Yes it happens on every directory on the home direcotory of the user. It's very very strange.... Confused
I have also verified that with f-secure ssh file transfer all works fine...
thanks
No, I can't... because ssh server is behind firewall and i'm not system administrator.... sorry.
OK, I have downloaded evaluation version of the F-Secure server. Maybe it will help me to solve this.
BTW: Are you able to enter the directory by typing "\dirname" to "Open directory" window (Ctrl-O)?
Apologies for delay...
I have closed this issue installing new versionn of F-Secure SSH Server (5.3 build 20).
This problem is caused by a bug in the older version of SSH Server.
Thank you.
algernon
hi,
i have just experienced the same problem.
cannot change to any dir after login.
unfortunately i do not know what server type i am connecting to. i try to find out.
i am sure it is an incompatibility to be blamed to the server, but it is true, the older 3.6.8 of winscp version works! all 3.7.x do not.
using the goto>opendir> and typing \dirname or /dirname does not do the trick.
a truely lovely program! btw, what kind of free ssl-ftp server would you recommend if i want to set one up for my own use?
algernon
I'm not very clever from your post. What problem are you exactly having?
WinSCP has nothing to do with SSL. It is SSH. I use OpenSSH for Windows.
it is a problem similar to what user "cu" reports!
Error changing directory to 'xxx'
The server does not support the operation.
Error code: 8
Error message from server: Operation unsupported
Request code: 7
the old version winscp 3.6.8. does not give this error!
in case you want to reproduce the error, here is some info.
the server i connect to is called ftpshellserver:
http://www.ftpshell.com/
http://www.ftpshell.com/download/ftpservsetup.exe
greetings,
algernon
Error code: 8
Request code: 7
This is completelly different problem.
I have downloaded the server and its SFTP implementation seems terrible.
I have implemented workaround for this particular lack of functionality. In other words WinSCP returns back to pre-3.7.2 approach when entering subdirectories when server fails to support the newer approach. The change in 3.7.2 was that since this version WinSCP allows entering traverse-only directories (chmod 110).
However it seems that the server does not support many other features.
algernon
nice support! Very Happy
i do not have any choice in this particular case, but what (free) sftp server would you recommend to install and use together with winscp?
another question, do you consider writing a plugin for "total commander"?
www.ghisler.com
OpenSSH for Windows, see one of my posts above.
www.ghisler.com
No. Or at least not now. This was discussed here many times, please search the forum.
uologic
I removed
[Sessions\Default%20Settings]
from winscp.ini and error code 2 can't change directory is gone. hope that help you.
