Topic "WinSCP script- Want to automate the copy of files"
VictorIT1
Need help with this daily manual code script.
Help in changing script to automate
1. Automatically pull a list of source folder names from \\ipaddress\backups\LatestOfEach\
There are many folders similar to VMNAME-421b33f2-ca0f-1279-633f-fe7f84d3b6a2-20110601_000316
VMNAME-GUID---------------------------------date----_time--
2. To use the put command while ignoring the source folder -date_time.
The source folders cannot be renamed...
3. During the put command rename the files in the source folder to the correct name format.
i.e. Source folders have files names as:
VMNAME-scsi0_0-flat.vmdk
VMNAME-scsi0_0.vmdk
VMNAME-scsi0_1-flat.vmdk
VMNAME-scsi0_1.vmdk
Destination files should be named: (Correspond to source files)
VMNAME-flat.vmdk
VMNAME.vmdk
VMNAME_1-flat.vmdk
VMNAME_1.vmdk
Skilled help is VERY much welcome. Smile - Shocker...
Here is the current code:
# Author: VictorIT1
# Date: 20110531
# Purpose: Replicate all previous day backups to secondary SAN storage
# What it does: Logins to ESXi host and (remote) directory, then in binary
# batch mode get or put files to specific target.
# How to call this script:
#winscp.exe /console /script=c:\scripts\replication_script.txt /log="c:\scripts\replicationlog.txt"
# or
# use Windows Scheduler
# Requirement: Net map R: as persistent to \\X.Y.Z.149\backups\LatestOfEach
# Or AS DONE HERE use the UNC path (instead of a mapped drive)
# user: username password: correct-password on local system before using.
option batch on
open scp://root:@passwordhere@ESX4.1Update1host.dom
cd/vmfs/volumes/
option transfer binary
# VMNAME1
put \\X.Y.Z.149\backups\LatestOfEach\VMNAME1-421b33f2-ca0f-1279-633f-fe7f84d3b6a2-20110601_000316\*.vmdk /vmfs/volumes/DataCore2/VMNAME1/*.vmdk
# VMNAME2
put \\X.Y.Z.149\backups\LatestOfEach\VMNAME2-420068db-9b0b-f396-75ef-345418ec76e7-20110601_000316\*.vmdk /vmfs/volumes/DataCore3/VMNAME2/*.vmdk
# VMNAME3
#put \\X.Y.Z.149\backups\LatestOfEach\VMNAME3-503c248e-44b8-7e1c-b7e2-159a60cf421e-20110601_000316\*.vmdk /vmfs/volumes/DataCore3/VMNAME3/*.vmdk
close
There's example script you may start with:
http://winscp.net/eng/docs/script_download_timestamped_filename
VictorIT1
prikryl,
Thanks for the script referal. It is kind of doing the opposite of what I am looking for, but the components of the script give enough knowledge to probably allow for adaption.
Thanks again,
VictorIT1
