Topic "Shortcut"
PiperK
Hello!
I maintain a website and use WinSCP to access the files. The website has been maintained by many people and as a result there are files everywhere. I am trying to create a folder with shortcuts to the files/folders I access. It is difficult to navigate through all the files for just the ones I need and with a shortcut, I'd be more productive.
I tried creating links but get errors that the file either doesn't exist or already does.
Please help!
