Access denied
Karloce
Access denied
I get access denied while trying to login. here are the entires in the logs:
User is in a group which has full control.
08-01-2011 13:19:48 IP 76.255.79.16 SSH connection attempt.
08-01-2011 13:19:54 IP 76.255.79.16 SSH test1 successfully logged on using password.
Dont understand why access deined and logs shows successful login.
Re: Access denied
