Convert char encoding of sending file's name to UTF-8
Yozora Mikazuki
Dear WinSCP developer team
Recently, I encountered the problem that Windows OS in Japanese environment automatically converts file-name's char encoding from UTF-8 to SHIFT_JIS(SJIS) when it sends a file via ftp(sftp). This makes a serious problem of strange characters because of the server using UTF-8 encoding.
I really would like you to implement the function that enables WinSCP to encode sending file's name to UTF-8 like FileZilla.
Thank you for reading.
Yozora Mikazuki
Re: Convert char encoding of sending file's name to UTF-8
Thank you for early reply!
I have read the document you mentioned but the problem is still not solved.
Even if I send a file with settings that "UTF-8 encoding for filenames" is on, starange characters appears when I send a binary file like mp4.
Now what should I do to solve this encoding problem?
Sincerely,
