How to detect internet connection loss during transfer?
doydoy
Hey everyone, I'm fairly new to WinSCP in .NET. I have been using SSH.NET so far, but I can't make it handle internet connection losses properly. And since WinSCP offers resuming file transfer after disconnection, I just HAD to try it :)
Currently I am testing a situation where a user would download 1 file only, while they are conencted through a VPN. Turning off the VPN doesn't seem to faze WinSCP as the download resumes after a while without issue. Yet turning all internet connections off (Wifi in this case) just makes the transfer stay on a lull, with no exceptions thrown or any prompt whatsoever.
My question is, is there a way where WinSCP can react to a complete internet connection loss? Or at least a disconnection from the server?
I have had a look (and tested) both Session.GetFiles() and Session.GetFileToDirectory().
GetFiles does have the Check() method to throw any errors, but it does not seem to do anything.
Any feedback is appreciated. Thanks in advance! :)
Edit: I use the SFTP protocol, if it helps.
Re: How to detect internet connection loss during transfer?
doydoy
Log attached!
The wifi connection was turned off at 13:56. However, I can see that WinSCP was attempting to reconnect with the server several times. During this, no output was given. It was only when I turned the wifi on again when the session went on to resume the transfer, and then I shut down the debugging process.
For reference, here is how my session is configured:
static void Main(string[] args)
    try
            Protocol = Protocol.Sftp,
            HostName = "SERVER_URL",
            UserName = "USERNAME",
            SshPrivateKeyPath = @"C:\PuttyPrivateKey.ppk",
            SshHostKeyPolicy = SshHostKeyPolicy.GiveUpSecurityAndAcceptAny,
            Timeout = new TimeSpan(0, 0, 15)
            session.FileTransferProgress += SessionFileTransferProgress;
            session.SessionLogPath = @"C:\connection_loss_log_1.log";
            // Connect
            session.Open(sessionOptions);
            if (!session.FileExists(fileToDownload))
                Console.WriteLine("File does not exist!");
                session.Close();
            else
                RemoteFileInfo remoteFileInfo = session.GetFileInfo(fileToDownload);
                remoteFileSize = remoteFileInfo.Length;
                // Download files
                TransferOptions transferOptions = new TransferOptions();
                transferOptions.TransferMode = TransferMode.Binary;
                string fullDestPath = Path.Combine(destinationPath, fileToDownload);
                TransferOperationResult transferResult = session.GetFiles(fileToDownload, fullDestPath, false, transferOptions);
                // Throw on any error
                transferResult.Check();
                session.Close();
    catch (SessionLocalException sle)
        Console.WriteLine("SessionLocalException " + sle.Message);
    catch (SessionRemoteException sre)
        Console.WriteLine("SessionRemoteException " + sre.Message);
    catch (Exception ex)
        Console.WriteLine("Error in ProcessEdi() while downloading EDI files via FTP: Message:" + ex.Message + "Stacktrace: " + ex.StackTrace);
Console.WriteLine("End.");
            Console.ReadLine();
static void SessionFileTransferProgress(object sender, FileTransferProgressEventArgs e)
    long currentSize = (long)(remoteFileSize * e.FileProgress);
    Console.WriteLine("Progress: " + currentSize +" of " + remoteFileSize);
    Console.WriteLine("OVerallProgress: " + e.OverallProgress);
    Console.WriteLine("==========================");
  • connection_loss_log_1.log (19.14 KB, Private file)
In the log I see that WinSCP reconnected successfully after the connection was restored. What do you want it to do differently?
Antony Parakka
FTP Upload Resume Disconnection Notification
Hi Friend ,Resume is working Fine .While internet disconnected want to show message .From session.PutFiles giving no notifications
