GUI transfers fine, script throws timeout detected connection control
Zparr
WinSCP version 6.1.2
Windows Server 2022
FTP TLS/SSL
Hello, I'm trying to automate a transfer of a small website. When using the GUI, I simply select the entire contents of the folder and click download. The "Download" window appears, I make no changes and click OK. The "Downloading" window appears and it works perfect every time.
I then invoke the following command:
"c:\Program Files (x86)\WinSCP\WinSCP.com" /log=c:\temp\winscp-script-log.txt /script=c:\batch\winscp-script2.txt
c:\batch\winscp-script2.txt:
open ftp://ftpsync@redacteddomain.com:complexredactedpassword@redacteddomain.com/
lcd "C:\batch\public_html"
get /public_html/*
The consistent result is that the files start to transfer and after 1 to 30 files transfer, the following error is returned:
.htaccess                 |          731 B |    1.1 KB/s | binary | 100%
Lost connection.
Timeout detected. (control connection)
Copying files from remote side failed.
(A)bort, (R)econnect (0 s):
I've scoured the forums and the most frequent diagnosis is a firewall issue. Given that the GUI works perfectly everytime, is that still the recommendation? I've also checked the on-prem firewall and do not see any blocked or aborted sessions.
Attached is the session log.
  • winscp-script-log.txt (10.58 KB, Private file)
Description: session log
