Topic "Put files with wildcard - Error"
Hugo Hugrich
i use WinSCP 4.18 and i am a Beginner. We need to put some files to another company.
This files have a running number. The file-name ist bq00001 bq00002 and so on.
The files should be delete after i have puted the files to the another company.
I want to run the transfer in a batchmode. I have written a bat-file with content:
set abfrage=D:\Programme\test
set winscp=D:\Programme\Winscp
cd /D %abfrage%
if exist %abfrage%\bq*.* %winscp%\winscp.exe /console /hostkey /log=D:\log.txt /script=abfragebzr.txt
cd \
The file abfragebzr.txt content:
option batch on
open session_test
put -delete bq*
but now i get an error in the log-file. Here are content of the log-file-error:
. 2009-01-14 11:54:03.746 Copying 1 files/directories to remote directory "/home/test/data"
. 2009-01-14 11:54:03.746 PrTime: Yes; PrRO: No; Rght: rw-r--r--; PrR: No (No); FnCs: N; RIC: 01; Resume: S (102400); CalcS: No; Mask:
. 2009-01-14 11:54:03.746 TM: M; ClAr: No; CPS: 0; ExclM(No):
. 2009-01-14 11:54:03.746 AscM: *.*html; *.htm; *.txt; *.php; *.php3; *.cgi; *.c; *.cpp; *.h; *.pas; *.bas; *.tex; *.pl; .htaccess; *.xtml; *.css; *.cfg; *.ini; *.sh; *.xml
. 2009-01-14 11:54:03.746 File: "bq*"
* 2009-01-14 11:54:03.761 (EOSError) System Fehler. Code: 123.
* 2009-01-14 11:54:03.761 Die Syntax fr den Dateinamen, Verzeichnisnamen oder die Datentrgerbezeichnung ist falsch
. 2009-01-14 11:54:03.761 Asking user:
. 2009-01-14 11:54:03.761 Datei oder Verzeichnis "bq*" existiert nicht. ("System Fehler. Code: 123.
. 2009-01-14 11:54:03.761 Die Syntax fr den Dateinamen, Verzeichnisnamen oder die Datentrgerbezeichnung ist falsch")
* 2009-01-14 11:54:03.777 (EScpSkipFile) Datei oder Verzeichnis "bq*" existiert nicht.
* 2009-01-14 11:54:03.777 System Fehler. Code: 123.
* 2009-01-14 11:54:03.777 Die Syntax fr den Dateinamen, Verzeichnisnamen oder die Datentrgerbezeichnung ist falsch
. 2009-01-14 11:54:03.777 Closing connection.
. 2009-01-14 11:54:03.777 Sending special code: 12
. 2009-01-14 11:54:03.777 Sent EOF message
I try to translate the error at 2009-01-14 11_54:03.761 file or directory "bq* does not exist) (System Error. Code 123)
What is wrong in my skript ?
Sorry about my English.
Christian
You have to use *.* in your put command.
The documentation was wrong about using of file masks. I have fixed that.
hemant_kalal
I am using following script to upload all the files from local directory to remote system, the requirement is that if a perticular file already exist then it should not copy that file and move on with the next file but the problem is that if it finds the file on the remote server it exits the session and does not consider the next file, If say I delete all the files from the remote machine then the script works fine.Pls. let me know where I am doing it wrong.
option batch on
put c:\temp2\*.txt
close
option batch on
put c:\temp2\*.txt
close
Use "synchronize remote", not "put". Read documentation.
Kevdog777
I have hit an issue in WinSCP.
I am trying to copy a file from SCO to my local machine (Vista), and am getting the following error:
System Error. Code: 123.
The filename, directory name, or volume label syntax is incorrect
All I am doing is:
1) dragging file1.txt from SCO (right hand side of WinSCP)
2) dropping file1.txt into the folder on my local machine - which was pre-created (left hand side of WinSCP)
I have done this many times with other platforms.
Is this an issue with my file or is this an issue elsewhere?[/list]
Kevdog777 wrote:
All I am doing is:
Please start a new thread and attach a full log file showing the problem (using the latest version of WinSCP).
kevdog777
prikryl wrote:
Kevdog777 wrote:
All I am doing is:
Hi Martin,
Thanks for getting back to me. I have tried a few things, and was about to send you the log file, but my colleague thought it may be a corrupt file, which it was.
So there is no issue in WinSCP Mr. Green
By the way, it is a great product!
