Topic "Invalid handle error with initial remote directory"
AnonBugCoward
I get an invalid handle error when initial SFTP remote directory is /Mailbox:/FOOORPTS/INBOX
I can navigate to the directory manually after login just fine.
WinSCP version 4.3.2 (Build 1201). I got the error in prior versions as well.
Error
Error changing directory to '/Mailbox:/FOOORPTS/INBOX'.
Invalid handle.
Error code: 9
Error message from server (en): The handle is invalid.
Request code: 7
OK Help
Please post a full log files showing both cases (separate log file for each).
AnonBugCoward
First, I found this post on the forum: http://winscp.net/forum/viewtopic.php?t=2576
Is that related to my issue?
Here is the log up until the error plus the next few lines:
WinSCP Version 4.3.2 (Build 1201) (OS 5.1.2600 Service Pack 3)
Login time: Thursday, April 21, 2011 1:56:48 PM
Session name: FOO
Host name: ftp.foopro.com (Port: 22)
User name: FOOUSER1 (Password: No, Key file: No)
Tunnel: No
Transfer Protocol: SFTP (SCP)
Ping type: -, Ping interval: 30 sec; Timeout: 15 sec
Proxy: none
SSH protocol version: 2; Compression: No
Bypass authentication: No
Try agent: Yes; Agent forwarding: No; TIS/CryptoCard: No; KI: Yes; GSSAPI: No
Ciphers: aes,blowfish,3des,WARN,arcfour,des; Ssh2DES: No
SSH Bugs: -,-,-,-,-,-,-,-,-
SFTP Bugs: -,-
Return code variable: Autodetect; Lookup user groups: Yes
Shell: default
EOL: 0, UTF: 2
Clear aliases: Yes, Unset nat.vars: Yes, Resolve symlinks: Yes
LS: ls -la, Ign LS warn: Yes, Scp1 Comp: No
Local directory: C:\Program Files\_Projects\1160\FOO\Daily Foo Files, Remote directory: /Mailbox:/FOOORPTS/INBOX, Update: No, Cache: Yes
Cache directory changes: Yes, Permanent: Yes
DST mode: 1
Looking up host "ftp.foopro.com"
Connecting to aaa.bb.ccc.ddd port 22
Server version: SSH-2.0-VShell_2_3_2_178 VShell
We believe remote version has SSH-2 ignore bug
Using SSH protocol version 2
We claim version: SSH-2.0-WinSCP_release_4.3.2
Doing Diffie-Hellman group exchange
Doing Diffie-Hellman key exchange with hash SHA-1
Host key fingerprint is:
ssh-dss 1024 aa:bb:cc:dd:ee:ff:gg:hh:ii:jj:kk:ll:mm:nn:oo:pp
Initialised AES-256 CBC client->server encryption
Initialised HMAC-SHA1 client->server MAC algorithm
Initialised AES-256 CBC server->client encryption
Initialised HMAC-SHA1 server->client MAC algorithm
Using username "FOOUSER1".
Prompt (6, SSH password, , &Password: )
Sent password
Access granted
Opened channel for session
Started a shell/command
Using SFTP protocol.
Doing startup conversation with host.
Type: SSH_FXP_INIT, Size: 5, Number: -1
Type: SSH_FXP_VERSION, Size: 340, Number: -1
SFTP version 4 negotiated.
Unknown server extension newline@vandyke.com=0x00F00
Server requests EOL sequence "\r\n".
File system roots:
Unknown server extension default-fs-attribs@vandyke.com=0x0F00
We will use UTF-8 strings when appropriate
Changing directory to "/Mailbox:/FOOORPTS/INBOX".
Getting real path for '/Mailbox:/FOOORPTS/INBOX'
Type: SSH_FXP_REALPATH, Size: 33, Number: 16
Type: SSH_FXP_NAME, Size: 41, Number: 16
Real path is 'Mailbox:/FOOORPTS/INBOX'
Trying to open directory "Mailbox:/FOOORPTS/INBOX".
Type: SSH_FXP_LSTAT, Size: 36, Number: 263
Type: SSH_FXP_STATUS, Size: 42, Number: 263
Status code: 9, Message: 263, Server: The handle is invalid. , Language: en
(ECommand) Error changing directory to '/Mailbox:/FOOORPTS/INBOX'.
Invalid handle.
Error code: 9
Request code: 7
Getting current directory name.
Getting real path for '.'
Type: SSH_FXP_REALPATH, Size: 10, Number: 528
Type: SSH_FXP_NAME, Size: 27, Number: 528
Real path is 'Mailbox:'
Listing directory "Mailbox:".
It could be related. Have you tried setting the SFTP version to 3? Also try to seek help from Vandyke support.
AnonBugCoward
Changing WinSCP to SFTP version 3 and removing the colon (:) from after "Mailbox" did the trick.
When I log onto that site with SFTP version 5 and browse from root, there's a colon after "Mailbox". When I log onto the site with version 3, there's no colon. Very strange!
So solution is:
WinSCP: set SFTP version 3
Remote directory: /Mailbox/FOOORPTS/INBOX
Thanks for the pointers.
Still, it would be nice if you report this to Vandyke. If you do, please cc me.
