Cannot change Visible in OnShow or OnHide - Vcl::Forms::TCustomForm::CMShowingChanged
Goto page
Previous, 1, 2, 3
a.s.jernakov@...
WinSCP 5.17.4
Трассировка стека:
(00237E84) Vcl::Forms::TCustomForm::CMShowingChanged
(000281C3) TCustomScpExplorerForm::CMShowingChanged
(00028052) TCustomScpExplorerForm::Dispatch
(00279DF5) Vcl::Controls::TWinControl::WndProc
(002342BC) Vcl::Forms::TCustomForm::WndProc
(00E4137C) Vclcommon::C2992_0
a.s.jernakov@...
WinSCP 5.17.4
Трассировка стека:
info@...
WinSCP 5.17.4
jcarlson1701@...
<Try to describe precise steps that lead to the problem (where do you click, what keys do you press, what do you see, etc.)> Error dialog appears at launch of WinSCP
WinSCP 5.17.4
mattia.landoni@...
I just installed WinSCP on a fresh windows install. This message happens every time I open the program. The program then opens up and works regularly.
WinSCP 5.17.4
pivovarov.maxim@...
WinSCP 5.17.4
Трассировка стека:
scott.shapiro@...
Occurs when launching program after install on new laptop. Once I log into a site, I cannot navigate to directories. They are grayed out. My other laptop has 5.17.3 and I don't have an issue. I grabbed that version for my new laptop and I'm up and running on the older version.
WinSCP 5.17.4
rafatrelles17@...
WinSCP 5.17.4
402641605@...
WinSCP 5.17.4
karbuncle@...
Fresh install, on launch. Happens all the time. After clicking OK it seems to function normally.
WinSCP 5.17.4
yzu-vetlab@...
WinSCP 5.17.4
zgubacsi@...
Error occurs on every start of the application.
After continue the application works but the remote window is disabled (grey). No click event received by the panel.
WinSCP 5.17.4
Veremkivonat:
frankhoeflich@...
When starting WinSCP with local directory on my Windows 10 laptop, and remote directory on my Ubuntu server at work (via Cisco AnyConnect Secure Mobility Client VPN).
WinSCP 5.17.4
pushkin@...
WinSCP 5.17.4
darren.joyner@...
The errors happen when I open the program
WinSCP 5.17.4
wani_fakhira95@...
WinSCP 5.17.4
davec.bugs@...
WinSCP 5.17.4
fatuitycookie@...
WinSCP 5.17.4
nidhitewari23@...
WinSCP 5.17.4
wrnewcombe@...
WinSCP 5.17.4
msekiguc@...
WinSCP 5.17.4
スタック トレース:
Re: Cannot change Visible in OnShow or OnHide - Vcl::Forms::TCustomForm::CMShowingChanged
Thanks for your reports.
cedric.repincay@...
WinSCP 5.17.4
Trace de la pile :
johnnyv_cn@...
Error displayed when starting WinSCP.
WinSCP 5.17.4
mailingbin@...
WinSCP 5.17.4
Трассировка стека:
eboto@...
- installed with .exe file
- got a window with error
WinSCP 5.17.4
Trace de la pile :
jannette@...
WinSCP 5.17.4
liannedelange7@...
WinSCP 5.17.4
rafisoltys@...
WinSCP 5.17.4
amihai@...
WinSCP 5.17.4
m@...
WinSCP 5.17.4
(00237E84)
(000281C3)
(00028052)
(00279DF5)
(002342BC)
(00E4137C)
a.s.jernakov@...
WinSCP 5.17.5
(0025293B) Vcl::Forms::TCustomForm::CMShowingChanged
(00035533) TCustomScpExplorerForm::CMShowingChanged
(00034F37) TCustomScpExplorerForm::Dispatch
(001D6079) Vcl::Controls::TControl::WndProc
(001DBD17) Vcl::Controls::TWinControl::WndProc
(0024DD70) Vcl::Forms::TCustomForm::WndProc
(00FE78AB) Vclcommon::C3005_0
(00FEA8E0) DoFormWindowProc
(00FE7A64) Vclcommon::C3005_0
(001D5B7A) Vcl::Controls::TControl::Perform
(001DAFC0) Vcl::Controls::TWinControl::UpdateShowing
(001DB0E6) Vcl::Controls::TWinControl::UpdateControlState
(001DAE56) Vcl::Controls::TWinControl::CMRecreateWnd
(00034F85) TCustomScpExplorerForm::Dispatch
(00FEAB40) DoFormWindowProc
(001DAE0B) Vcl::Controls::TWinControl::RecreateWnd
(0024F352) Vcl::Forms::TCustomForm::SetPosition
(000DAD29) RestoreForm
(00062E3F) TScpCommanderForm::RestoreFormParams
(0002BD1A) TCustomScpExplorerForm::DoShow
(000642C2) TScpCommanderForm::DoShow
(00252994) Vcl::Forms::TCustomForm::CMShowingChanged
(001DE771) Vcl::Controls::TWinControl::CMVisibleChanged
(001D3CB0) Vcl::Controls::TControl::SetVisible
(0024D4AD) Vcl::Forms::TCustomForm::SetVisible
(00259B8D) Vcl::Forms::TApplication::Run
(0012A258) Execute
(0000315D) wWinMain
(0112F759) C5178_0
(00066C12) ntdll.dll.RtlGetAppContainerNamedObjectPath
(00066BDF) ntdll.dll.RtlGetAppContainerNamedObjectPath
gjia@...
Previous shotdown was forced by holding power button. Start Windows (cold boot), try to start WinSCP from start menu pin, got this meesage (not sure how long after clicking the pin as I was not paying attention to the computer for a while after). I see a previous issue marked as resolved, but my window was not aligned with top or left monitor edge previously.
WinSCP 6.5.5
(004ABC78) Vcl::Forms::TCustomForm::CMShowingChanged
(0002D83D) TCustomScpExplorerForm::CMShowingChanged
(0002D5A0) TCustomScpExplorerForm::Dispatch
(0039E3C2) Vcl::Controls::TControl::WndProc
(003A356D) Vcl::Controls::TWinControl::WndProc
(004A77B4) Vcl::Forms::TCustomForm::WndProc
(00E06DE4) Vclcommon::C4884_0
(00E06FA6) Vclcommon::C4884_0
(0039DFF8) Vcl::Controls::TControl::Perform
(003A2819) Vcl::Controls::TWinControl::UpdateShowing
(003A292E) Vcl::Controls::TWinControl::UpdateControlState
(003A24FF) Vcl::Controls::TWinControl::CMRecreateWnd
(0002D652) TCustomScpExplorerForm::Dispatch
(00E0706B) Vclcommon::C4884_0
(003A24BA) Vcl::Controls::TWinControl::RecreateWnd
(00065087) TScpExplorerForm::RestoreFormParams
(00065601) TScpExplorerForm::DoShow
(004ABCD1) Vcl::Forms::TCustomForm::CMShowingChanged
(003A56F2) Vcl::Controls::TWinControl::CMVisibleChanged
(0039CA26) Vcl::Controls::TControl::SetVisible
(0012A249) Execute
(000033BB) wWinMain
(00EF5205) __wstartup
(0006B439) ntdll.dll
(0006B3BA) ntdll.dll
Goto page
Previous, 1, 2, 3
