Advanced FTP/SFTP scripting
cscript.exeorwscript.exe) to run Java Script or VB Script files.
- Windows scripting host (Java or VB script)
- Further reading
It supports all the features listed in Windows command interpreter section above (with grater flexibility). Plus it includes many advanced functions, you may find useful when using together with WinSCP. See sections below.
To use the examples below copy the JavaScript code to file (e.g. example.js) and use cscript.exe to execute it (use /nologo to suppress banner):
cscript /nologo example.js
You can use WScript.Shell to execute WinSCP console interface tool and feed the script commands (using input stream), without creating temporary script file:
var shell = WScript.CreateObject("WScript.Shell"); // run (make it log to XML) var exec = shell.Exec("winscp.com /log=log.xml"); // feed the commands exec.StdIn.Write( "option batch abort\n" + "open session\n" + "ls\n" + "exit\n"); // wait until it finishes while (exec.Status == 0) { WScript.Sleep(100); }
If you want to see WinSCP output replace the trailing while statement with:
// wait until the script finishes while (!exec.StdOut.AtEndOfStream) { WScript.Echo(exec.StdOut.ReadAll()); }
XML parsing
Note that while you may find installing new scripting engine to Windows troublesome, you may not need to install anything actually. E.g. for using PHP interpreter, you can just grab the Windows binary PHP zip package and extract php.exe and php5ts.dll files out of it. These two binaries alone support most (if not all) features you need. No installing or registration is required.
Now you can execute PHP script example.php:
with simple command:
php.exe example.php
Further reading
- Troubleshooting;
- Scripting documentation;
- Guide to automation;
- FAQ about scripting;
- Example scripts.
