Advanced FTP/SFTP scripting
cmd.exe
) to run.bat
or.cmd
files (for simple tasks); - Windows script host (
cscript.exe
orwscript.exe
) to run Java Script or VB Script files.
- Windows scripting host (JScript or VB script)
- .NET (C# or VB.NET)
- Further reading
Windows command interpreter executes .bat
or .cmd
files. Some of the features it supports:
It supports all the features listed in Windows command interpreter section above (with greater flexibility). Plus it includes many advanced functions, you may find useful when using together with WinSCP. See sections below.
To use the examples below copy the JavaScript code to file (e.g. example.js
) and use cscript.exe
to execute it (use /nologo
to suppress banner):
cscript /nologo example.js
You can use WScript.Shell
to execute WinSCP console interface tool and feed the script commands (using input stream), without creating temporary script file:
var shell = WScript.CreateObject("WScript.Shell"); // run (make it log to XML) var exec = shell.Exec("winscp.com /log=log.xml"); // feed the commands exec.StdIn.Write( "option batch abort\n" + "open mysession\n" + "ls\n" + "exit\n"); // wait until it finishes and collect its output var output = exec.StdOut.ReadAll(); // optionally print the output WScript.Echo(output);
XML parsing
You can use MSXML2.DOMDocument
object to parse XML log produced by WinSCP. The following example follows up to the previous one (which starts session with XML logging and lists contents of initial directory):
.NET (C# or VB.NET)
Note that while you may find installing new scripting engine to Windows troublesome, you may not need to install anything actually. E.g. for using PHP interpreter, you can just grab the Windows binary PHP zip package and extract php.exe
and php5ts.dll
files out of it. These two binaries alone support most (if not all) features you need. No installing or registration is required.
Having the two binaries you can execute PHP script example.php
with simple command:
php.exe example.php
Further reading
- Troubleshooting;
- Scripting documentation;
- Guide to automation;
- FAQ about scripting;
- Example scripts.
