Advanced FTP/SFTP scripting
WinSCP .NET assembly mostly deprecates techniques demostrated in this article. Using the assembly is now preferred approach for advanced automation tasks with WinSCP.
cscript.exeorwscript.exe) to run Java Script or VB Script files.
- Windows script host (JScript or VB script)
- .NET (C# or VB.NET)
- Further reading
It supports all the features listed in Windows command interpreter section above (with greater flexibility). Plus it includes many advanced functions, you may find useful when using together with WinSCP. See sections below.
To use the examples below copy the JavaScript code to file (e.g. example.js) and use cscript.exe to execute it (use /nologo to suppress banner):
cscript /nologo example.js
You can use WScript.Shell to execute WinSCP console interface tool and feed the script commands (using input stream), without creating temporary script file:
var shell = WScript.CreateObject("WScript.Shell"); // run (make it log to XML) var exec = shell.Exec("winscp.com /log=log.xml"); // feed the commands exec.StdIn.Write( "option batch abort\n" + "open mysession\n" + "ls\n" + "exit\n"); // wait until it finishes and collect its output var output = exec.StdOut.ReadAll(); // optionally print the output WScript.Echo(output);
XML parsing
See also guide to interpreting XML log for advanced scripting (uses C# language, though could be easily rewritten to JScript or VB script).
.NET (C# or VB.NET)
Note that while you may find installing new scripting engine to Windows troublesome, you may not need to install anything actually. E.g. for using PHP interpreter, you can just grab the Windows binary PHP zip package and extract php.exe and php5ts.dll files out of it. These two binaries alone support most (if not all) features you need. No installing or registration is required.
Having the two binaries you can execute PHP script example.php:
with simple command:
php.exe example.php
Further reading
- Troubleshooting;
- WinSCP .NET assembly;
- Scripting documentation;
- Guide to automation;
- FAQ about scripting;
- Example scripts.
