Advanced FTP/SFTP scripting
WinSCP .NET assembly mostly deprecates techniques demostrated in this article. Using the assembly is now preferred approach for advanced automation tasks with WinSCP.
Choosing Language
  • Windows command interpreter (cmd.exe) to run .bat or .cmd files (for simple tasks);
  • Windows script host (cscript.exe or wscript.exe) to run Java Script or VB Script files.
Windows command interpreter (batch files)
  • Conditional execution based on an exit code of an application or a value of an environment variable;
  • An iteration over files matching a mask;
  • Setting and querying environment variables;
  • Simple file path manipulation (extracting a directory from a path, extracting an extension, etc.).
Windows script host (JScript or VB script)
It supports all the features listed in Windows command interpreter section above (with greater flexibility). Plus it includes many advanced functions, you may find useful when using together with WinSCP. See sections below.
To use the examples below copy the JScript code to file (e.g. example.js) and use cscript.exe to execute it (use /nologo to suppress banner):
cscript /nologo example.js
You can use WScript.Shell to execute WinSCP console interface tool and feed the script commands (using input stream), without creating temporary script file:
var shell = WScript.CreateObject("WScript.Shell");
// run (make it log to XML)
var exec = shell.Exec("winscp.com /xmllog=log.xml");
// feed the commands
exec.StdIn.Write(
    "option batch abort\n" +
    "open mysession\n" +
    "ls\n" +
    "exit\n");
// wait until it finishes and collect its output
var output = exec.StdOut.ReadAll();
// optionally print the output
WScript.Echo(output);
XML parsing
// parse XML log file
var doc = new ActiveXObject("MSXML2.DOMDocument");
doc.async = false;
doc.load("log.xml");
doc.setProperty("SelectionNamespaces",
    "xmlns:w='http://winscp.net/schema/session/1.0'");
// look for file tags
var nodes = doc.selectNodes("//w:file");
WScript.Echo("There are " + nodes.length + " files and subdirectories:");
// list the files
for (var i = 0; i < nodes.length; ++i)
    var filename = nodes[i].selectSingleNode("w:filename/@value").value;
    WScript.Echo(filename);
There are 14 files and subdirectories:
.htaccess
commandline.txt
config.txt
directory_cache.txt
dragext.txt
faq.txt
faq_commandline.txt
faq_dir_default.txt
faq_download_temp.txt
faq_drag_move.txt
faq_error_code.txt
faq_filemanager.txt
See also guide to interpreting XML log for advanced scripting (uses C# language, though could be easily rewritten to JScript or VB script).
Hidden execution
When executing JScript code with cscript.exe, console window is shown. If you want to execute the JScript without showing console window, use wscript.exe instead.
Some notes for using wscript:
  • Every call to WScript.Echo causes message box to be shown, pausing the execution. So generaly you do not want to use WScript.Echo from wscript.exe (except maybe to report errors).
  • Execution of winscp.com opens new console window (if one is not opened already, e.g. by cscript.exe). Use winscp.exe instead (without /console switch). However winscp.exe does not allow input/output redirection, so you need to pass the commands in using command-line.
.NET (C# or VB.NET)
See guide to using WinSCP from .NET.
External script interpreters (PHP, Perl, etc)
Note that while you may find installing new scripting engine to Windows troublesome, you may not need to install anything actually. E.g. for using PHP interpreter, you can just grab the Windows binary PHP zip package and extract php.exe and php5ts.dll files out of it. These two binaries alone support most (if not all) features you need. No installing or registration is required.
Having the two binaries you can execute PHP script example.php:
system("winscp.com /script=example.txt", $exitcode);
if ($exitcode == 0)
    echo "success\n";
else
    echo "error\n";
    // handle an error
with simple command:
php.exe example.php
Further reading
