Advanced FTP/SFTP scripting
WinSCP .NET assembly mostly deprecates techniques demostrated in this article. Using the assembly is now preferred approach for advanced automation tasks with WinSCP.
- Choosing Language
- Windows script host (JScript or VB script)
- .NET (C# or VB.NET)
- External script interpreters (PowerShell, PHP, Perl, etc)
- Further reading
Choosing Language
cscript.exeorwscript.exe) to run Java Script or VB Script files.
- Conditional execution based on an exit code of an application or a value of an environment variable;
- An iteration over files matching a mask;
- Simple file path manipulation (extracting a directory from a path, extracting an extension, etc.).
It supports all the features listed in Windows command interpreter section above (with greater flexibility). Plus it includes many advanced functions, you may find useful when using together with WinSCP. See sections below.
To use the examples below copy the JScript code to file (e.g. example.js) and use cscript.exe to execute it (use /nologo to suppress banner):
cscript /nologo example.js
You can use WScript.Shell to execute WinSCP console interface tool and feed the script commands (using input stream), without creating temporary script file:
var shell = WScript.CreateObject("WScript.Shell"); // run (make it log to XML) var exec = shell.Exec("winscp.com /xmllog=log.xml"); // feed the commands exec.StdIn.Write( "option batch abort\n" + "open mysession\n" + "ls\n" + "exit\n"); // wait until it finishes and collect its output var output = exec.StdOut.ReadAll(); // optionally print the output WScript.Echo(output);
XML parsing
See also the guide Interpreting XML log for advanced scripting (uses C# language, though could be easily rewritten to JScript or VB script).
.NET (C# or VB.NET)
All versions of Windows since Windows XP have PowerShell available. With PowerShell, it is more convenient to use WinSCP .NET assembly, than the simple scripting. There are lot of examples of use of the WinSCP .NET assembly in PowerShell.
If you want to use your another favorite scripting language, but you do not have it on your Windows machine, you may find installing it troublesome. But you may not need to install anything actually. E.g. for using PHP interpreter, you can just grab the Windows binary PHP zip package and extract php.exe and php7ts.dll files out of it. These two binaries alone support most (if not all) features you need. No installing or registration is required.
Having the two binaries you can execute PHP script example.php:
with simple command:
php.exe example.php
Further reading
- Troubleshooting;
- WinSCP .NET assembly;
- Scripting documentation;
- Guide to automation;
- FAQ about scripting;
- Example scripts.
