Control '' has no parent window - Vcl::Forms::ValidParentForm
Goto page
1, 2, Next
sushreewill@...
WinSCP 5.6.4
[00AC3BCA] Vcl::Forms::ValidParentForm
Re: Control '' has no parent window
johan.Bergsma@...
I was scrolling upwards with the mouse wheel when i got the following error:
WinSCP 5.7.1
[00DD42DA] Vcl::Forms::ValidParentForm
pj.loton@...
use ctrl+F to find words... :evil:
WinSCP 5.7.1
[012842DA] Vcl::Forms::ValidParentForm
cs_tjaarda@...
WinSCP 5.7.1
[012642DA] Vcl::Forms::ValidParentForm
imon214@...
WinSCP 5.7.1
[002D42DA] Vcl::Forms::ValidParentForm
It closes when trying to scroll(middle button in the mouse) in Find window.
Please fix!!!!
Where is a mouse cursor located when you try to scroll?
Do you really scroll with some button? Or do you mean mouse wheel?
cb53311@...
WinSCP 5.7.1
[009F42DA] Vcl::Forms::ValidParentForm
lisa.nafeie@...
WinSCP 5.7.1
[004142DA] Vcl::Forms::ValidParentForm :(
iharnett@...
I tried to search a log file.
WinSCP 5.7.2
(001D34BE) Vcl::Forms::ValidParentForm
partizang249@...
WinSCP 5.7.2
Yığın izleme:
partizang249@...
WinSCP 5.7.2
Yığın izleme:
:cry:
tpsimple@...
WinSCP 5.7.2
Трассировка стека:
georgeboon4567@...
WinSCP 5.7.1
jorge.vgp@...
WinSCP 5.7.2
Re: Control '' has no parent window - Vcl::Forms::ValidParentForm
jtf_1@...
WinSCP 5.7.2
rgab77370@...
WinSCP 5.7.2
hans.unland@...
Hello All,
I simply opened a remote log-file using the internal WinSCP-editor. Then I searched the text (Ctrl-F) for specific words.
WinSCP 5.7.2
gitafanatic@...
I use the mouse wheel - the winscp close down with this error message:
(001D39EA) Vcl::Forms::ValidParentForm
WinSCP 5.7.3
jeremiah.benes@...
WinSCP 5.7.3
All I was doing was searching for a string in the default editor.
chenchn98@...
WinSCP 5.7.3
worldofjassi@...
WinSCP 5.7.3
Thanks for your reports.
I have sent you an email with a debug version of WinSCP to addresses you have used to register on this forum.
hadebe_s@...
WinSCP 5.7.3
contact@...
WinSCP 5.7.3
partizang249@...
WinSCP 5.7.3
Yığın izleme:
iuri.stanchev@...
WinSCP 5.7.3
didier@...
WinSCP 5.7.3
This error occurs when scrolling with the mouse into the viewer window.
The file was opened this way: right click on the remote file -> Open.
Connection protocol was SFTP.
It looks like the error occurs occasionally when doing a fast scroll using the mouse wheel.
dario@...
WinSCP 5.7.3
jason.harms@...
WinSCP 5.7.1
[014242DA] Vcl::Forms::ValidParentForm
xxjempoxx@...
WinSCP 5.7.3
sgondi@...
WinSCP 5.7.4
(001D3B5E) Vcl::Forms::ValidParentForm
sgondi@...
WinSCP 5.7.4
ralf.marxen@...
WinSCP 5.7.4
vladimir.mironov@...
WinSCP 5.7.4
seckin@...
WinSCP 5.7.4
Yığın izleme:
andrewimutch@...
Scrolled mouse while "Find" dialog box was open.
WinSCP 5.7.4
h_miranda@...
I was editing a file and crashed.
WinSCP 5.7.4
almere109@...
WinSCP 5.6.5
[01413C32] Vcl::Forms::ValidParentForm
Just a mouse scroll with a Microsoft mouse caused this
othmane.to.us@...
WinSCP 5.7.3
james.ra.crawford@...
WinSCP 5.7.5
(001D3DEE) Vcl::Forms::ValidParentForm
I was dearcjhing for a term on a remote file, the screen began to scroll and died - no logs appeared in Windows and couldnt see them elsewhere
rasaq.bello@...
Attempted to access one of opened files
WinSCP 5.7.5
pcotter@...
I was doing a search in a file I had opened. Screenshot attached
WinSCP 5.7.4
  • Capture.PNG (88.93 KB, Private file)
Description: Screenshot
nrshapiro@...
I had a remote file open in the editor, a CSS file. I was searching for OL . I might have accidentally hit the scroll on the mouse while it was up for the error to appear.
WinSCP 5.7.5
nrshapiro@...
I just did a find in the remote editor, then was trying to use the scroll wheel to scroll down.
WinSCP 5.7.5
benjamin.genter@...
WinSCP 5.7.5
gnomez.grave@...
Open a text file using the inbuilt editor. Open the Find window. Click on the text box and scroll (rotate the mouse wheel). Then this error is generated.
WinSCP 5.7.2
https://winscp.net/tracker/1353
saikrishnab4u@...
WinSCP 5.7.5
allorad@...
WinSCP 5.7
[0155424A] Vcl::Forms::ValidParentForm
opposite@...
WinSCP 5.7.3
(001D39EA)
I just scrolled opened .LESS document
dambrosioalfredo@...
WinSCP 5.7.4
vkanev@...
WinSCP 5.7.3
Used ctrl+f to find a string which was not available in the file
osamaejaz1@...
I just logged in to sftp. opened a .php file and used the find function to find a text. Just that. It gave error on 4rth time i pressed the Find button i guess
WinSCP 5.7.5
madnorbis@...
WinSCP 5.7.5
Трассировка стека:
reznikua@...
Rolling by mouse in viewer of text file
WinSCP 5.7.5
Трассировка стека:
dccharron@...
WinSCP 5.7.5
I was searching for the string <ul> in a php file. I moved the cursor to the top of the file and clicked on Find Next.
mgajewski@...
WinSCP 5.7.5
patrick.douret@...
WinSCP 5.7.4
Trace de la pile :
noemail@...
WinSCP 5.7.5
velinenirk@...
WinSCP 5.7.5
velinenirk@... wrote:
WinSCP 5.7.5
indichosts@...
WinSCP 5.7.5
noname@...
Searching upward clicking Find Next for the 2 digit string "64".
WinSCP 5.7.5
dadreng@gmail,com
WinSCP 5.7.5
When performing a find and replace (or at least it appears to be when I do this) when 'right-clicking' to open the dialogue box the page dies with the given message, often the entire application will close before I have the chnace to do anything else
WinSCP 5.7.5
jpoling@...
WinSCP 5.7.5
jpoling@...
It has to do with scrolling with a corded mouse. It is very annoying!
WinSCP 5.7.5
l.fumetti-levine@...
I was looking through a text file attached to a centos server. had looked for a specific common string and was clicking next rapidly to move through the file.
WinSCP 5.7.5
assennatog@...
WinSCP 5.7.5
cagordoneales@...
WinSCP 5.7.5
I opened up a file by double clicking it, I was scrolling down the page when this suddenly appeared and winscp closed
jankev@...
--> event occurs during sftp session whlie the intern winscp editor tries to save a edited file. <--
WinSCP 5.7.5
mayconfranca@...
WinSCP 5.7.5
info@...
WinSCP 5.7.5
Goto page
1, 2, Next
