Invalid access to memory - TRichEdit20::SetFormat
pavan.sadhu@...
WinSCP 5.7
Invalid access to memory.
[00AB4EBC] TRichEdit20::SetFormat
[77C2B466] ntdll.dll
[77BE012E] ntdll.dll.KiUserExceptionDispatcher
[00AB6DDD] TEditorForm::ApplyConfiguration
[003C7982] TEditorManager::ProcessFiles
Re: Invalid access to memory - TRichEdit20::SetFormat
gaurav008@...
WinSCP 5.7.5
(0074746C) TRichEdit20::SetFormat
(0006238A) ntdll.dll
(007493D9) TEditorForm::ApplyConfiguration
(00056E1A) TEditorManager::ProcessFiles
havocmafiagaming@...
WinSCP 5.7.6
(0074813C) TRichEdit20::SetFormat
(0008A52F) ntdll.dll
(00077DAA) ntdll.dll.KiUserExceptionDispatcher
(0074A0A9) TEditorForm::ApplyConfiguration
(00056E2E) TEditorManager::ProcessFiles
havocmafiagaming@... wrote:
WinSCP 5.7.6
rkarthick2006@...
WinSCP 5.7.5
(0003F07E) ntdll.dll.ZwWow64CallFunction64
(0003F7FA) ntdll.dll.KiUserExceptionDispatcher
alokranjancs@...
WinSCP 5.8.3
(007A2DC4) TRichEdit20::SetFormat
(00062496) ntdll.dll
(007A4CEC) TEditorForm::ApplyConfiguration
(00061682) TEditorManager::ProcessFiles
chandrancpk@...
WinSCP 5.7.6
danielpozuelo1@...
WinSCP 5.7.6
(0074813C)
(00045A86) ntdll.dll
(0074A0A9)
(00056E2E)
marvinody@...
WinSCP 5.7.7
(00748CB8) TRichEdit20::SetFormat
(0005A5DA) ntdll.dll
(0074AC25) TEditorForm::ApplyConfiguration
david@...
the last two releases of WinSCP have been 'buggy' / many memory errors like this - I really do not know why you are "fixing what a'int broke" ..
I am reporting this but probably will uninstall go back two clicks and turn off updates
do not want contacting ! or will use FileZilla again
WinSCP 5.9.2
(007B2374) TRichEdit20::SetFormat
(000461C6) ntdll.dll.RtlRaiseStatus
(00046052) ntdll.dll.KiUserExceptionDispatcher
(007B42A0) TEditorForm::ApplyConfiguration
(00061CE2) TEditorManager::ProcessFiles
iam@...
WinSCP 5.9.2
(0008137F) ntdll.dll
(0006EF1A) ntdll.dll.KiUserExceptionDispatcher
arjunmeda025@...
WinSCP 5.9.3
(007B4898) TRichEdit20::SetFormat
(000624F6) ntdll.dll
(007B67C4) TEditorForm::ApplyConfiguration
(00061E7A) TEditorManager::ProcessFiles
alvarors@...
Acceso a memoria no válido - TRichEdit20::SetFormat
WinSCP 5.9.3
Traza de la pila:
(00081D3F) ntdll.dll
ananth2509@...
WinSCP 5.9.3
hank@...
This seems to be happening every time I click on new session and try to login to one of my saved sites. If I hit ok and redo the attempt to the same site, it works the second time. If I change sites, I get the error again.
I assume a reboot of either WinSCP or my PC would fix it, but I wanted to submit the report just in case it helps track down a nuisance bug.
WinSCP 5.9.6
(007B6740) TRichEdit20::SetFormat
(00088D5F) ntdll.dll
(0006FC11) ntdll.dll.KiUserExceptionDispatcher
(007B8710) TEditorForm::ApplyConfiguration
(00061F4A) TEditorManager::ProcessFiles
