Cannot change Visible in OnShow or OnHide - Vcl::Forms::TCustomForm::CMShowingChanged
Goto page
1, 2, 3, Next
info@...
WinSCP 5.9.1
(0020CAD0) Vcl::Forms::TCustomForm::CMShowingChanged
(00022C5F) TCustomScpExplorerForm::CMShowingChanged
(00022BD4) TCustomScpExplorerForm::Dispatch
(0024EA59) Vcl::Controls::TWinControl::WndProc
(00208F08) Vcl::Forms::TCustomForm::WndProc
(008082B5) Vclcommon::C2754_0
(00249B50) Vcl::Controls::TControl::Perform
(0024DE49) Vcl::Controls::TWinControl::UpdateShowing
(0024DF58) Vcl::Controls::TWinControl::UpdateControlState
(0024DCEF) Vcl::Controls::TWinControl::CMRecreateWnd
(00022BE8) TCustomScpExplorerForm::Dispatch
(008083DC) Vclcommon::C2754_0
(0024DCAA) Vcl::Controls::TWinControl::RecreateWnd
(00047338) TScpExplorerForm::RestoreFormParams
(00250AFE) Vcl::Controls::TWinControl::CMVisibleChanged
satownchevy@...
I believe this happened because I had to force a computer shutdown and winscp was still running. It kept trying to reconnect even though the machine had no connection so it was still open during the shutdown with reconnect messages. This message popped up after the reboot, I closed winscp since it did not have the login screen up and reopened it and started just fine.
WinSCP 5.9.2
(0020CCA0) Vcl::Forms::TCustomForm::CMShowingChanged
(00022A9F) TCustomScpExplorerForm::CMShowingChanged
(00022A14) TCustomScpExplorerForm::Dispatch
(0024EC29) Vcl::Controls::TWinControl::WndProc
(002090D8) Vcl::Forms::TCustomForm::WndProc
(008093C5) Vclcommon::C2754_0
(00249D20) Vcl::Controls::TControl::Perform
(0024E019) Vcl::Controls::TWinControl::UpdateShowing
(0024E128) Vcl::Controls::TWinControl::UpdateControlState
(0024DEBF) Vcl::Controls::TWinControl::CMRecreateWnd
(00022A28) TCustomScpExplorerForm::Dispatch
(008094EC) Vclcommon::C2754_0
(0024DE7A) Vcl::Controls::TWinControl::RecreateWnd
(00047274) TScpExplorerForm::RestoreFormParams
(00250CCE) Vcl::Controls::TWinControl::CMVisibleChanged
arni64@...
Problem occurs every time when trying to synchronize folders on WinSCP 5.10 beta (did work on previous version). It does not occur when synchronizing identical folders - only when there's something to sync. After dismissing error window, sync checklist appears empty.
Let me know if you need any additional info. Thanks!
WinSCP 5.10
(00215B14) Vcl::Forms::TCustomForm::CMShowingChanged
(00834B88) TSynchronizeChecklistDialog::Dispatch
(00257A85) Vcl::Controls::TWinControl::WndProc
(00211F4C) Vcl::Forms::TCustomForm::WndProc
(008385B4) Vclcommon::C2749_0
dick@...
WinSCP 5.10
vince.banes@...
WinSCP 5.10
w-insc-p@...
Whenever I try to synchronize from remote to local, this message appears. Afterwards, the synchronization list is shown but it's empty (while there are obvious differences between local and remote).
WinSCP 5.10
Re: Cannot change Visible in OnShow or OnHide - Vcl::Forms::TCustomForm::CMShowingChanged
Thanks for your reports.
https://winscp.net/tracker/1539
wendell@...
All I do is try to run WinSCP and get this error. Cannot open and use WinSCP at all.
WinSCP 5.10.1
(00215B8C) Vcl::Forms::TCustomForm::CMShowingChanged
(00023377) TCustomScpExplorerForm::CMShowingChanged
(0002323A) TCustomScpExplorerForm::Dispatch
(00257AFD) Vcl::Controls::TWinControl::WndProc
(00211FC4) Vcl::Forms::TCustomForm::WndProc
(00838728) Vclcommon::C2749_0
alexandr_lykhin@...
WinSCP 5.10.4
(00215BE8) Vcl::Forms::TCustomForm::CMShowingChanged
(00023383) TCustomScpExplorerForm::CMShowingChanged
(00023246) TCustomScpExplorerForm::Dispatch
(00257B59) Vcl::Controls::TWinControl::WndProc
(00212020) Vcl::Forms::TCustomForm::WndProc
(0083B7A8) Vclcommon::C2751_0
alexandr_lykhin@...
WinSCP 5.10.1
wendell@...
All I'm trying to do is run WinSCP. This error comes up, I click OK, and then I just get a blank WinSCP window. So it's completely unusable at this point. :-(
WinSCP 5.11
(00215BD0) Vcl::Forms::TCustomForm::CMShowingChanged
(0002336B) TCustomScpExplorerForm::CMShowingChanged
(0002322E) TCustomScpExplorerForm::Dispatch
(00257B41) Vcl::Controls::TWinControl::WndProc
(00212008) Vcl::Forms::TCustomForm::WndProc
(0083B790) Vclcommon::C2751_0
brian@...
WinSCP 5.11.1
(00215C30) Vcl::Forms::TCustomForm::CMShowingChanged
(00257BA1) Vcl::Controls::TWinControl::WndProc
(00212068) Vcl::Forms::TCustomForm::WndProc
(0083B8E0) Vclcommon::C2751_0
ttt@...
WinSCP 5.11.1
brian@... wrote:
WinSCP 5.11.1
it-info@...
WinSCP 5.11.1
jenoszalai@...
WinSCP 5.11.1
info@...
WinSCP 5.11.1
Bryce.Rakop@...
Immediately occurs upon launch, and result seems to be the file listing (both remote and local) are permanently hidden. Even if I connect to a session I can't see any file icons for initiating transfers.
The odd part is I haven't done any new install or update that I know of that would've caused this problem. It just started out of the blue.
WinSCP 5.11.1
esamiuyanik@...
When i start, i saw this error and when i tried to start a session, i cant see directory list.
WinSCP 5.11
lars@...
When I start the program it gives this error.
Only difference with last start up is that winscp was displayed on a second screen previous time and now i dont have a second screen connected.
WinSCP 5.11.1
kratochvil-petr@...
Everytime I open WinSCP
WinSCP 5.11.1
miyaharakoji@...
WinSCP 5.11.2
スタック トレース:
(00215D14) Vcl::Forms::TCustomForm::CMShowingChanged
(0002336F) TCustomScpExplorerForm::CMShowingChanged
(00023232) TCustomScpExplorerForm::Dispatch
(00257C85) Vcl::Controls::TWinControl::WndProc
(0021214C) Vcl::Forms::TCustomForm::WndProc
(0083BA40) Vclcommon::C2751_0
fw9xu5f9lq2i4czt6tl2@...
WinSCP 5.11.2
StefanUser
Workaround in WinSCP.ini
I also got the error message "Cannot change Visible in OnShow or OnHide" directly after starting WinSCP.
To workaround this, I deleted the following section from WinSCP.ini:
[Configuration\Interface\Commander]
ToolbarsLayout=...
Now WinSCP starts again without the error message.
I hope this helps some of you.
Regards
Stefan
noelman@...
WinSCP 5.11.2
fredrik.jakobsson@...
The problem occurs when starting WinSCP
WinSCP 5.11.2
Stackspår:
c.boyce@...
Once I have established a session I dont not get any files on the right hand panel. Note that I am in explorer view mode. This issue has occurred since the last update was applied
WinSCP 5.11.2
mellezwerver@...
I get this error everytime i open winscp.
WinSCP 5.11.2
david.wedge@...
This occurs whenever I start up WINSCP
WinSCP 5.11.2
sjholderman@...
Happens immediately on start up
WinSCP 5.11.2
todd.hubers@...
WinSCP 5.11.2
hashashin@...
WinSCP 5.11.2
joseph.ciecior@...
This issue happens consistently on application load. This issue appears to coincide with the installation of Docker/Hyper-V on my Windows 10 system. If I click through the error I can create sessions, but I cannot view any of the files; either locally or on the connected machine.
WinSCP 5.11.2
math0ne@...
WinSCP 5.11.2
WinSCP 5.11.2
markus.spaethling@...
WinSCP 5.11.2
(00215D14)
(0002336F)
(00023232)
(00257C85)
(0021214C)
(0083BA40)
ste.ona5@...
WinSCP 5.11.1
Always opens, when starting the program. After reinstall works once. Then second time occurs the error message
WinSCP 5.11.2
karl.rosentrater@...
all I did was try to open the application.
WinSCP 5.11.2
markus.spaethling@... wrote:
WinSCP 5.11.2
(00215D14)
(0002336F)
(00023232)
(00257C85)
(0021214C)
(0083BA40)
aoxing.liu@...
WinSCP 5.11.1
WinSCP 5.11.2
https://winscp.net/tracker/1576
raewe
version 5.11.2 cannot change visible...
mario.cerciello@...
WinSCP 5.17.4
(00237E84) Vcl::Forms::TCustomForm::CMShowingChanged
(000281C3) TCustomScpExplorerForm::CMShowingChanged
(00028052) TCustomScpExplorerForm::Dispatch
(00279DF5) Vcl::Controls::TWinControl::WndProc
(002342BC) Vcl::Forms::TCustomForm::WndProc
(00E4137C) Vclcommon::C2992_0
itdontwant@...
On each start: Cannot change Visible in OnShow or OnHide - Vcl::Forms::TCustomForm::CMShowingChanged
On each start of the App I get the following error.
I'm using Windows 10 Enterprise Edition.
WinSCP 5.17.4
yodayodaspace@...
WinSCP 5.17.4
Трассировка стека:
gpuchi@...
WinSCP 5.17.4
Traza de la pila:
v-sijeff@...
I started WinSCP from the start menu for the first time after installing it.
WinSCP 5.17.4
jpozzoli@...
After installing, left the "Launch WinSCP" button checked in the installer. This is what came up.
This also happens each time I launch the app manually (clicking on the icon in the start menu).
Clicking "OK" on the error brings me into the app.
Win10 x64, 10.0.18363 Build 18363
Ryzen 7, 2700, 16GB RAM
WinSCP 5.17.4
kara.stanicic@...
WinSCP 5.17.4
nobody@...
WinSCP 5.17.4
kaweresimonpeter.com
current version crashes upon opening it after installation.
WinSCP 5.17.4
dkuandyk99@...
WinSCP 5.17.4
Трассировка стека:
dhirst@...
WinSCP 5.17.4
dave.arduini@...
Issue occurs on Launch of 64-bit version installed using .exe from winscp.net
WinSCP 5.17.4
tibaraskar@...
WinSCP 5.17.4
duttasubirnipa@...
WinSCP 5.17.4
mubarakalsulaiti03@...
WinSCP 5.17.4
dangerously@...
WinSCP 5.17.4
driss.hadi@...
WinSCP 5.17.4
bond@...
WinSCP 5.17.4
test@...
WinSCP 5.17.4
ltaylor@...
On first launch of newly downloaded binary
WinSCP 5.17.4
lonphil1@...
WinSCP 5.17.4
georg_baker@...
new Installation and this happens every time on launch.
WinSCP 5.17.4
1204177652c@...
WinSCP 5.17.4
tp1012@...
WinSCP 5.17.4
スタック トレース:
docfaz@...
WinSCP 5.17.4
truongduchanh.tm@...
WinSCP 5.17.4
alan4d@...
WinSCP 5.17.4
**** I get this as soon as I try to open the software. Im on W10
theamner@...
WinSCP 5.17.4
mhhooper@...
WinSCP 5.17.4
dkaur@...
WinSCP 5.17.4
danilo@...
WinSCP 5.17.4
Rastreamento de pilha:
oareago@...
WinSCP 5.17.4
slizmo@...
WinSCP 5.17.4
araragino@...
WinSCP 5.17.4
chickennuggetcrazykid@...
WinSCP 5.17.4
dipakguharay@...
WinSCP 5.17.4
416M106@...
WinSCP 5.17.4
スタック トレース:
trading@...
WinSCP 5.17.4
johnson@...
WinSCP 5.17.4
Stack 追蹤:
a_zhivotov@...
WinSCP 5.17.4
Трассировка стека:
4toasthax@...
WinSCP 5.17.4
darrell.rinehart@...
This happens every time I start WinSCP. I cannot interact with the remote panel once it is opened.
WinSCP 5.17.4
nganbuinguyen123@...
WinSCP 5.17.4
johannes.severini@...
I start the program and it says this. I don't know how to fix it. It has said this seven times in a row now. I can neither actually do something in the remote server thing. It is crashed.
WinSCP 5.17.4
gfs225@...
WinSCP 5.17.4
dylan.maree@...
I can't run WinSCP at all. Gives many errors, then starts but nothing really works. If i try anything i get more errors.
I'll search other ways to get the remote file locally.
WinSCP 5.17.4
Goto page
1, 2, 3, Next
