Deletion of Second File on Remote Server when Dragging and Dropping the other file
Mike Valente
Tyne & Wear
Hi
I have had this situation more than once.
There are two files on the remote server.
I select one of the files, together with the Shift key pressed, Drag and drop that selected file to a local directory but then the other (second file) is automatically deleted without any request to do so.
Which is really irritating :)
Log file attached.
  • log.txt (3.46 KB, Private file)
