Invalid access to memory - _log_proxy_stderr
anchous039@...
The problem occurs when winscp tries to reconnect after connection was broken: Internet connection lost or when notebook went into sleep mode and was woken up.
Closing program an starting new instance helps, of course, but this procedure involves closing all the files which were opened at the moment.
PS I do not really wish to be contacted by the WinSCP team to help resolving the problem. It's just for you to know, in case it can be helpful
WinSCP 5.9.5
Invalid access to memory.
(0060F5DF) _log_proxy_stderr
(0086700E) C5073_3
(00869076) ____ExceptionHandler
(00865E30) __ExceptionHandler
(00081D3F) ntdll.dll
(00649916) C2501_0
(006497BA) _handle_got_event
(006FF523) TSecureShell::EventSelectLoop
(006FE75B) TSecureShell::WaitForData
(006F9B65) TSecureShell::Init
(006F943A) TSecureShell::Open
(0077055A) TTerminal::Open
(006C91FF) TTerminalThread::TerminalOpenEvent
(006C41D4) TSignalThread::Execute
(00098BA3) Userinterface::C20_0
(000152C2) KERNEL32.DLL.BaseThreadInitThunk
(0005FFD7) ntdll.dll
(0005FF9F) ntdll.dll
(00867679) C5073_3
(00868C53) _ReThrowException
(006F9C73) TSecureShell::Init
(00867679) C5073_3
(006F9D0E) TSecureShell::Init
(00867679) C5073_3
(006F9528) TSecureShell::Open
(0077055A) TTer
fanfei.clark@...
WinSCP 5.9.5
(0086700E) C5073_3
(00649916) C2501_0
(006FFA69) TSecureShell::Idle
(0076F72F) TTerminal::Idle
(0008EEF0) TTerminalManager::Idle
(00016C9F) TCustomScpExplorerForm::Idle
(0003D057) TNonVisualDataModule::DoIdle
(0003D014) TNonVisualDataModule::SessionIdleTimerTimer
(0037326C) System::Classes::_18201
(0002C2B1) USER32.dll
(0000D885) USER32.dll
(0000D1DF) USER32.dll
(0000CF9B) USER32.dll.DispatchMessageW
(00867679) C5073_3
(0008EF35) TTerminalManager::Idle
boristim@...
Ошибка доступа к памяти - _log_proxy_stderr
WinSCP 5.11.2
Ошибка доступа к памяти.
Трассировка стека:
(00627407) _log_proxy_stderr
(0089C9C2) C5067_3
(0089EA2A) ____ExceptionHandler
(0089B7E4) __ExceptionHandler
(00062496) ntdll.dll
(00661A76) C2503_0
(00661912) _handle_got_event
(0071AD03) TSecureShell::EventSelectLoop
(00719F33) TSecureShell::WaitForData
(007150C5) TSecureShell::Init
(0071499A) TSecureShell::Open
(00759E5F) TSFTPFileSystem::Open
(007981FF) TTerminal::Reopen
(006E2A69) TTerminalThread::TerminalReopenEvent
(006DDBC4) TSignalThread::Execute
(000A0D93) Userinterface::C20_0
(00012368) kernel32.dll.BaseThreadInitThunk
(000388F0) ntdll.dll
(000388C0) ntdll.dll
(0089D02D) C5067_3
(0089E607) _ReThrowException
(007151D3) TSecureShell::Init
(0089D02D) C5067_3
(0071526E) TSecureShell::Init
(006DDBC4)%
Re: Ошибка доступа к памяти - _log_proxy_stderr
I was sent a report by email.
The problem occurs when winscp tries to reconnect after connection was broken: Notebook went into sleep mode, and was woken up in another wifi network.
2018.gt@...
WinSCP 5.11.3
(006279BB) _log_proxy_stderr
(0089D34A) C5067_0
(0089F3B2) ____ExceptionHandler
(0089C16C) __ExceptionHandler
(000851DF) ntdll.dll
(0066202A) C2503_0
(00661EC6) _handle_got_event
(0071B307) TSecureShell::EventSelectLoop
(0071B84D) TSecureShell::Idle
(00795DEB) TTerminal::Idle
(00096CA0) TTerminalManager::Idle
(00017207) TCustomScpExplorerForm::Idle
(0003DCDF) TNonVisualDataModule::DoIdle
(0003DC9C) TNonVisualDataModule::SessionIdleTimerTimer
(0037BCBC) System::Classes::_18201
(00031F89) USER32.dll
(0002443E) USER32.dll
(00023DCD) USER32.dll
(00023B9B) USER32.dll.DispatchMessageW
(0089D9B5) C5067_0
(0089EF8F) _ReThrowException
(00096CE5) TTerminalManager::Idle
Florian.P.Nierhaus@...
I get this regularly with this version - I assume when the connection times out and I try to refresh later.
WinSCP 5.11.3
(0089D34A) C5067_0
(00088D2F) ntdll.dll
(0006FBF1) ntdll.dll.KiUserExceptionDispatcher
(0066202A) C2503_0
(0071A537) TSecureShell::WaitForData
(007156C9) TSecureShell::Init
(00714F9E) TSecureShell::Open
(00796C16) TTerminal::Open
(006E3013) TTerminalThread::TerminalOpenEvent
(006DE17C) TSignalThread::Execute
(000A0DD7) Userinterface::C20_0
(00017652) KERNEL32.DLL.BaseThreadInitThunk
(00063A45) ntdll.dll.RtlGetAppContainerNamedObjectPath
(00063A12) ntdll.dll.RtlGetAppContainerNamedObjectPath
(0089D9B5) C5067_0
(007157D7) TSecureShell::Init
(0089D9B5) C5067_0
(00715872) TSecureShell::Init
(0089D9B5) C5067_0
(0071508C) TSecureShell::Open
(0089D9B5) C5067_0
(00796DAB) TTerminal::Open
(0089D9B5) C5067_0
(00797309) TTerminal::Open
Re: Invalid access to memory - _log_proxy_stderr
