Invalid access to memory - System::Classes::TComponent::FindComponent
julian@...
WinSCP 5.14
Invalid access to memory.
(003961F6) System::Classes::TComponent::FindComponent
(008F9532) C5107_0
(008FB59A) ____ExceptionHandler
(008F8354) __ExceptionHandler
(0008341F) ntdll.dll
(000711F1) ntdll.dll.KiUserExceptionDispatcher
(00028B60) TCustomScpExplorerForm::AddSessionColor
(0001F284) TCustomScpExplorerForm::DoTerminalListChanged
(000060AA) TCustomScpExplorerForm::TerminalChanged
(00005F92) TCustomScpExplorerForm::DoSetTerminal
(00005F42) TCustomScpExplorerForm::SetTerminal
(00049ACA) TScpCommanderForm::~TScpCommanderForm
(000F6C03) Execute
(000024FC) wWinMain
(008F7569) C4975_0
(0006507B) ntdll.dll.RtlGetAppContainerNamedObjectPath
(00065048) ntdll.dll.RtlGetAppContainerNamedObjectPath
rarnold@...
Dear all, nothing special done: open a session, moving to the target remote directory and local directory; afterwards downloading a WIndows .Net executable file. I would say a typcial standard situation in terms of how to use WinSCP. Regards Ronald
WinSCP 5.14
(008F9532) C5107_0
(000F6C03) Execute
(000024FC) wWinMain
(008F7569) C4975_0
(00137FF0)
(008F9532) C5107_0
(008FA3EB) C5107_0
(008FB3E1) ____ExceptionHandler
(008F94C2) ___doGlobalUnwind
(008FB6AE) ____ExceptionHandler
(000F6C03) Execute
(000024FC) wWinMain
(008F7569) C4975_0
michal@...
Chyba přístupu do paměti - System::Classes::TComponent::FindComponent
Long run WinSCP exception on close. The same as yesterday.
WinSCP 5.14
Chyba přístupu do paměti.
(008F9532) C5107_0
(0007DAFF) ntdll.dll
(000F6C03) Execute
(000024FC) wWinMain
(008F7569) C4975_0
(00062058) ntdll.dll.RtlValidSecurityDescriptor
(00062025) ntdll.dll.RtlValidSecurityDescriptor
jkellgren@...
I was interrupted a couple of times during my session with the external server, but able to rectify by relogging in again. The error below showed up as the point that I close the WinSCP session when I was done.
WinSCP 5.14
(008F9532) C5107_0
(000F6C03) Execute
(000024FC) wWinMain
(008F7569) C4975_0
ahmeda10@...
-Connected to server.
-attempted to close program down.
-Crash.
WinSCP 5.14
(008F9532) C5107_0
(000851DF) ntdll.dll
(000F6C03) Execute
(000024FC) wWinMain
(008F7569) C4975_0
(0006482B) ntdll.dll.RtlGetAppContainerNamedObjectPath
(000647F8) ntdll.dll.RtlGetAppContainerNamedObjectPath
sasho.new@...
It's simple enough. I've just installed this version and crash happens after I closed WinSCP. My PC was "waken-up" not rebooted if this might be important. I'll let you know if crash persists...
WinSCP 5.14
(008F9532) C5107_0
(00051C17) TScpExplorerForm::~TScpExplorerForm
(000F6C03) Execute
(000024FC) wWinMain
(008F7569) C4975_0
Re: Invalid access to memory - System::Classes::TComponent::FindComponent
Thanks for your reports.
https://winscp.net/tracker/1693
I'm sending you an email with a development version of WinSCP to the addresses you have used to register on this forum.
kilian.frey@...
Opening a connection from the shortcut-menu on Windows 10 taskbar when said connection has a background-color causes fatal crash.
Works as expected, if the application is already open.
WinSCP 6.0
(002121AA) System::Classes::TComponent::FindComponent
(00087B7F) ntdll.dll
(0002DCBC) TCustomScpExplorerForm::AddSessionColor
(0002347E) TCustomScpExplorerForm::SessionListChanged
(00030CD3) TCustomScpExplorerForm::SessionsPageControlResize
(003F4F51) Vcl::Controls::TWinControl::WndProc
(003F4598) Vcl::Controls::TWinControl::MainWndProc
(00213A0C) System::Classes::_18201
(00040239) USER32.dll
(000371F5) USER32.dll
(00036DF5) USER32.dll
(0003A9BD) USER32.dll
(00073FBB) ntdll.dll.KiUserCallbackDispatcher
(00034C1A) USER32.dll.SendMessageW
(00421F21) Vcl::Comctrls::TCustomTabControl::TabsChanged
(00423562) Vcl::Comctrls::TPageControl::UpdateTab
(00422A19) Vcl::Comctrls::TTabSheet::CMTextChanged
(003F0048) Vcl::Controls::TControl::Perform
(003EDEA1) Vcl::Controls::TControl::SetTextBuf
(00C8FA4F) TThemeTabSheet::UpdateCaption
(00C8F7C7) TThemeTabSheet::SetBaseCaption
(000236F5) TCustomScpExplorerForm::UpdateNewTabTab
(0002E0C2) TCustomScpExplorerForm::UpdateToolbarDisplayMode
nlgroup@...
WinSCP 6.0
(002121AA)
(00062496) ntdll.dll
(0002DCBC)
(0002347E)
(00030CD3)
(003F4F51)
(003F4598)
(00213A0C)
(000152F7) USER32.dll
(00015D35) USER32.dll
(00015DE8) USER32.dll
(00015E49) USER32.dll
(0000F117) ntdll.dll.KiUserCallbackDispatcher
(000186D0) USER32.dll.SendMessageW
(00421F21)
(00423562)
(00422A19)
(003F4F51)
(003F0048)
(003EDEA1)
(00C8FA4F)
(00C8F7C7)
(000236F5)
(0002E0C2)
@kilian.frey and @nlgroup: Thanks for your reports.
eb@...
WinSCP 6.2.1
(00223F92) System::Classes::TComponent::FindComponent
(00087A7F) ntdll.dll
(0002F328) TCustomScpExplorerForm::AddSessionColor
(00024875) TCustomScpExplorerForm::SessionListChanged
(0000A417) TCustomScpExplorerForm::ConfigurationChanged
(0000AC56) TCustomScpExplorerForm::RestoreParams
(00057B02) TScpCommanderForm::TScpCommanderForm
(003CB762) Vcl::Forms::TApplication::CreateForm
(00D240CB) _SafeFormCreate
(0000318F) wWinMain
(00E1B161) __wstartup
(00066C6C) ntdll.dll.RtlGetAppContainerNamedObjectPath
(00066C39) ntdll.dll.RtlGetAppContainerNamedObjectPath
(00E1D412) C6608_0
(00E1F47A) ____ExceptionHandler
(00E1C234) __ExceptionHandler
(0000318F) wWinMain
@eb: Thanks for your report.
