List index out of bounds (4) - TScpCommanderForm::DoRemotePathComboBoxAdjustImageIndex
gerhard.pobinger@...
WinSCP 6.0.1
(001FAACD) System::Classes::TStringList::GetObject
(0005F10B) TScpCommanderForm::DoRemotePathComboBoxAdjustImageIndex
(0002CBCA) TCustomScpExplorerForm::RemotePathComboBoxAdjustImageIndex
(004EF95F) Tbxextitems::TTBXComboBoxItem::AdjustImageIndex
(004EFD42) Tbxextitems::TTBXComboBoxItem::GetImageIndex
(004D2C03) Tb2item::TTBView::DrawItem
ralf.wieler@...
List index out of bounds (9) - TScpCommanderForm::DoRemotePathComboBoxAdjustImageIndex
After termination of the last session, the error-message poped up. Clicking 'ok' will close the popup and normal termination of winscp follows.
WinSCP 6.1.1
Stapelverfolgung:
(001FBC21) System::Classes::TStringList::GetObject
(0005FA7F) TScpCommanderForm::DoRemotePathComboBoxAdjustImageIndex
(0002D322) TCustomScpExplorerForm::RemotePathComboBoxAdjustImageIndex
(004F0BF7) Tbxextitems::TTBXComboBoxItem::AdjustImageIndex
(004F0FDA) Tbxextitems::TTBXComboBoxItem::GetImageIndex
(004D3E9B) Tb2item::TTBView::DrawItem
alexandru.stefan55@...
List index out of bounds (5) - TScpCommanderForm::DoRemotePathComboBoxAdjustImageIndex
WinSCP 6.1.1
info@...
List index out of bounds (8) - TScpCommanderForm::DoRemotePathComboBoxAdjustImageIndex
WinSCP 6.1.1
Stapelverfolgung:
sekiya@...
WinSCP 6.1.1
スタック トレース:
mvitt@...
I closed an open connection to a VM - first time this has happened. Will try update if one is available,
Thank you,
Mark
WinSCP 6.1
(001FBBBD) System::Classes::TStringList::GetObject
(0005FA4F) TScpCommanderForm::DoRemotePathComboBoxAdjustImageIndex
(0002D2F2) TCustomScpExplorerForm::RemotePathComboBoxAdjustImageIndex
(004F0B93) Tbxextitems::TTBXComboBoxItem::AdjustImageIndex
(004F0F76) Tbxextitems::TTBXComboBoxItem::GetImageIndex
(004D3E37) Tb2item::TTBView::DrawItem
Re: List index out of bounds (5) - TScpCommanderForm::DoRemotePathComboBoxAdjustImageIndex
@sekiya: Thanks for your report.
programmatore1.weasy@...
WinSCP 6.1.1
@programmatore1.weasy: Thanks for your report.
fabiola.citrangolo@...
<Try to describe precise steps that lead to the problem (where do you click, what keys do you press, what do you see, etc.)> I moved from the tab in the ssh to the tab in my computer (only by clicking)
WinSCP 6.1.1
Trace de la pile :
info@...
I closed the connection with the shortcut cmd+w ... Afterthat this error occurs.
WinSCP 6.2
Stapelverfolgung:
(0020C26D) System::Classes::TStringList::GetObject
(000612AF) TScpCommanderForm::DoRemotePathComboBoxAdjustImageIndex
(0002E1CE) TCustomScpExplorerForm::RemotePathComboBoxAdjustImageIndex
(0050240F) Tbxextitems::TTBXComboBoxItem::AdjustImageIndex
(005027F2) Tbxextitems::TTBXComboBoxItem::GetImageIndex
(004E56B3) Tb2item::TTBView::DrawItem
florianf.97@...
WinSCP 6.1.2
Stapelverfolgung:
(001FC4D5) System::Classes::TStringList::GetObject
(0005FAE7) TScpCommanderForm::DoRemotePathComboBoxAdjustImageIndex
(004F14AB) Tbxextitems::TTBXComboBoxItem::AdjustImageIndex
(004F188E) Tbxextitems::TTBXComboBoxItem::GetImageIndex
(004D474F) Tb2item::TTBView::DrawItem
Re: List index out of bounds (4) - TScpCommanderForm::DoRemotePathComboBoxAdjustImageIndex
@florianf.97: Thanks for your report.
tamura@...
List index out of bounds (6) - TScpCommanderForm::DoRemotePathComboBoxAdjustImageIndex
WinSCP 6.1.2
スタック トレース:
user@...
List index out of bounds (7) - TScpCommanderForm::DoRemotePathComboBoxAdjustImageIndex
WinSCP 6.1.2
スタック トレース:
WinSCP 6.3.1
(0020D5E9) System::Classes::TStringList::GetObject
(0006163F) TScpCommanderForm::DoRemotePathComboBoxAdjustImageIndex
(0002E2BA) TCustomScpExplorerForm::RemotePathComboBoxAdjustImageIndex
(0050379F) Tbxextitems::TTBXComboBoxItem::AdjustImageIndex
(00503B82) Tbxextitems::TTBXComboBoxItem::GetImageIndex
(004E6A43) Tb2item::TTBView::DrawItem
aswiss904@...
Closed the open connection with the shortcut: cmd + w
WinSCP 6.3.2
(0020DE11) System::Classes::TStringList::GetObject
(00503FF3) Tbxextitems::TTBXComboBoxItem::AdjustImageIndex
(005043D6) Tbxextitems::TTBXComboBoxItem::GetImageIndex
(004E7297) Tb2item::TTBView::DrawItem
Re: List index out of bounds (8) - TScpCommanderForm::DoRemotePathComboBoxAdjustImageIndex
@aswiss904: Thanks for your report.
