Transfer was successfully finished, but temporary transfer file 'login.log-20240908.filepart' could not be renamed to target file name 'login.log-20240908'. If the problem persists, you may try to turn off transfer resume support - ___CPPdebugHook_segment
Ousmanou75@...
WinSCP 6.3.3
Transfer was successfully finished, but temporary transfer file 'login.log-20240908.filepart' could not be renamed to target file name 'login.log-20240908'. If the problem persists, you may try to turn off transfer resume support.
Invalid access to memory.
(00E2A0AC) ___CPPdebugHook_segment
(00E2235E) C6610_3
(00E243C6) ____ExceptionHandler
(00E21180) __ExceptionHandler
(00087A6F) ntdll.dll
(000740C1) ntdll.dll.KiUserExceptionDispatcher
(00C80196) TTerminal::Sink
(00C7EE94) TTerminal::SinkRobust
(00C7ECBC) TTerminal::DoCopyToLocal
(00C4B646) TSFTPFileSystem::CopyToLocal
(00C7E7AE) TTerminal::CopyToLocal
(0001206D) TCustomScpExplorerForm::ExecuteCopyMoveFileOperation
(00012B5C) TCustomScpExplorerForm::ExecuteFileOperation
(000269FB) TCustomScpExplorerForm::RemoteFileControlFileOperation
(00026E31) TCustomScpExplorerForm::RemoteFileControlDDEnd
(0048F29E) Customdirview::TCustomDirView::DDDragDetect
(00AE9B4A) TUnixDirView::DDDragDetect
(0048B42E) Customdirview::TCustomDirView::CNNotify
(00404951) Vcl::Controls::TControl::WndProc
(00409495) Vcl::Controls::TWinControl::WndProc
(0044C76F) Vcl::Comctrls::TCustomListView::WndProc
(004095FB) Vcl::Controls::_17076
(00408ADC) Vcl::Controls::TWinControl::MainWndProc
(002271BC) System::Classes::_18201
(000402B9) USER32.dll
(00036A55) USER32.dll
(00036655) USER32.dll
(0003AB5D) USER32.dll
(00034D4A) USER32.dll.SendMessageW
(00068881) COMCTL32.DLL
(0019EF20) COMCTL32.DLL
(000A3E60) COMCTL32.DLL
(000648A2) COMCTL32.DLL
(00036211) USER32.dll.GetSystemMetricsForDpi
(00034A06) USER32.dll.CallWindowProcW
(004095A6) Vcl::Controls::TWinControl::DefaultHandler
(0048CEB2) Customdirview::TCustomDirView::WMLButtonDown
(00079E57) COMCTL32.DLL
(00079EF6) COMCTL32.DLL
(00079CAC) COMCTL32.DLL
(004C32DF) Dragdrop::TDragDrop::WndMethod
(0003538C) USER32.dll
(00034EAB) USER32.dll.DispatchMessageW
Re: Transfer was successfully finished, but temporary transfer file 'login.log-20240908.filepart' could not be renamed to target file name 'login.log-20240908'. If the problem persists, you may try to turn off transfer resume support - ___CPPdebugHook_seg
@Ousmanou75: Thanks for your report.
