Automate file transfers (or synchronization) to FTP/SFTP server
This guide contains simplified description of automating operations on FTP/SFTP server with WinSCP. You may want to see detailed documentation of the scripting functionality instead.
Before starting you should:
- Commands
- Script file
- Using script
- Notes
- Modifying the script automatically
- Checking script results
- Further reading
Commands
- Set script to be performed non-interactively. For most automation scripts, you should use commands
option batch onandoption confirm off. - Open session using
opencommand. - Perform operation. For uploads use
putcommand. For downloads usegetcommand. For synchronization usesynchronizecommand. For other operations, see supported commands. - Exit scripting using
exitcommand.
Script file
Assemble the commands into script file. You can name the script file as you like. See simple example and some useful scripts.
Use /script command line option to pass the script to WinSCP executable. You can embed whole command line into Windows batch file (.bat), such as:
@echo off winscp.com /script=myscript.txt
Using script
- Make shortcut to it on desktop to ease execution. Either make shortcut to batch file (
.bat) or enter full command line to shortcut itself. - If the wrapping batch file takes filename as command line parameter (see below) you can:
- Make shortcut to it on desktop and use it by dropping files on the icon. Windows automatically run the batch file and passes path to dropped file as command-line parameter.
- In a similar way you can put the shortcut to the batch file into Explorer’s ‘Send To’ context menu (
c:\documents and settings\username\sendto).
- Schedule automatic execution.
Notes
When connecting to SSH host, you will need to accept its host key.
When connecting to FTPS host with certificate signed by untrusted authority you will need to verify the certificate.
For simple modifications, you can use environment variables from the script:
option batch on option confirm off open session put %FILE_TO_UPLOAD% exit
Alternatively, you can generate new script file each time. To automate that, make a wrapper script file. For simple tasks you can use built-in Windows scripting functionality from batch file (.bat). For complex tasks, you will need to use some scripting language, such JavaScript or VBScript from Windows scripting host or PHP or Perl.
rem Generate temporary script to upload %1 echo option batch on > script.tmp echo option confirm off >> script.tmp echo open session >> script.tmp echo put %1 >> script.tmp echo exit >> script.tmp rem Execute script winscp /script=script.tmp rem Delete temporary script del script.tmp
upload.bat c:\myfile.txt
See more hints on using parameterised batch file.
See guide to advanced scripting for examples of script generation using more powerful languages.
- Check exit code of WinSCP (exit code is the only relevant and reliable way to check if script completed successfully). See example below and FAQ.
- Save and inspect log file. XML log format is recommended. Use command-line parameter
/log. - Save and inspect output of the script. Use output redirection.
Once you find out what was the result of the script, you can perform any action you like. E.g. after evaluating exit code of WinSCP, you can send a “success” or “error” email. For that use any command-line email client you like, e.g. sendmail:
winscp.com /script=example.txt if errorlevel 1 goto error echo Success sendmail.exe -t < success_mail.txt goto end :error echo Error! sendmail.exe -t < error_mail.txt :end
Where for example content of success_mail.txt may be:
From: script@example.com To: me@example.com Subject: Success The files were uploaded successfully.
See guide to advanced scripting for examples of checking script results (including XML log parsing) using more powerful languages.
Further reading
- Troubleshooting;
- Scripting documentation;
- Guide to advanced scripting;
- Command-line parameters;
- WinSCP executables;
- FAQ about scripting;
- Example scripts.
