Conditional Processing in Automation
When automating an operation with WinSCP, you may want to perform it only when a certain condition is met. Typically you may want to test if a particular file exists before attempting to transfer it.
Using WinSCP .NET Assembly
Particularly for complex conditions or conditions involving remote files, using WinSCP .NET assembly is the easiest and the recommended approach.
An example of PowerShell script that checks is a remote file exists before downloading it:
$remotePath = "/home/user/test.txt" $localPath = "C:\download\test.txt" if ($session.FileExists($remotePath)) { Write-Host ("File {0} exists, downloading" -f $remotePath) $session.GetFiles($remotePath, $localPath).Check() } else { Write-Host ("File {0} dos not exist" -f $remotePath) }
See also:
- Checking file existence;
- Using WinSCP .NET assembly from PowerShell;
- Example for
Session.FileExists(complete code for above example); - Example for
Session.GetFiles(showing how to test a local file existence and how to compare local and remote file timetamps).
Conditions in a Batch File
If you do not want to use .NET assembly, for simple conditions or conditions involving local files, you may be able to move the condition outside of WinSCP script into a wrapper batch file.
For example you can use an if command to test a local file existence before uploading it:
if exist c:\upload\test.txt winscp.com /script=upload.txt
See also:
