Upload timeout (not WinSCP's fault)
I banged my head against the desk for the last couple of days with this problem, but could not solve it.
A few days ago, uploading started to fail. I don't recall anything that could cause it. I can connect, create new folders, delete files. But uploading starts, the progress bar fills up to the end or almost, then it stops until the timeout occurs.
I tried (I'm on Windows 10):
I'm tempted to switch to Linux, but I tried it before and couldn't get used with the constant struggle to do little things I take for granted in Windows (like automatically upload changed files, PopTray email notifier, desktop shortcuts and other insignificant-but-important-to-me thingies).
I really would like to not change much in my ways of doing things at this moment, so, please, share your thoughts.
Anyways, here it is:
and the log taken in normal mode (upload failed):
Thank you.
- FileZilla: same behaviour
- Cyberduck: worked first time, then the same behaviour
- Classic FTP: same behaviour
- command prompt (Windows 10): works
- safe mode with networking: works
- FileZilla/Ubuntu (dual boot on the same machine) works and is much faster
- an animated GIF capture (<invalid hyperlink removed by admin>) showing the failure
- a text comparison (<invalid hyperlink removed by admin>) between the log from the safe mode and the log from the normal mode
- the log taken in safe mode (upload succeeded):
-------------------------------------------------------------------------- WinSCP Version 5.9.2 (Build 6958) (OS 10.0.10586 - Windows 10 Pro) Configuration: D:\apps\comm\WinSCP\WinSCP.ini Log level: Debug 2 Local account: PCID\windows-user Working directory: D:\apps\comm\WinSCP Process ID: 3564 Command-line: "D:\apps\comm\WinSCP\WinSCP.exe" Time zone: Current: GMT+3, [...] Login time: Tuesday, 27 September 2016 13:13:49 -------------------------------------------------------------------------- Session name: host/domain.com (Site) Host name: ftp.domain.com (Port: 21) User name: username (Password: Yes, Key file: No) Transfer Protocol: FTP Ping type: Dummy, Ping interval: 30 sec; Timeout: 15 sec Disable Nagle: No Proxy: None Send buffer: 262144 UTF: Auto FTPS: None [Client certificate: No] FTP: Passive: Yes [Force IP: Auto]; MLSD: Auto [List all: Auto]; HOST: Auto Local directory: D:\tmp, Remote directory: /backup, Update: Yes, Cache: Yes Cache directory changes: Yes, Permanent: Yes Recycle bin: Delete to: No, Overwritten to: No, Bin path: Timezone offset: 0h 0m -------------------------------------------------------------------------- Session upkeep Connecting to ftp.domain.com ... Connected with ftp.domain.com. Waiting for welcome message... 220---------- Welcome to Pure-FTPd [privsep] [TLS] ---------- 220-You are user number 7 of 50 allowed. 220-Local time is now 13:13. Server port: 21. 220-This is a private system - No anonymous login 220-IPv6 connections are also welcome on this server. 220 You will be disconnected after 15 minutes of inactivity. USER username 331 User username OK. Password required PASS ************* 230 OK. Current restricted directory is / SYST 215 UNIX Type: L8 FEAT 211-Extensions supported: EPRT IDLE MDTM SIZE MFMT REST STREAM MLST type*;size*;sizd*;modify*;UNIX.mode*;UNIX.uid*;UNIX.gid*;unique*; MLSD AUTH TLS PBSZ PROT UTF8 TVFS ESTA PASV EPSV SPSV ESTP 211 End. OPTS UTF8 ON 200 OK, UTF-8 enabled Session upkeep Connected Got reply 1 to the command 1 -------------------------------------------------------------------------- Using FTP protocol. Doing startup conversation with host. PWD 257 "/" is your current location Got reply 1 to the command 16 Changing directory to "/backup". CWD /backup 250 OK. Current directory is /backup Got reply 1 to the command 16 Getting current directory name. PWD 257 "/backup" is your current location Got reply 1 to the command 16 Retrieving directory listing... TYPE A 200 TYPE is now ASCII PASV 227 Entering Passive Mode (5,154,178,88,60,153) MLSD Connecting to 5.154.178.88:15513 ... Data connection opened 150 Accepted data connection Data connection closed 226-Options: -a -l 226 12 matches total […] Directory listing successful Got reply 1 to the command 2 ..;D;0;1899-12-30T02:00:00.000Z;0;"" [0];"" [0];---------;0 […] Startup conversation with host finished. Session upkeep Session upkeep Session upkeep Session upkeep Session upkeep Session upkeep Session upkeep Session upkeep Session upkeep Session upkeep Copying 1 files/directories to remote directory "/backup/" PrTime: Yes; PrRO: No; Rght: rw-r--r--; PrR: No (No); FnCs: N; RIC: 0100; Resume: S (102400); CalcS: Yes; Mask: *.* TM: M; ClAr: No; RemEOF: No; RemBOM: No; CPS: 0; NewerOnly: No; InclM: ; ResumeL: 0 AscM: *.*html; *.htm; *.txt; *.php; *.php3; *.cgi; *.c; *.cpp; *.h; *.pas; *.bas; *.tex; *.pl; .htaccess; *.xtml; *.css; *.cfg; *.ini; *.sh; *.xml File: 'D:\tmp\order-carrier.tpl' [2016-09-22T14:56:14.993Z] [17577] Copying "D:\tmp\order-carrier.tpl" to remote directory started. Binary transfer mode selected. Starting upload of D:\tmp\order-carrier.tpl TYPE I 200 TYPE is now 8-bit binary PASV 227 Entering Passive Mode (5,154,178,88,156,122) STOR order-carrier.tpl Data connection opened 150 Accepted data connection Data connection opened 226-File successfully transferred 226 0.049 seconds (measured here), 349.36 Kbytes per second MFMT 20160922145614 order-carrier.tpl 213 UTIME OK Upload successful Got reply 1 to the command 4 Transfer done: 'D:\tmp\order-carrier.tpl' [17577] Retrieving directory listing... TYPE A 200 TYPE is now ASCII PASV 227 Entering Passive Mode (5,154,178,88,120,186) MLSD Connecting to 5.154.178.88:30906 ... Data connection opened 150 Accepted data connection 226-Options: -a -l 226 13 matches total Data connection closed type=cdir;sizd=4096;modify=20160927101351;UNIX.mode=0755;UNIX.uid=1523;UNIX.gid=1524;unique=901gb410b8; . type=pdir;sizd=4096;modify=20160926153246;UNIX.mode=0711;UNIX.uid=1523;UNIX.gid=1524;unique=901gb41047; .. […] Directory listing successful Got reply 1 to the command 2 ..;D;0;1899-12-30T02:00:00.000Z;0;"" [0];"" [0];---------;0 […] Session upkeep Session upkeep Session upkeep Session upkeep Session upkeep Session upkeep Session upkeep Session upkeep Session upkeep Session upkeep Session upkeep Session upkeep Session upkeep Session upkeep Session upkeep Session upkeep Session upkeep Session upkeep Session upkeep Session upkeep Session upkeep Session upkeep Session upkeep Session upkeep Session upkeep Session upkeep Session upkeep Session upkeep Session upkeep Session upkeep Session upkeep Session upkeep Got reply 1004 to the command 2 Disconnected from server
-------------------------------------------------------------------------- WinSCP Version 5.9.2 (Build 6958) (OS 10.0.10586 - Windows 10 Pro) Configuration: D:\apps\comm\WinSCP\WinSCP.ini Log level: Debug 2 Local account: PCID\windows-user Working directory: D:\apps\comm\WinSCP Process ID: 6100 Command-line: "D:\apps\comm\WinSCP\WinSCP.exe" Time zone: Current: GMT+3, [...] Login time: Tuesday, 27 September 2016 13:15:43 -------------------------------------------------------------------------- Session name: host/domain.com (Site) Host name: ftp.domain.com (Port: 21) User name: username (Password: Yes, Key file: No) Transfer Protocol: FTP Ping type: Dummy, Ping interval: 30 sec; Timeout: 15 sec Disable Nagle: No Proxy: None Send buffer: 262144 UTF: Auto FTPS: None [Client certificate: No] FTP: Passive: Yes [Force IP: Auto]; MLSD: Auto [List all: Auto]; HOST: Auto Local directory: D:\tmp, Remote directory: /backup, Update: Yes, Cache: Yes Cache directory changes: Yes, Permanent: Yes Recycle bin: Delete to: No, Overwritten to: No, Bin path: Timezone offset: 0h 0m -------------------------------------------------------------------------- Session upkeep Connecting to ftp.domain.com ... Connected with ftp.domain.com. Waiting for welcome message... 220---------- Welcome to Pure-FTPd [privsep] [TLS] ---------- 220-You are user number 4 of 50 allowed. 220-Local time is now 13:15. Server port: 21. 220-This is a private system - No anonymous login 220-IPv6 connections are also welcome on this server. 220 You will be disconnected after 15 minutes of inactivity. USER username 331 User username OK. Password required PASS ************* 230 OK. Current restricted directory is / SYST 215 UNIX Type: L8 FEAT 211-Extensions supported: EPRT IDLE MDTM SIZE MFMT REST STREAM MLST type*;size*;sizd*;modify*;UNIX.mode*;UNIX.uid*;UNIX.gid*;unique*; MLSD AUTH TLS PBSZ PROT UTF8 TVFS ESTA PASV EPSV SPSV ESTP 211 End. OPTS UTF8 ON 200 OK, UTF-8 enabled Connected Got reply 1 to the command 1 -------------------------------------------------------------------------- Using FTP protocol. Doing startup conversation with host. PWD 257 "/" is your current location Got reply 1 to the command 16 Changing directory to "/backup". CWD /backup 250 OK. Current directory is /backup Got reply 1 to the command 16 Getting current directory name. PWD 257 "/backup" is your current location Got reply 1 to the command 16 Retrieving directory listing... TYPE A 200 TYPE is now ASCII PASV 227 Entering Passive Mode (5,154,178,88,48,75) MLSD Connecting to 5.154.178.88:12363 ... Data connection opened 150 Accepted data connection Session upkeep Data connection closed 226-Options: -a -l 226 12 matches total […] Directory listing successful Got reply 1 to the command 2 ..;D;0;1899-12-30T02:00:00.000Z;0;"" [0];"" [0];---------;0 […] Startup conversation with host finished. Session upkeep Session upkeep Session upkeep Session upkeep Session upkeep Session upkeep Session upkeep Session upkeep Session upkeep Session upkeep Copying 1 files/directories to remote directory "/backup/" PrTime: Yes; PrRO: No; Rght: rw-r--r--; PrR: No (No); FnCs: N; RIC: 0100; Resume: S (102400); CalcS: Yes; Mask: *.* TM: M; ClAr: No; RemEOF: No; RemBOM: No; CPS: 0; NewerOnly: No; InclM: ; ResumeL: 0 AscM: *.*html; *.htm; *.txt; *.php; *.php3; *.cgi; *.c; *.cpp; *.h; *.pas; *.bas; *.tex; *.pl; .htaccess; *.xtml; *.css; *.cfg; *.ini; *.sh; *.xml File: 'D:\tmp\order-carrier.tpl' [2016-09-22T14:56:14.993Z] [17577] Copying "D:\tmp\order-carrier.tpl" to remote directory started. Binary transfer mode selected. Starting upload of D:\tmp\order-carrier.tpl TYPE I 200 TYPE is now 8-bit binary PASV 227 Entering Passive Mode (5,154,178,88,121,16) STOR order-carrier.tpl Data connection opened 150 Accepted data connection Data connection opened Timeout detected. (control connection) Copying files to remote side failed. Got reply 1004 to the command 4 Connection was lost, asking what to do. Asking user: Lost connection. ("Timeout detected. (control connection)","Copying files to remote side failed.") (ESshFatal) **Lost connection.** Timeout detected. (control connection) Copying files to remote side failed. Copying files to remote side failed.
Thank you.
