How to use XML log with Powershell
                Hi support,
my OS: WIN2008
POWERTSHELL VERSION: V1.0
WINSCP VERSION: 5.92
i using below code is ok.
$sessionLogPath="C:\SinoPorject\Log\session.log"
i can got Log file.
but i use below code,
$sessionLogPath="C:\SinoPorject\Log\session.xml"
there are no xml file in the folder..
hoe to using XML log in powershell?
BR
Justin
        my OS: WIN2008
i can got Log file.
BR
Justin
