Automate script without check on fingerprint
saker
Egypt
Dears,
I need to make an automatic script to connect to servers and don't check on a fingerprint key.
Script created on Windows.
And I try to use "/hostkey="*" & -hostkey="*" and it doesn't work.
Any help?
Re: Automate script without check on fingerprint
Show us your code and session log file.
Hello Martin,
sorry for being late. please find below the script
cd C:\
cd program files (x86)
cd WinSCP
WinSCP.com /command "option batch abort" "option confirm off" "option transfer ascii" "open sftp://USER@10.10.10.10" "get -delete /PATH/*.lst D:\PATH\" "exit" /privatekey=D:\keyfile.ppk
This script connect to cluster servers, so may be fingerprint changes every while, so I need this script to ignore the fingerprint check.
And where's the -hostkey switch?
It should be like:
WinSCP.com /command "option transfer ascii" "open sftp://USER@10.10.10.10/ -hostkey=*" ...
(Note that the "option batch abort" "option confirm off" are not needed anymore in the recent versions of WinSCP).
Though, when connecting to a cluster of servers, you should simply list all their fingerprints, instead of blindly accepting any.
"open sftp://USER@10.10.10.10/ -hostkey=""ssh-dss 1024 key1;ssh-dss 1024 key2;ssh-dss 1024 key3"""
