.NET Specifiy Initial Remote Directory
peter594
I currently try to get an SFTP connection to work with the .NET Assembly.
What I do is the following (see code). But I can't get this to work. I should mention I have no read or write permissions to the root directory only to a directory called /OUT. But I haven't found any possiblity to specify the Initial Remote directory before session.Open. Has anyone a hint for me about this issue?
The session.Open(sessionOptions) throws following expection:
An unhandled exception of type 'WinSCP.SessionRemoteException' occurred in WinSCPnet.dll
Additional information: Connection has been unexpectedly closed. Server sent command exit status 0. Authentication failed.
The thing is a generated this information with Winscp Windows program and the settings are right. I also added the password which is not added by default in generated code.
I can connect by commmand line of Winscp and with Winscp GUI so the settings should be correct.
namespace Test
    class Program
        static void Main(string[] args)
            var sessionOptions = new SessionOptions
                Protocol = Protocol.Sftp,
                HostName = "...",
                UserName = "...",
                Password = "...",
                SshHostKeyFingerprint = "...",
                SshPrivateKeyPath = @"FILE",
                // Connect
                sessionOptions.AddRawSettings("AuthGSSAPI", "...");
                sessionOptions.AddRawSettings("Cipher", "...");
                sessionOptions.AddRawSettings("KEX", "...");
                session.Open(sessionOptions);
                var result = session.ListDirectory("/OUT");
Re: .NET Specifiy Initial Remote Directory
peter594
Hello Martin,
first thanks for your answer. Enclosed the requested log, I removed all the personal information like URL, usernames etc. At says Disconnected: Unable to authenticate at the end but the login informations are exactly the same like when I enter it into the normal GUI. There it can connect. The only difference is in the GUI I also private in the Directory options a remote directory name.
  • log.txt (6.74 KB, Private file)
