File containing source files paths
mestevez01
I need to transfer multiple files that are stored in different subfolders within a folder. My question is, can I create a file containing the paths of all the files that I need to transfer and then use that file in a script?
Thanks in advance for your help.
Re: File containing source files paths
Thanks for your feedback.
The request became a bit more challenging.
1 - I need to obtain from a database the paths for the files that I need to copy (No problem). The files are stored in multiple subfolders.
2 - The files need to be renamed and then copied to their final location.
I think I'll use a .Net script to achieve this. I was hoping to use WinSCP but this might be just too much for it.
Thanks.
Not directly.
Either create the file list with put command prefix.
Or use the file list to generate ad-hoc upload script.
See https://winscp.net/eng/docs/script_upload_file_list
