challenges while usind WinSCP Dll in Webservice
siddheish
India
I want to upload file to ftp server using webservice i have done all code but still getting error of Access is denied on local file path
in putfiles function i have given everyone rights to folder
below is error from transferresult.check() line.
and also i get filename invalid error sometimes on same line.
Please help me ASAP
08-10-2016 10:58:06 PM_WinSCP: Error is reported by the remote server; Local error occurs in WinSCP console session, such as error reading local file.
Message:Error transferring file 'D:\Work\OCR schedulers\FTPFilehandling_ASMX\FTPFilehandling_ASMX\test\soc.jpg'.
Access is denied.
Win32 error: Access is denied.
Error details: File system denied the access.
End
Target Site:Void Check()
Inner Exception:
Stacktrace: at WinSCP.OperationResultBase.Check()
at FTPFilehandling_ASMX.Service1.UploadFile(String Frompath, String Topath, String hostName, String userName, String password, Int32 port, Protocol mode, String Fingerprint) in D:\Work\OCR schedulers\FTPFilehandling_ASMX\FTPFilehandling_ASMX\FTPFilehandling.asmx.cs:line 116
Re: challenges while usind WinSCP Dll in Webservice
siddheish
India
First of All is it possible to use Winscp DLL assembly c# in Webservice if so Please give me proper guide for that because i m getting so much challenges than applying it in windows application
I have attached log please check.
  • test.txt (7.67 KB, Private file)
Description: Session log
The error comes from the server. It's most probably Windows server, so that's why the message wording ("Win32 error") gives impression that it's referring to a local file.
So your issue has nothing to do with uploading from a webservice.
Are you able to upload the file to the server any other way? e.g. from WinSCP GUI? Show us a log!
