Topic "Shell sudo -s has no effect"
This maybe a frequently asked question, but I do checked the FAQ and searched a lot.
What I did is:
1. Add "myname ALL = NOPASSWD: ALL" into /etc/sudoers
2. Advanced site settings -> Shell -> Shell, input sudo -s
After this, I am still telled if edit files with rwxr-xr-x
Permission denied.
Error code: 3
Error message from server: Permission denied
Could anyone help me with the problem?
Any help will be highly appreciated.
The Shell option is for the SCP protocol. While it seems that you are using the SFTP protocol. So use the SFTP server option.
See https://winscp.net/eng/docs/faq_su
Martin, Thanks a lot for your reply.
Actually, I have tried both SFTP and Shell.
If set SFTP server to "sudo /bin/sftp-server", the login fail, it says
Sever sent command exit status 1
Cannot initialize SFTP protocol. Is the host running an SFTP server?
And does the /bin/sftp-server exists?
Search
