TransferEventArgs should have an equivalent to the Side property of FileTransferProgressEventA...
Chris David
Unless there is an easy way to accomplish this that I haven't seen, it would be nice to know once a file is transferred if it was an upload or download. During a file transfer progress event, I can use the Side property to know, but I don't have an equivalent property for the file transferred event. I suppose I could start examining directory names, but that is sort of "clumsy" so to speak.
Edit: I suppose I could just set it to the appropriate handler when I am doing an upload or download, but I would have preferred one handler that handles both.
Thank you.
Re: TransferEventArgs should have an equivalent to the Side property of FileTransferProgressEventA...
Chris David
Hi Martin,
I'm using the NET assembly version of WinSCP.
If you wanted me to take a look I would need that version to do so.
Is that what you sent me?
Chris David
Chris David wrote:
Hi Martin,
It is working as expected for both uploads and downloads.
