Want to upload multiple files using SFTP to remote server
skumarlingamNC
Hello Experts,
I am trying to upload multiple files using below script, somehow batch script picking only first file out of multiple files from local drive and uploads on remote server.
WinScp version 5.9.2
batch command
"C:\Program Files (x86)\WinSCP\WinSCP.exe" /log= V:\BatchScripts\File_Put.log /script=V:\BatchScripts\File_Put.txt
File_Put.txt
# Connect to SFTP server using a password
open sftp://username:password;fingerprint=ssh-**s-**-**-**-**-**-**-**-**-**-**-**-**-**-**-**-**@sftp.**.com/XYZ/WVW_to_User/
# Upload file
put V:\*.csv /XYZ/WVW_to_User/
Please let me know is there any wrong with script.
Thank you in advance.
[/code]
I think you can try doing an LCD to change the directory then try the transfer.
# Upload file
lcd V:\
put *.csv /XYZ/WVW_to_User/
EXIT
skumarlingamNC
Thank you my friend.
I will try and let you know the progress.
# Upload file
lcd V:\
EXIT
skumarlingamNC
sorry I changed code as per your suggestion. batch script picking first file and uploading on remote server. not picking other files.
Re: Want to upload multiple files using SFTP to remote server
It must be erroring out. I would enable logging to see what exactly is happening. You can also try disabling the permission and timestamp setting to see if that's the problem. https://winscp.net/eng/docs/message_preserve_time_perm
# Upload file
lcd V:\
put *.csv /XYZ/WVW_to_User/ -nopreservetime -nopermissions
EXIT[/quote][/quote]
skumarlingamNC
You are my hero Thank you. Finally I can upload all my multiple files.
here is the code the one suggested by you.
# Upload file
lcd V:\
EXIT
Thank you once again.
skumarlingamNC
sorry for late reply.
Correct. below line is enough to upload multiple files via sftp.
-nopreservetime
thank you though for helping me.
Is that possible after uploading files on remote server can we suffix today's(current) datetime to each file
(example file name: XYZ_10_14_2016.csv)
Please let me know if you want me to open in spread thread.
