winscp (sftp) occasionally fails to transfer files from AWS server to the remote 3rd party server.
mshaik
sioux falls
HI,
We have many clients that transfer statements 3rd part QPS server. Few of the clients were migrated to AWS. the AWS clients are facing issues once in a while while transferring PDF files to remote 3rd part QPS server. So far no solution found. The remote PDF file got corrupted. every night twp pdf files will be transferred using winscp (SFTP). The first file is a small file. The second file is a 100K+ file. most of the days in a week these PDF files will be transferred using SFTP to the remote server successfully. And one day it the first file will be transferred successfully and the second file will be failed (the remote server will have a corrupted PDF file with size 430 bytes.). The log is pasted below for your reference. I appreciated your hwlp in resolving the issue.
The following winscp log has both success of first file (45K size) and the failure of second file (100K + size) for your reference. I removed some sensive data related to userids/passwords and server names and the transferred files content for security purpose.
. 2016-09-19 00:01:46.976 --------------------------------------------------------------------------
. 2016-09-19 00:01:46.977 WinSCP Version 5.5.6 (Build 4746) (OS 6.3.9600 - Windows Server 2012 R2 Standard)
. 2016-09-19 00:01:46.978 Configuration: \\<..>\WinSCP.ini
. 2016-09-19 00:01:46.978 Local account:
. 2016-09-19 00:01:46.978 Working directory:
. 2016-09-19 00:01:46.978 Process ID:
. 2016-09-19 00:01:46.978 Command-line: "\\<...>\WinSCP.exe" /console=556 /consoleinstance=_7104_861 "/script=\\<...>\Temp\command20160919000146421157.txt"
. 2016-09-19 00:01:46.978 Time zone: Current: GMT-5, Standard: GMT-6 (Central Standard Time), DST: GMT-5 (Central Daylight Time), DST Start: 3/13/2016, DST End: 11/6/2016
. 2016-09-19 00:01:46.978 Login time: Monday, September 19, 2016 12:01:46 AM
. 2016-09-19 00:01:46.978 --------------------------------------------------------------------------
. 2016-09-19 00:01:46.978 Script: Retrospectively logging previous script records:
> 2016-09-19 00:01:46.978 Script: option batch abort
< 2016-09-19 00:01:46.978 Script: batch abort
> 2016-09-19 00:01:46.978 Script: option confirm off
< 2016-09-19 00:01:46.978 Script: confirm off
> 2016-09-19 00:01:46.978 Script: open sftp://<...>@<...>.com:22 -hostkey="ssh-rsa <...>"
. 2016-09-19 00:01:46.978 Session name: (Ad-Hoc site)
. 2016-09-19 00:01:46.979 Host name: <> (Port: 22)
. 2016-09-19 00:01:46.979 User name: (Password: Yes, Key file: No)
. 2016-09-19 00:01:46.979 Tunnel: No
. 2016-09-19 00:01:46.979 Transfer Protocol: SFTP
. 2016-09-19 00:01:46.979 Ping type: -, Ping interval: 30 sec; Timeout: 15 sec
. 2016-09-19 00:01:46.979 Proxy: none
. 2016-09-19 00:01:46.979 Send buffer: 262144
. 2016-09-19 00:01:46.979 SSH protocol version: 2; Compression: No
. 2016-09-19 00:01:46.979 Bypass authentication: No
. 2016-09-19 00:01:46.979 Try agent: Yes; Agent forwarding: No; TIS/CryptoCard: No; KI: Yes; GSSAPI: No
. 2016-09-19 00:01:46.979 Ciphers: aes,blowfish,3des,WARN,arcfour,des; Ssh2DES: No
. 2016-09-19 00:01:46.979 SSH Bugs: A,A,A,A,A,A,A,A,A,A
. 2016-09-19 00:01:46.979 Simple channel: Yes
. 2016-09-19 00:01:46.979 Return code variable: Autodetect; Lookup user groups: A
. 2016-09-19 00:01:46.979 Shell: default
. 2016-09-19 00:01:46.979 EOL: 0, UTF: 2
. 2016-09-19 00:01:46.979 Clear aliases: Yes, Unset nat.vars: Yes, Resolve symlinks: Yes
. 2016-09-19 00:01:46.979 LS: ls -la, Ign LS warn: Yes, Scp1 Comp: No
. 2016-09-19 00:01:46.979 Local directory: default, Remote directory: home, Update: Yes, Cache: Yes
. 2016-09-19 00:01:46.979 Cache directory changes: Yes, Permanent: Yes
. 2016-09-19 00:01:46.979 DST mode: 1; Timezone offset: 0h 0m
. 2016-09-19 00:01:46.979 --------------------------------------------------------------------------
. 2016-09-19 00:01:46.983 Looking up host ""
. 2016-09-19 00:01:46.987 Connecting to port 22
. 2016-09-19 00:01:47.030 Selecting events 63 for socket 696
. 2016-09-19 00:01:47.030 Waiting for the server to continue with the initialization
. 2016-09-19 00:01:47.030 Looking for incoming data
. 2016-09-19 00:01:47.030 Looking for network events
. 2016-09-19 00:01:47.030 Detected network event
. 2016-09-19 00:01:47.030 Enumerating network events for socket 696
. 2016-09-19 00:01:47.030 Enumerated 18 network events making 18 cumulative events for socket 696
. 2016-09-19 00:01:47.030 Handling network write event on socket 696 with error 0
. 2016-09-19 00:01:47.030 Handling network connect event on socket 696 with error 0
. 2016-09-19 00:01:47.073 Detected network event
. 2016-09-19 00:01:47.073 Enumerating network events for socket 696
. 2016-09-19 00:01:47.073 Enumerated 1 network events making 1 cumulative events for socket 696
. 2016-09-19 00:01:47.073 Handling network read event on socket 696 with error 0
. 2016-09-19 00:01:47.073 Server version: SSH-2.0-WS_FTP-SSH_7.7 FIPS
. 2016-09-19 00:01:47.073 Using SSH protocol version 2
. 2016-09-19 00:01:47.073 We claim version: SSH-2.0-WinSCP_release_5.5.6
. 2016-09-19 00:01:47.076 Waiting for the server to continue with the initialization
. 2016-09-19 00:01:47.076 Looking for incoming data
. 2016-09-19 00:01:47.076 Looking for network events
. 2016-09-19 00:01:47.114 Detected network event
. 2016-09-19 00:01:47.114 Enumerating network events for socket 696
. 2016-09-19 00:01:47.114 Enumerated 1 network events making 1 cumulative events for socket 696
. 2016-09-19 00:01:47.114 Handling network read event on socket 696 with error 0
. 2016-09-19 00:01:47.118 Using Diffie-Hellman with standard group "group14"
. 2016-09-19 00:01:47.118 Doing Diffie-Hellman key exchange with hash SHA-1
. 2016-09-19 00:01:47.170 Waiting for the server to continue with the initialization
. 2016-09-19 00:01:47.170 Looking for incoming data
. 2016-09-19 00:01:47.170 Looking for network events
. 2016-09-19 00:01:47.243 Detected network event
. 2016-09-19 00:01:47.243 Enumerating network events for socket 696
. 2016-09-19 00:01:47.243 Enumerated 1 network events making 1 cumulative events for socket 696
. 2016-09-19 00:01:47.243 Handling network read event on socket 696 with error 0
. 2016-09-19 00:01:47.299 Verifying host key rsa2 0x with fingerprint ssh-rsa
. 2016-09-19 00:01:47.301 Host key matches configured key
. 2016-09-19 00:01:47.301 Selecting events 63 for socket 696
. 2016-09-19 00:01:47.301 Host key fingerprint is:
. 2016-09-19 00:01:47.301 ssh-rsa 1024 <...>
. 2016-09-19 00:01:47.301 Initialised AES-256 CBC client->server encryption
. 2016-09-19 00:01:47.301 Initialised HMAC-SHA1 client->server MAC algorithm
. 2016-09-19 00:01:47.301 Waiting for the server to continue with the initialization
. 2016-09-19 00:01:47.301 Looking for incoming data
. 2016-09-19 00:01:47.301 Looking for network events
. 2016-09-19 00:01:47.303 Detected network event
. 2016-09-19 00:01:47.303 Enumerating network events for socket 696
. 2016-09-19 00:01:47.303 Enumerated 1 network events making 1 cumulative events for socket 696
. 2016-09-19 00:01:47.303 Handling network read event on socket 696 with error 0
. 2016-09-19 00:01:47.303 Initialised AES-256 CBC server->client encryption
. 2016-09-19 00:01:47.303 Initialised HMAC-SHA1 server->client MAC algorithm
. 2016-09-19 00:01:47.303 Waiting for the server to continue with the initialization
. 2016-09-19 00:01:47.303 Looking for incoming data
. 2016-09-19 00:01:47.303 Looking for network events
. 2016-09-19 00:01:47.400 Detected network event
. 2016-09-19 00:01:47.400 Enumerating network events for socket 696
. 2016-09-19 00:01:47.400 Enumerated 1 network events making 1 cumulative events for socket 696
. 2016-09-19 00:01:47.400 Handling network read event on socket 696 with error 0
! 2016-09-19 00:01:47.400 Using username "<...>".
. 2016-09-19 00:01:47.400 Waiting for the server to continue with the initialization
. 2016-09-19 00:01:47.400 Looking for incoming data
. 2016-09-19 00:01:47.400 Looking for network events
. 2016-09-19 00:01:47.450 Detected network event
. 2016-09-19 00:01:47.450 Enumerating network events for socket 696
. 2016-09-19 00:01:47.450 Enumerated 1 network events making 1 cumulative events for socket 696
. 2016-09-19 00:01:47.450 Handling network read event on socket 696 with error 0
. 2016-09-19 00:01:47.450 Prompt (7, SSH password, , &Password: )
. 2016-09-19 00:01:47.450 Using stored password.
. 2016-09-19 00:01:47.451 Sent password
. 2016-09-19 00:01:47.451 Waiting for the server to continue with the initialization
. 2016-09-19 00:01:47.451 Looking for incoming data
. 2016-09-19 00:01:47.451 Looking for network events
. 2016-09-19 00:01:47.500 Detected network event
. 2016-09-19 00:01:47.500 Enumerating network events for socket 696
. 2016-09-19 00:01:47.500 Enumerated 1 network events making 1 cumulative events for socket 696
. 2016-09-19 00:01:47.500 Handling network read event on socket 696 with error 0
. 2016-09-19 00:01:47.500 Access granted
. 2016-09-19 00:01:47.500 Opening session as main channel
. 2016-09-19 00:01:47.500 Waiting for the server to continue with the initialization
. 2016-09-19 00:01:47.500 Looking for incoming data
. 2016-09-19 00:01:47.500 Looking for network events
. 2016-09-19 00:01:47.540 Detected network event
. 2016-09-19 00:01:47.540 Enumerating network events for socket 696
. 2016-09-19 00:01:47.540 Enumerated 1 network events making 1 cumulative events for socket 696
. 2016-09-19 00:01:47.540 Handling network read event on socket 696 with error 0
. 2016-09-19 00:01:47.540 Opened main channel
. 2016-09-19 00:01:47.540 Waiting for the server to continue with the initialization
. 2016-09-19 00:01:47.540 Looking for incoming data
. 2016-09-19 00:01:47.540 Looking for network events
. 2016-09-19 00:01:47.650 Detected network event
. 2016-09-19 00:01:47.650 Enumerating network events for socket 696
. 2016-09-19 00:01:47.650 Enumerated 1 network events making 1 cumulative events for socket 696
. 2016-09-19 00:01:47.650 Handling network read event on socket 696 with error 0
. 2016-09-19 00:01:47.650 Started a shell/command
. 2016-09-19 00:01:47.650 --------------------------------------------------------------------------
. 2016-09-19 00:01:47.652 Using SFTP protocol.
. 2016-09-19 00:01:47.653 Doing startup conversation with host.
> 2016-09-19 00:01:47.656 Type: SSH_FXP_INIT, Size: 5, Number: -1
> 2016-09-19 00:01:47.656 01,00,00,00,05,
. 2016-09-19 00:01:47.656 Sent 9 bytes
. 2016-09-19 00:01:47.656 There are 0 bytes remaining in the send buffer
. 2016-09-19 00:01:47.656 Looking for network events
. 2016-09-19 00:01:47.656 Timeout waiting for network events
. 2016-09-19 00:01:47.656 Waiting for another 4 bytes
. 2016-09-19 00:01:47.656 Looking for incoming data
. 2016-09-19 00:01:47.696 Detected network event
. 2016-09-19 00:01:47.696 Enumerating network events for socket 696
. 2016-09-19 00:01:47.696 Enumerated 1 network events making 1 cumulative events for socket 696
. 2016-09-19 00:01:47.696 Handling network read event on socket 696 with error 0
. 2016-09-19 00:01:47.696 Received 9 bytes (0)
. 2016-09-19 00:01:47.696 Read 4 bytes (5 pending)
. 2016-09-19 00:01:47.696 Read 5 bytes (0 pending)
< 2016-09-19 00:01:47.696 Type: SSH_FXP_VERSION, Size: 5, Number: -1
< 2016-09-19 00:01:47.696 02,00,00,00,04,
. 2016-09-19 00:01:47.696 SFTP version 4 negotiated.
. 2016-09-19 00:01:47.697 We will use UTF-8 strings when appropriate
. 2016-09-19 00:01:47.700 Getting current directory name.
. 2016-09-19 00:01:47.701 Getting real path for '.'
> 2016-09-19 00:01:47.701 Type: SSH_FXP_REALPATH, Size: 10, Number: 16
> 2016-09-19 00:01:47.701 10,00,00,00,10,00,00,00,01,2E,
. 2016-09-19 00:01:47.701 Sent 14 bytes
. 2016-09-19 00:01:47.701 There are 0 bytes remaining in the send buffer
. 2016-09-19 00:01:47.701 Looking for network events
. 2016-09-19 00:01:47.701 Timeout waiting for network events
. 2016-09-19 00:01:47.701 Waiting for another 4 bytes
. 2016-09-19 00:01:47.701 Looking for incoming data
. 2016-09-19 00:01:47.768 Detected network event
. 2016-09-19 00:01:47.768 Enumerating network events for socket 696
. 2016-09-19 00:01:47.768 Enumerated 1 network events making 1 cumulative events for socket 696
. 2016-09-19 00:01:47.768 Handling network read event on socket 696 with error 0
. 2016-09-19 00:01:47.768 Received 27 bytes (0)
. 2016-09-19 00:01:47.768 Read 4 bytes (23 pending)
. 2016-09-19 00:01:47.768 Read 23 bytes (0 pending)
< 2016-09-19 00:01:47.768 Type: SSH_FXP_NAME, Size: 23, Number: 16
< 2016-09-19 00:01:47.768 68,00,00,00,10,00,00,00,01,00,00,00,01,2F,00,00,00,04,02,00,00,01,E8,
. 2016-09-19 00:01:47.769 Real path is '/'
. 2016-09-19 00:01:47.769 Startup conversation with host finished.
< 2016-09-19 00:01:47.769 Script: Active session: [1] <>@<>.com
. 2016-09-19 00:01:47.769 Session upkeep
. 2016-09-19 00:01:47.769 Looking for network events
. 2016-09-19 00:01:47.769 Timeout waiting for network events
> 2016-09-19 00:01:47.769 Script: mkdir ./Statements
. 2016-09-19 00:01:47.769 Creating directory "./Statements".
. 2016-09-19 00:01:47.769 Canonifying: "./Statements"
. 2016-09-19 00:01:47.769 Getting real path for '/Statements'
> 2016-09-19 00:01:47.769 Type: SSH_FXP_REALPATH, Size: 20, Number: 528
> 2016-09-19 00:01:47.769 10,00,00,02,10,00,00,00,0B,2F,53,74,61,74,65,6D,65,6E,74,73,
. 2016-09-19 00:01:47.769 Sent 24 bytes
. 2016-09-19 00:01:47.769 There are 0 bytes remaining in the send buffer
. 2016-09-19 00:01:47.770 Looking for network events
. 2016-09-19 00:01:47.770 Timeout waiting for network events
. 2016-09-19 00:01:47.770 Waiting for another 4 bytes
. 2016-09-19 00:01:47.770 Looking for incoming data
. 2016-09-19 00:01:47.810 Detected network event
. 2016-09-19 00:01:47.810 Enumerating network events for socket 696
. 2016-09-19 00:01:47.810 Enumerated 1 network events making 1 cumulative events for socket 696
. 2016-09-19 00:01:47.810 Handling network read event on socket 696 with error 0
. 2016-09-19 00:01:47.810 Received 37 bytes (0)
. 2016-09-19 00:01:47.810 Read 4 bytes (33 pending)
. 2016-09-19 00:01:47.810 Read 33 bytes (0 pending)
< 2016-09-19 00:01:47.810 Type: SSH_FXP_NAME, Size: 33, Number: 528
< 2016-09-19 00:01:47.810 68,00,00,02,10,00,00,00,01,00,00,00,0B,2F,53,74,61,74,65,6D,65,6E,74,73,00,
< 2016-09-19 00:01:47.810 00,00,04,02,00,00,01,E8,
. 2016-09-19 00:01:47.810 Real path is '/Statements'
. 2016-09-19 00:01:47.810 Canonified: "/Statements"
> 2016-09-19 00:01:47.810 Type: SSH_FXP_MKDIR, Size: 25, Number: 270
> 2016-09-19 00:01:47.810 0E,00,00,01,0E,00,00,00,0B,2F,53,74,61,74,65,6D,65,6E,74,73,00,00,00,00,02,
. 2016-09-19 00:01:47.810 Sent 29 bytes
. 2016-09-19 00:01:47.810 There are 0 bytes remaining in the send buffer
. 2016-09-19 00:01:47.810 Looking for network events
. 2016-09-19 00:01:47.810 Timeout waiting for network events
. 2016-09-19 00:01:47.810 Waiting for another 4 bytes
. 2016-09-19 00:01:47.810 Looking for incoming data
. 2016-09-19 00:01:47.851 Detected network event
. 2016-09-19 00:01:47.851 Enumerating network events for socket 696
. 2016-09-19 00:01:47.851 Enumerated 1 network events making 1 cumulative events for socket 696
. 2016-09-19 00:01:47.851 Handling network read event on socket 696 with error 0
. 2016-09-19 00:01:47.851 Received 21 bytes (0)
. 2016-09-19 00:01:47.851 Read 4 bytes (17 pending)
. 2016-09-19 00:01:47.851 Read 17 bytes (0 pending)
< 2016-09-19 00:01:47.851 Type: SSH_FXP_STATUS, Size: 17, Number: 270
< 2016-09-19 00:01:47.851 65,00,00,01,0E,00,00,00,04,00,00,00,00,00,00,00,00,
< 2016-09-19 00:01:47.851 Status code: 4, Message: 270, Server: , Language:
. 2016-09-19 00:01:47.851 Asking user:
. 2016-09-19 00:01:47.851 Error creating folder './Statements'. ("General failure (server should provide error description).
. 2016-09-19 00:01:47.851 Error code: 4
. 2016-09-19 00:01:47.851 Error message from server: ")
< 2016-09-19 00:01:47.851 Script: Error creating folder './Statements'.
< 2016-09-19 00:01:47.851 Script: General failure (server should provide error description).
< 2016-09-19 00:01:47.851 Error code: 4
< 2016-09-19 00:01:47.851 Error message from server:
. 2016-09-19 00:01:47.852 Script: Failed
. 2016-09-19 00:01:47.852 Session upkeep
. 2016-09-19 00:01:47.852 Looking for network events
. 2016-09-19 00:01:47.852 Timeout waiting for network events
. 2016-09-19 00:01:47.852 Script: Exit code: 1
. 2016-09-19 00:01:47.852 Closing connection.
. 2016-09-19 00:01:47.852 Sending special code: 12
. 2016-09-19 00:01:47.852 Sent EOF message
. 2016-09-19 00:01:47.853 Selecting events 0 for socket 696
. 2016-09-19 00:01:48.110 --------------------------------------------------------------------------
. 2016-09-19 00:01:48.110 WinSCP Version 5.5.6 (Build 4746) (OS 6.3.9600 - Windows Server 2012 R2 Standard)
. 2016-09-19 00:01:48.111 Configuration: \\<>\WinSCP.ini
. 2016-09-19 00:01:48.112 Local account: <>
. 2016-09-19 00:01:48.112 Working directory: <>
. 2016-09-19 00:01:48.112 Process ID: 6720
. 2016-09-19 00:01:48.112 Command-line: "<>\WinSCP.exe" /console=556 /consoleinstance=_796_65 "/script=\\<>\Temp\command20160919000146421157.txt"
. 2016-09-19 00:01:48.112 Time zone: Current: GMT-5, Standard: GMT-6 (Central Standard Time), DST: GMT-5 (Central Daylight Time), DST Start: 3/13/2016, DST End: 11/6/2016
. 2016-09-19 00:01:48.112 Login time: Monday, September 19, 2016 12:01:48 AM
. 2016-09-19 00:01:48.112 --------------------------------------------------------------------------
. 2016-09-19 00:01:48.112 Script: Retrospectively logging previous script records:
> 2016-09-19 00:01:48.112 Script: option batch abort
< 2016-09-19 00:01:48.112 Script: batch abort
> 2016-09-19 00:01:48.112 Script: option confirm off
< 2016-09-19 00:01:48.112 Script: confirm off
> 2016-09-19 00:01:48.112 Script: open sftp://<>:22 -hostkey="ssh-rsa <...>"
. 2016-09-19 00:01:48.112 Session name: <...> (Ad-Hoc site)
. 2016-09-19 00:01:48.112 Host name: <...> (Port: 22)
. 2016-09-19 00:01:48.112 User name: <...> (Password: Yes, Key file: No)
. 2016-09-19 00:01:48.112 Tunnel: No
. 2016-09-19 00:01:48.112 Transfer Protocol: SFTP
. 2016-09-19 00:01:48.112 Ping type: -, Ping interval: 30 sec; Timeout: 15 sec
. 2016-09-19 00:01:48.112 Proxy: none
. 2016-09-19 00:01:48.112 Send buffer: 262144
. 2016-09-19 00:01:48.112 SSH protocol version: 2; Compression: No
. 2016-09-19 00:01:48.112 Bypass authentication: No
. 2016-09-19 00:01:48.112 Try agent: Yes; Agent forwarding: No; TIS/CryptoCard: No; KI: Yes; GSSAPI: No
. 2016-09-19 00:01:48.112 Ciphers: aes,blowfish,3des,WARN,arcfour,des; Ssh2DES: No
. 2016-09-19 00:01:48.112 SSH Bugs: A,A,A,A,A,A,A,A,A,A
. 2016-09-19 00:01:48.112 Simple channel: Yes
. 2016-09-19 00:01:48.112 Return code variable: Autodetect; Lookup user groups: A
. 2016-09-19 00:01:48.112 Shell: default
. 2016-09-19 00:01:48.112 EOL: 0, UTF: 2
. 2016-09-19 00:01:48.112 Clear aliases: Yes, Unset nat.vars: Yes, Resolve symlinks: Yes
. 2016-09-19 00:01:48.112 LS: ls -la, Ign LS warn: Yes, Scp1 Comp: No
. 2016-09-19 00:01:48.112 Local directory: default, Remote directory: home, Update: Yes, Cache: Yes
. 2016-09-19 00:01:48.112 Cache directory changes: Yes, Permanent: Yes
. 2016-09-19 00:01:48.112 DST mode: 1; Timezone offset: 0h 0m
. 2016-09-19 00:01:48.113 Looking up host "<...>"
. 2016-09-19 00:01:48.116 Connecting to <...> port 22
. 2016-09-19 00:01:48.156 Selecting events 63 for socket 808
. 2016-09-19 00:01:48.156 Waiting for the server to continue with the initialization
. 2016-09-19 00:01:48.156 Looking for incoming data
. 2016-09-19 00:01:48.156 Looking for network events
. 2016-09-19 00:01:48.156 Detected network event
. 2016-09-19 00:01:48.156 Enumerating network events for socket 808
. 2016-09-19 00:01:48.156 Enumerated 18 network events making 18 cumulative events for socket 808
. 2016-09-19 00:01:48.156 Handling network write event on socket 808 with error 0
. 2016-09-19 00:01:48.156 Handling network connect event on socket 808 with error 0
. 2016-09-19 00:01:48.198 Detected network event
. 2016-09-19 00:01:48.198 Enumerating network events for socket 808
. 2016-09-19 00:01:48.198 Enumerated 1 network events making 1 cumulative events for socket 808
. 2016-09-19 00:01:48.198 Handling network read event on socket 808 with error 0
. 2016-09-19 00:01:48.198 Server version: SSH-2.0-WS_FTP-SSH_7.7 FIPS
. 2016-09-19 00:01:48.198 Using SSH protocol version 2
. 2016-09-19 00:01:48.198 We claim version: SSH-2.0-WinSCP_release_5.5.6
. 2016-09-19 00:01:48.199 Waiting for the server to continue with the initialization
. 2016-09-19 00:01:48.199 Looking for incoming data
. 2016-09-19 00:01:48.199 Looking for network events
. 2016-09-19 00:01:48.238 Detected network event
. 2016-09-19 00:01:48.238 Enumerating network events for socket 808
. 2016-09-19 00:01:48.238 Enumerated 1 network events making 1 cumulative events for socket 808
. 2016-09-19 00:01:48.238 Handling network read event on socket 808 with error 0
. 2016-09-19 00:01:48.239 Using Diffie-Hellman with standard group "group14"
. 2016-09-19 00:01:48.239 Doing Diffie-Hellman key exchange with hash SHA-1
. 2016-09-19 00:01:48.291 Waiting for the server to continue with the initialization
. 2016-09-19 00:01:48.291 Looking for incoming data
. 2016-09-19 00:01:48.291 Looking for network events
. 2016-09-19 00:01:48.399 Detected network event
. 2016-09-19 00:01:48.399 Enumerating network events for socket 808
. 2016-09-19 00:01:48.399 Enumerated 1 network events making 1 cumulative events for socket 808
. 2016-09-19 00:01:48.399 Handling network read event on socket 808 with error 0
. 2016-09-19 00:01:48.456 Verifying host key rsa2 0x23, with fingerprint ssh-rsa 1024 <...>
. 2016-09-19 00:01:48.457 Host key matches configured key
. 2016-09-19 00:01:48.457 Selecting events 63 for socket 808
. 2016-09-19 00:01:48.457 Host key fingerprint is:
. 2016-09-19 00:01:48.457 ssh-rsa 1024 <...>
. 2016-09-19 00:01:48.457 Initialised AES-256 CBC client->server encryption
. 2016-09-19 00:01:48.457 Initialised HMAC-SHA1 client->server MAC algorithm
. 2016-09-19 00:01:48.457 Waiting for the server to continue with the initialization
. 2016-09-19 00:01:48.457 Looking for incoming data
. 2016-09-19 00:01:48.457 Looking for network events
. 2016-09-19 00:01:48.459 Detected network event
. 2016-09-19 00:01:48.459 Enumerating network events for socket 808
. 2016-09-19 00:01:48.459 Enumerated 1 network events making 1 cumulative events for socket 808
. 2016-09-19 00:01:48.459 Handling network read event on socket 808 with error 0
. 2016-09-19 00:01:48.459 Initialised AES-256 CBC server->client encryption
. 2016-09-19 00:01:48.459 Initialised HMAC-SHA1 server->client MAC algorithm
. 2016-09-19 00:01:48.459 Waiting for the server to continue with the initialization
. 2016-09-19 00:01:48.459 Looking for incoming data
. 2016-09-19 00:01:48.459 Looking for network events
. 2016-09-19 00:01:48.587 Detected network event
. 2016-09-19 00:01:48.587 Enumerating network events for socket 808
. 2016-09-19 00:01:48.587 Enumerated 1 network events making 1 cumulative events for socket 808
. 2016-09-19 00:01:48.587 Handling network read event on socket 808 with error 0
! 2016-09-19 00:01:48.587 Using username "<...>".
. 2016-09-19 00:01:48.587 Waiting for the server to continue with the initialization
. 2016-09-19 00:01:48.587 Looking for incoming data
. 2016-09-19 00:01:48.587 Looking for network events
. 2016-09-19 00:01:48.636 Detected network event
. 2016-09-19 00:01:48.636 Enumerating network events for socket 808
. 2016-09-19 00:01:48.636 Enumerated 1 network events making 1 cumulative events for socket 808
. 2016-09-19 00:01:48.636 Handling network read event on socket 808 with error 0
. 2016-09-19 00:01:48.637 Prompt (7, SSH password, , &Password: )
. 2016-09-19 00:01:48.637 Using stored password.
. 2016-09-19 00:01:48.637 Sent password
. 2016-09-19 00:01:48.637 Waiting for the server to continue with the initialization
. 2016-09-19 00:01:48.637 Looking for incoming data
. 2016-09-19 00:01:48.637 Looking for network events
. 2016-09-19 00:01:48.686 Detected network event
. 2016-09-19 00:01:48.686 Enumerating network events for socket 808
. 2016-09-19 00:01:48.686 Enumerated 1 network events making 1 cumulative events for socket 808
. 2016-09-19 00:01:48.686 Handling network read event on socket 808 with error 0
. 2016-09-19 00:01:48.686 Access granted
. 2016-09-19 00:01:48.686 Opening session as main channel
. 2016-09-19 00:01:48.686 Waiting for the server to continue with the initialization
. 2016-09-19 00:01:48.686 Looking for incoming data
. 2016-09-19 00:01:48.686 Looking for network events
. 2016-09-19 00:01:48.726 Detected network event
. 2016-09-19 00:01:48.726 Enumerating network events for socket 808
. 2016-09-19 00:01:48.726 Enumerated 1 network events making 1 cumulative events for socket 808
. 2016-09-19 00:01:48.726 Handling network read event on socket 808 with error 0
. 2016-09-19 00:01:48.726 Opened main channel
. 2016-09-19 00:01:48.726 Waiting for the server to continue with the initialization
. 2016-09-19 00:01:48.726 Looking for incoming data
. 2016-09-19 00:01:48.726 Looking for network events
. 2016-09-19 00:01:48.866 Detected network event
. 2016-09-19 00:01:48.866 Enumerating network events for socket 808
. 2016-09-19 00:01:48.866 Enumerated 1 network events making 1 cumulative events for socket 808
. 2016-09-19 00:01:48.866 Handling network read event on socket 808 with error 0
. 2016-09-19 00:01:48.866 Started a shell/command
. 2016-09-19 00:01:48.866 --------------------------------------------------------------------------
. 2016-09-19 00:01:48.866 Using SFTP protocol.
. 2016-09-19 00:01:48.868 Doing startup conversation with host.
> 2016-09-19 00:01:48.869 Type: SSH_FXP_INIT, Size: 5, Number: -1
> 2016-09-19 00:01:48.869 01,00,00,00,05,
. 2016-09-19 00:01:48.869 Sent 9 bytes
. 2016-09-19 00:01:48.869 There are 0 bytes remaining in the send buffer
. 2016-09-19 00:01:48.869 Looking for network events
. 2016-09-19 00:01:48.869 Timeout waiting for network events
. 2016-09-19 00:01:48.869 Waiting for another 4 bytes
. 2016-09-19 00:01:48.869 Looking for incoming data
. 2016-09-19 00:01:48.909 Detected network event
. 2016-09-19 00:01:48.909 Enumerating network events for socket 808
. 2016-09-19 00:01:48.909 Enumerated 1 network events making 1 cumulative events for socket 808
. 2016-09-19 00:01:48.909 Handling network read event on socket 808 with error 0
. 2016-09-19 00:01:48.909 Received 9 bytes (0)
. 2016-09-19 00:01:48.909 Read 4 bytes (5 pending)
. 2016-09-19 00:01:48.909 Read 5 bytes (0 pending)
< 2016-09-19 00:01:48.909 Type: SSH_FXP_VERSION, Size: 5, Number: -1
< 2016-09-19 00:01:48.909 02,00,00,00,04,
. 2016-09-19 00:01:48.909 SFTP version 4 negotiated.
. 2016-09-19 00:01:48.909 We will use UTF-8 strings when appropriate
. 2016-09-19 00:01:48.910 Getting current directory name.
. 2016-09-19 00:01:48.910 Getting real path for '.'
> 2016-09-19 00:01:48.910 Type: SSH_FXP_REALPATH, Size: 10, Number: 16
> 2016-09-19 00:01:48.910 10,00,00,00,10,00,00,00,01,2E,
. 2016-09-19 00:01:48.910 Sent 14 bytes
. 2016-09-19 00:01:48.910 There are 0 bytes remaining in the send buffer
. 2016-09-19 00:01:48.910 Looking for network events
. 2016-09-19 00:01:48.910 Timeout waiting for network events
. 2016-09-19 00:01:48.910 Waiting for another 4 bytes
. 2016-09-19 00:01:48.910 Looking for incoming data
. 2016-09-19 00:01:48.976 Detected network event
. 2016-09-19 00:01:48.976 Enumerating network events for socket 808
. 2016-09-19 00:01:48.976 Enumerated 1 network events making 1 cumulative events for socket 808
. 2016-09-19 00:01:48.976 Handling network read event on socket 808 with error 0
. 2016-09-19 00:01:48.976 Received 27 bytes (0)
. 2016-09-19 00:01:48.976 Read 4 bytes (23 pending)
. 2016-09-19 00:01:48.976 Read 23 bytes (0 pending)
< 2016-09-19 00:01:48.976 Type: SSH_FXP_NAME, Size: 23, Number: 16
< 2016-09-19 00:01:48.976 68,00,00,00,10,00,00,00,01,00,00,00,01,2F,00,00,00,04,02,00,00,01,E8,
. 2016-09-19 00:01:48.977 Real path is '/'
. 2016-09-19 00:01:48.977 Startup conversation with host finished.
< 2016-09-19 00:01:48.977 Script: Active session: [1] <...>. 2016-09-19 00:01:48.977 Session upkeep
. 2016-09-19 00:01:48.977 Looking for network events
. 2016-09-19 00:01:48.977 Timeout waiting for network events
> 2016-09-19 00:01:48.977 Script: put -nopreservetime -resumesupport=off \\<...>\Upload\* ./Statements/ -transfer=automatic
. 2016-09-19 00:01:48.979 Copying 2 files/directories to remote directory "./Statements/"
. 2016-09-19 00:01:48.979 PrTime: No; PrRO: No; Rght: rw-r--r--; PrR: No (No); FnCs: N; RIC: 0100; Resume: N (102400); CalcS: No; Mask:
. 2016-09-19 00:01:48.979 TM: M; ClAr: No; RemEOF: No; RemBOM: No; CPS: 0; NewerOnly: No; InclM:
. 2016-09-19 00:01:48.979 AscM: *.*html; *.htm; *.txt; *.php; *.php3; *.cgi; *.c; *.cpp; *.h; *.pas; *.bas; *.tex; *.pl; *.js; .htaccess; *.xtml; *.css; *.cfg; *.ini; *.sh; *.xml
. 2016-09-19 00:01:48.980 File: '\\<...>_20160919.pdf' [2016-09-19T05:01:44.775Z] [45372]
. 2016-09-19 00:01:48.981 Copying "\\<...>_20160919.pdf" to remote directory started.
. 2016-09-19 00:01:48.981 Binary transfer mode selected.
. 2016-09-19 00:01:48.981 Opening remote file.
> 2016-09-19 00:01:48.981 Type: SSH_FXP_OPEN, Size: 72, Number: 259
> 2016-09-19 00:01:48.981 03,00,00,01,03,00,00,00,2E,2F,53,74,61,74,65,6D,65,6E,74,73,2F,4D,49,30,31,
> 2016-09-19 00:01:48.981 2E,43,6F,6C,6C,65,63,74,69,6F,6E,4C,65,74,74,65,72,5F,32,30,31,36,30,39,31,
> 2016-09-19 00:01:48.981 39,2E,70,64,66,00,00,00,1A,00,00,00,01,01,00,00,00,00,00,00,B1,3C,
. 2016-09-19 00:01:48.981 Sent 76 bytes
. 2016-09-19 00:01:48.981 There are 0 bytes remaining in the send buffer
. 2016-09-19 00:01:48.981 Looking for network events
. 2016-09-19 00:01:48.981 Timeout waiting for network events
. 2016-09-19 00:01:48.981 Waiting for another 4 bytes
. 2016-09-19 00:01:48.981 Looking for incoming data
. 2016-09-19 00:01:49.050 Detected network event
. 2016-09-19 00:01:49.050 Enumerating network events for socket 808
. 2016-09-19 00:01:49.050 Enumerated 1 network events making 1 cumulative events for socket 808
. 2016-09-19 00:01:49.050 Handling network read event on socket 808 with error 0
. 2016-09-19 00:01:49.050 Received 16 bytes (0)
. 2016-09-19 00:01:49.050 Read 4 bytes (12 pending)
. 2016-09-19 00:01:49.050 Read 12 bytes (0 pending)
< 2016-09-19 00:01:49.050 Type: SSH_FXP_HANDLE, Size: 12, Number: 259
< 2016-09-19 00:01:49.050 66,00,00,01,03,00,00,00,03,31,33,37,
. 2016-09-19 00:01:49.050 Write request offset: 0, len: 4096
> 2016-09-19 00:01:49.050 Type: SSH_FXP_WRITE, Size: 4120, Number: 774
> 2016-09-19 00:01:49.051 5,
> 2016-09-19 00:01:49.051 A,
> 2016-09-19 00:01:49.051 F,
> 2016-09-19 00:01:49.051 C,
> 2016-09-19 00:01:49.052 5,
> 2016-09-19 00:01:49.052 3,
> 2016-09-19 00:01:49.052 9,
> 2016-09-19 00:01:49.052 F,
> 2016-09-19 00:01:49.052 A,
> 2016-09-19 00:01:49.052 C,
> 2016-09-19 00:01:49.052 7,
> 2016-09-19 00:01:49.052 0,
> 2016-09-19 00:01:49.052 B,
> 2016-09-19 00:01:49.052 2,
> 2016-09-19 00:01:49.052 4,
> 2016-09-19 00:01:49.052 E,
> 2016-09-19 00:01:49.052 D,
> 2016-09-19 00:01:49.052 6,
> 2016-09-19 00:01:49.052 8,
> 2016-09-19 00:01:49.052 1,
> 2016-09-19 00:01:49.053 F,
> 2016-09-19 00:01:49.053 8,
> 2016-09-19 00:01:49.053 3,
> 2016-09-19 00:01:49.053 5,
> 2016-09-19 00:01:49.053 C,
> 2016-09-19 00:01:49.053 4,
> 2016-09-19 00:01:49.053 0,
> 2016-09-19 00:01:49.053 E,
> 2016-09-19 00:01:49.053 B,
> 2016-09-19 00:01:49.053 1,
> 2016-09-19 00:01:49.053 6,
. 2016-09-19 00:01:49.053
> 2016-09-19 00:01:49.054 B,
> 2016-09-19 00:01:49.054 8,
> 2016-09-19 00:01:49.054 6,
> 2016-09-19 00:01:49.054 5,
> 2016-09-19 00:01:49.054 0,
> 2016-09-19 00:01:49.054 C,
> 2016-09-19 00:01:49.054 F,
> 2016-09-19 00:01:49.054 A,
> 2016-09-19 00:01:49.054 7,
> 2016-09-19 00:01:49.054 D,
> 2016-09-19 00:01:49.054 E,
> 2016-09-19 00:01:49.054 1,
> 2016-09-19 00:01:49.054 4,
> 2016-09-19 00:01:49.054 3,
> 2016-09-19 00:01:49.054 9,
> 2016-09-19 00:01:49.054 2,
> 2016-09-19 00:01:49.055 5,
> 2016-09-19 00:01:49.055 2,
> 2016-09-19 00:01:49.055 6,
> 2016-09-19 00:01:49.055 E,
> 2016-09-19 00:01:49.055 9,
> 2016-09-19 00:01:49.055 4,
> 2016-09-19 00:01:49.055 1,
> 2016-09-19 00:01:49.055 3,
> 2016-09-19 00:01:49.055 D,
> 2016-09-19 00:01:49.055 7,
> 2016-09-19 00:01:49.055 0,
> 2016-09-19 00:01:49.055 C,
> 2016-09-19 00:01:49.055 F,
> 2016-09-19 00:01:49.055 B,
> 2016-09-19 00:01:49.055 8,
> 2016-09-19 00:01:49.055 A,
. 2016-09-19 00:01:49.055
> 2016-09-19 00:01:49.056 7,
> 2016-09-19 00:01:49.056 2,
> 2016-09-19 00:01:49.056 1,
> 2016-09-19 00:01:49.056 5,
> 2016-09-19 00:01:49.057 B,
> 2016-09-19 00:01:49.057 D,
> 2016-09-19 00:01:49.057 2,
> 2016-09-19 00:01:49.057 9,
> 2016-09-19 00:01:49.057 3,
> 2016-09-19 00:01:49.057 1,
> 2016-09-19 00:01:49.057 0,
> 2016-09-19 00:01:49.057 5,
> 2016-09-19 00:01:49.057 7,
> 2016-09-19 00:01:49.057 6,
> 2016-09-19 00:01:49.057 8,
> 2016-09-19 00:01:49.057 A,
> 2016-09-19 00:01:49.057 F,
> 2016-09-19 00:01:49.057 4,
> 2016-09-19 00:01:49.057 C,
> 2016-09-19 00:01:49.057 E,
> 2016-09-19 00:01:49.058 7,
> 2016-09-19 00:01:49.058 8,
> 2016-09-19 00:01:49.058 A,
> 2016-09-19 00:01:49.058 C,
> 2016-09-19 00:01:49.058 F,
> 2016-09-19 00:01:49.058 5,
> 2016-09-19 00:01:49.058 1,
. 2016-09-19 00:01:49.058
> 2016-09-19 00:01:49.059 E,
> 2016-09-19 00:01:49.059 5,
> 2016-09-19 00:01:49.059 0,
> 2016-09-19 00:01:49.059 1,
> 2016-09-19 00:01:49.059 C,
> 2016-09-19 00:01:49.059 8,
> 2016-09-19 00:01:49.059 7,
> 2016-09-19 00:01:49.059 2,
> 2016-09-19 00:01:49.059 6,
> 2016-09-19 00:01:49.059 A,
> 2016-09-19 00:01:49.059 3,
> 2016-09-19 00:01:49.059 F,
> 2016-09-19 00:01:49.059 D,
> 2016-09-19 00:01:49.059 4,
> 2016-09-19 00:01:49.059 B,
> 2016-09-19 00:01:49.059 9,
> 2016-09-19 00:01:49.060 9,
> 2016-09-19 00:01:49.060 D,
> 2016-09-19 00:01:49.060 0,
> 2016-09-19 00:01:49.060 F,
> 2016-09-19 00:01:49.060 1,
> 2016-09-19 00:01:49.060 A,
> 2016-09-19 00:01:49.060 8,
> 2016-09-19 00:01:49.060 4,
> 2016-09-19 00:01:49.060 5,
> 2016-09-19 00:01:49.060 7,
> 2016-09-19 00:01:49.060 6,
> 2016-09-19 00:01:49.060 3,
> 2016-09-19 00:01:49.060 2,
> 2016-09-19 00:01:49.060 C,
> 2016-09-19 00:01:49.060 B,
> 2016-09-19 00:01:49.060 E,
. 2016-09-19 00:01:49.060 Sent 4124 bytes
. 2016-09-19 00:01:49.060 There are 0 bytes remaining in the send buffer
. 2016-09-19 00:01:49.060 Looking for network events
. 2016-09-19 00:01:49.060 Timeout waiting for network events
. 2016-09-19 00:01:49.060 Write request offset: 16384, len: 28988
> 2016-09-19 00:01:49.060 Type: SSH_FXP_WRITE, Size: 29012, Number: 1798
> 2016-09-19 00:01:49.068
> 2016-09-19 00:01:49.069
> 2016-09-19 00:01:49.070
> 2016-09-19 00:01:49.071
> 2016-09-19 00:01:49.072
> 2016-09-19 00:01:49.073
> 2016-09-19 00:01:49.074
> 2016-0
  • winscpLog.txt (256.12 KB, Private file)
Description: winscp log
Re: winscp (sftp) occasionally fails to transfer files from AWS server to the remote 3rd party server.
First, please upgrade to the latest version of WinSCP.
mshaik
sioux falls
Good morning Martin,
I have upgraded to the latest version of winSCP and attached the winscp log for your reference. The problem still exist and we are facing lot of pressure now regarding this issue. The file partially transferred and timed out waiting for some network event. Let me know your thoughts and if the winscp log helps.
And also please observe line number 6533 where we got multiple network events.
Thanks in advance for your help.
Thanks & Regards,
Mohamed.
  • winscp-qps-tarnsfer.log (1.14 MB, Private file)
Description: winscp log while for your reference
mshaik
sioux falls
I was not able to identify cause of the problem.
Did you try to disable the "Optimize connection buffer size" option, as suggested in the error message?
Use -rawsettings SendBuf=0
https://winscp.net/eng/docs/message_host_is_not_communicating
https://winscp.net/eng/docs/rawsettings
Good Morning Martin,
Thanks for your quick response. I tried but it did not work. Increased the timeout limit also, still did not work. And Our IT working with AWS and so far no luck to resolve this issue.I guess the issue appears to be receive network events. If you look at the log that I attached earlier, a network event received at line 6552 of 21 bytes. after that another network event received of 21 bytes at line 6565. The second one appears to be out of sequence. Its just my guess.
Any thoughts on this will be help us a lot.
Thanks & Regards,
Mo.
Sorry, I do not see anything related on line 6552 in either log. Which log do you mean? Can you quote the line?
