Topic "Keep Local directoty up to Date. (Auto Syncronize?)"
I have an ftp server there the files there get updated/ modified and get new timestamps. Then this happened I want to download the files to my local computer. I think it is contrariwise to that the button Keep Remote directoty up to Date works.
If I press the Syncronize button its works fine, the files on my local computer is updated. But I have to press the button every time, I want it to do itself for say 1 or 5 minutes. Så my local folder “always” is synchronized.
I see people are talking about scripts is that this way I have to do, or have I misunderstand the settings in the software?
/Antigonos
I found a powershell script in Extensions that do what i want, i should try KeepLocalUpToDate.WinSCPextension.ps1 later.
Sorry for that i dont find it before i asked.
//Antigonos
https://winscp.net/eng/docs/library_example_keep_local_directory_up_to_date
Search
