Task Scheduler error, but when run manually no error
mcruz
Puerto Rico
Hi to all.
I have created the following batch:
option batch abort
open ftp://(USER):(PASSWORD)@ftp.com/folder/inbox/ -explicittls
put "Y:\*"
close
When i run it manually (double click to it) it will run with no problems. But if i put it in a task scheduler to run it give me the following error.
C:\Program Files (x86)\WinSCP>winscp.com /script=SyncToRemoteScript.txt
batch abort
reconnecttime 120
confirm off
Connecting to ftp.com ...
TLS connection established. Waiting for welcome message...
Connected
Starting the session...
Session started.
Active session: [1] ***@ftp.com
No file matching '*' found. (System Error. Code: 3.
The system cannot find the path specified)
Session '***@ftp.com' closed.
No session.
but if i run it manually
batch abort
reconnecttime 120
confirm off
Connected
Session started.
PR7_MN32_10242016_122526_ | 328 B | 1.4 KB/s | binary | 100%
No session.
Would you help to solve this,
Re: Task Scheduler error, but when run manually no error
I assume the problem is that the account that drives your task scheduler task does not see the Y: drive or does not have a network access at all. Try doing dir Y:\ in your task.
