PowerShell script – Get Files / Change Name / Move to another folder
vinicostasantos1
Hi guys,
Could someone please help me with this question?
I'm trying to use this site example to DOWNLOAD files but I'm having a issue:
https://winscp.net/eng/docs/script_locking_files_while_uploading#rename
I'm having a error when the script try to move the renamed file:
"Error: Error moving file 'G:\temporary_localpath\._filepart' to 'G:localpathnewfilename'
Could someone please please help me with this? Here is the script:
param (
    $localPath = "\localpath\",
    $remotePath = "/remotepath/",
try
    # Load WinSCP .NET assembly
    Add-Type -Path "C:\WinSCP\WinSCPnet.dll"
    # Setup session options
    $sessionOptions.Protocol = [WinSCP.Protocol]::Sftp
    $sessionOptions.HostName = "****"
    $sessionOptions.UserName = "****"
    $sessionOptions.Password = "****"
    $sessionOptions.SshHostKeyFingerprint = "************"
    try
        $suffix = "_filepart"
        $transferOptions.ResumeSupport.State =
            [WinSCP.TransferResumeSupportState]::Off
        $transferResult =
        $session.GetFiles(
            ($remotePath + "*.*"), ($localPath + "*.*" + $suffix),
            $False, $transferOptions)
        $transferResult.Check()
        foreach ($transfer in $transferResult.Transfers)
            $finalName =
                $transfer.Destination.Substring(0, $transfer.Destination.Length - $suffix.Length)
            Write-Host (
                "Renomeando arquivo {0} para o nome final" -f $transfer.Destination, $finalName)
            $session.MoveFile($transfer.Destination, $finalName)
    finally
        # Disconnect, clean up
        $session.Dispose()
    exit 0
catch [Exception]
    Write-Host ("Error: {0}" -f $_.Exception.Message)
    exit 1
Re: PowerShell script – Get Files / Change Name / Move to another folder
