WinSCP .net assembly file mask not working
cbickle
Here is the code, the file mask is not working - all files are being put on the ftp:
try
    # Connect
    $transferOptions.TransferMode = [WinSCP.TransferMode]::Binary
    $transferOptions.FileMask = ".txt"
   # Sync files local and delete any that are not on the SFTP
   $synchronizationResult = $session.SynchronizeDirectories([WinSCP.SynchronizationMode]::Remote, $SourcePath, $FtpPath, $True, $False, [WinSCP.SynchronizationCriteria]::Time, $transferOptions)
    # Throw on any error
    $synchronizationResult.Check()
finally
    # Disconnect, clean up
    $session.Dispose()
Re: WinSCP .net assembly file mask not working
