Timeout detected(data connection) Could not retrieve directory listing
SG_ebp
I got this error every time when I try to connect the FTP. Attached the Full Log file.
  • SCP.log (14.88 KB, Private file)
Description: Please find the attached Log file.
  • WinSCP_Error Screen.png (48.69 KB, Private file)
Description: Please find attached the
superiorus
Spain
Same problem here ... and I don't know what to do ...
Timeout detected. (data connection)
Error listing directory '/public_html/contents'.
SG_ebp
Re: Timeout detected(data connection) Could not retrieve directory listing
I cannot retrieve the directory listing using any other FTP client. It also gives error. I attached the screenshot of error as well.
Thanks for the links, but I already went through the links in the /docs section.
Only thing I need to check for the antivirus.
  • Error_Screen.png (9.86 KB, Private file)
Description: Error Screen
If no FTP client works, the FTP server (or its firewall) is probably misconfigured.
There nothing you can do on WinSCP side.
Read the link above to learn how to configure the FTP server/firewall properly.
Robert EM
This error showed up with a new FTP server I installed.
I know these are old posts but maybe someone searching for a solution might find this helpful: To get rid of this error I needed to enable passive mode on vsftpd running on RHEL 8.
