upload a file dont work
tomislav91
Here is a simple script to my domain linux pc. I have winscp and in that folder i put my script that I should upload and script for uploading that (first) script to pc.
But when open it, nothing happend, no errors, no nothing. And it didnt copy. sftp is opened, and with win scp GUI i can upload.
Where is mistake?
This is my .bat script
open sftp://myuser:mypassword@192.168.1.21/
put skrpta.sh /home/Test/Desktop
jrp78
SoVA
Try passing the complete local path. I used c:\folder as an example.
put c:\folder\skrpta.sh /home/Test/Desktop
If that fails, try adding the following switches to your script.
put c:\folder\skrpta.sh /home/Test/Desktop -nopreservetime -nopermissions
Re: upload a file dont work
How do you run this?
The above is not .bat (batch file), it's WinSCP script.
You have to run it using winscp.com, like:
winscp.com /script=upload.txt
Where the upload.txt is your ".bat script".
See also https://winscp.net/eng/docs/guide_automation
