Problem synchronize local
MICHAEL HUGE (abildoc)
I want to protect my FTP file transfer.
Randomly, I sometimes have a synchronization that does not happen.
I have many files in my remote folder. the command "synchonize local" returns "nothing to synchronize."
my files are not tranfered and as I delete all at the end then I lose my files.
this is my winscp script :
option echo off
option batch on
open ftp://***:***@****.abildoc.com
synchronize local C:\app-capture4invoice\FTP\WORK_TEMP\OUT\outbox-france\ /OUT/outbox-france
rm /OUT/outbox-france/*.*
close
My result with problem :
echo off
batch on
reconnecttime 120
confirm off
Connecting to ****.abildoc.com ...
Connected
Starting the session...
Session started.
Active session: [1] ****@****.abildoc.com
Comparing...
Local 'C:\app-capture4invoice\FTP\WORK_TEMP\OUT\outbox-france-rd' <= Remote '/OUT/outbox-france-rd'
Nothing to synchronize.
/OUT/outbox-france-rd/invoice-70636##$##_2016_10_24_14_23_584_45996622645.pdf
/OUT/outbox-france-rd/invoice-70636##$##_2016_10_24_14_23_584_45996622645.xml
/OUT/outbox-france-rd/invoice-70636##$##_2016_10_24_14_23_584_45996622646.pdf
/OUT/outbox-france-rd/invoice-70636##$##_2016_10_24_14_23_584_45996622646.xml
/OUT/outbox-france-rd/invoice-70636##$##_2016_10_24_14_23_584_45996622647.pdf
/OUT/outbox-france-rd/invoice-70636##$##_2016_10_24_14_23_584_45996622647.xml
Session '*****@*****.abildoc.com' closed.
No session.
How to verify my FTP transfert is OK before delete files ?
Thanks you for your help.
Best regards,
MICHAEL
Re: Problem synchronize local
Well, first your script is not safe. You remove the files after synchronization. What guarantees you that some files are not created between the synchronize and the rm?
See https://winscp.net/eng/docs/library_example_delete_after_successful_download
If you are sure, there's something wrong anyway, please attach a full session log file showing the problem (using the latest version of WinSCP).
thanks you for your fast answer.
But I don't a developper. I don't know .NET code.
I use only command line.
have you an example script (secure ftp transfert and delete files after success) with command line ?
Best regards,
MICHAEL
Sorry, but your scenario is so specific, that you cannot expect that a simple command-line interface supports it.
