Crash when remote current directory=""
TW
WinSCP 5.9.2 running on Windows 10 crashes while logging on a plain FTP session to an Isilon host.
I'll try to attach the WinSCP log file. In case I can't, the log file repeats the same 4 lines over 5000 times and then suddenly ends. Apparently, the server is reporting "" as the current working directory for this user.
> (timestamp) PWD
< (timestamp) 257 ""
. (timestamp) Got reply 1 to the command 16
. (timestamp) Getting current directory name.
TW
That does the PWD return when you are in a subfolder?
In a subfolder, it still returns 257 ""
The problem happens with a regular user but not with an ID that has full control of the file system. I'll eventually complain to Dell/EMC but for now I can't touch it.
