how to set the filter
lionelluo
hi,
how to set the download filter:
RPTXXX.313.downloaded%FT
RPTXXX.313
so only download file RPTXXX.313?
Thanks...
Re: how to set the filter
What is RPTXXX.313? Is a mask (the X's). Or is it a file name?
If it is a filename, you do not need any mask (filter). Just download the RPTXXX.313.
If it is a mask, just replace the X's with ?'s: RPT???.313 or with *: RPT*.313.
lionelluo
thanks for the help.
313 is from 001 to 999 number
RPTn.nnn: n is from 1-9
how to do the mask?
how to do the mask?
Would it be possible to downloads all files not ending in .downloaded instead of picking those up with .XXX? XXX is from 000-999
