Touchpad Scrolling on Windows 10
tehabe
When I try to scroll with my touchpad on Windows 10, not the file list but the window is "scrolled". (Windows 10 has this effect when you reach the end of the list, the window moves)
WinSCP 5.9.2
Windows 10.0 1607 (14393.447)
P.S. I can't rule out that this can also be a bug in the touchpad driver. But WinSCP is currently the only application in which I can reproduce this bug.
Re: Touchpad Scrolling on Windows 10
Do you get the same problem with directory tree? Or just a file list?
What does it mean "window is scrolled"?
What is your notebook and touchpad?
cbono360
I have a Dell XPS 13 9360. The scroll bar on the right moves up/down before springing back into place. The window stays exactly where it was. I haven't tried this with a mouse, only the touchpad.
usphi
touchpad can not scroll down or up
I got the same issue, Laptop touchpad can not scroll the page in tree or file list. Touch screen can do that!
Anonymous wrote:
I'm having the same problem. I can upload/email a video-recording of the issue if you'd like.
Brent
My problem was resolved by installed Dell's mouse driver. I have a Dell laptop, and for some reason it had a Microsoft driver instead of Dell's.
Thanks for sharing your solution!
JonhS
I'm using a Surface Pro 4 with it's touchpad keyboard so installing dell mouse drivers won't help. Can't scroll in either remote or local destination windows using the touchpad scroll gesture. An external mouse scrollwheel works normally though.
