Files displayed as Folders
Hi Guys,
I have just installed the latest version of OpenSSH on my Windows 10 desktop and have a netbook running Windows 7 pro connected to it using a LAN cable. I can log into the desktop using the latest version of WinSCP and Filzilla, but both display files in the right hand window as being folders. For example a text document is misidentified as being a folder of the same name. This becomes interesting when the tree view is used as everything in the directory listing is a folder! Also, when a file is transferred, the date and time stamps are not preserved and are reset to 01-01-1970 0:0:0. Any attempt to delete the file results in an error message (see log file). The same thing is true of FilZilla, the only difference is that Filezilla does delete the file and does not generate an error message.
I have set up OpenSSH in accordance with the instructions posted on the WinSCP site. The configuration is basically the default with the exception of the path to the OpenSSH binaries which is C:\OpenSSH and an additional Port entry for 443. The RSA Authorization file is at C:\Users\Administrator\.SSH and I am logged in as Administrator on both machines. There are no problems with logging in using RSA keys.
I have also tried PuTTY's sftp.exe and found that it preserves date and time stamps and works without any problems.
I think the problem is on the server side, but no amount of tinkering with the config file seems to help. Another possibility could be permissions on the Win 10 machine.
Any help would be greatly appreciated.
