How to compute TimeDifference raw setting - (time zone offset)
i'm using C# assembly, and i need to set TimeDifference raw setting like this.
sessionOptions.AddRawSettings("TimeDifference", "555555555555A5BF");
I got the hex 555555555555A5BF from winscp.ini that i saved after setting time zone offset.
The problem is that i need to know how to generate this hex.
Can someone help me with this.
Thanks.
Re: How to compute TimeDifference raw setting - (time zone offset)
Are you really sure you need to set this? You should only need to set it, when you are using FTP protocol with a server that does not support the MLSD command. In which case, make sure you are using the latest version of WinSCP and try calling Session.ListDirectory after logging in. It should allow WinSCP to autodetect the time difference. Post a log file if that does not help.
Good morning,
Yes, I'm connecting to a FTP server without MLSD support. I'm writing a file to the remote server and comparing the remote file timestamp with my local time in order to predict de time zone offset. Having this i was trying to set the raw setting TimeDifference, which works well if used with a value generated to winscp.ini. The problem is that i don't know how to convert a offset to this format.
Here is a piece of log. Thanks for your help.
2016-11-28 09:36:06.908 Using FTP protocol.
. 2016-11-28 09:36:06.910 Doing startup conversation with host.
> 2016-11-28 09:36:06.961 PWD
< 2016-11-28 09:36:07.290 257 "/" is current directory.
. 2016-11-28 09:36:07.290 Got reply 1 to the command 16
. 2016-11-28 09:36:07.290 Changing directory to "/pub".
> 2016-11-28 09:36:07.290 CWD /pub
< 2016-11-28 09:36:07.697 250 CWD command successful.
. 2016-11-28 09:36:07.697 Got reply 1 to the command 16
. 2016-11-28 09:36:07.697 Getting current directory name.
> 2016-11-28 09:36:07.697 PWD
< 2016-11-28 09:36:08.098 257 "/pub" is current directory.
. 2016-11-28 09:36:08.098 Got reply 1 to the command 16
. 2016-11-28 09:36:08.098 Session upkeep
. 2016-11-28 09:36:08.264 Retrieving directory listing...
> 2016-11-28 09:36:08.264 TYPE A
< 2016-11-28 09:36:08.499 200 Type set to "A".
> 2016-11-28 09:36:08.499 PASV
< 2016-11-28 09:36:08.901 227 Entering Passive Mode (XXX,XX,XX,XX,XX,XX)
> 2016-11-28 09:36:08.901 MLSD
. 2016-11-28 09:36:08.901 Connecting to XXX.XX.XX.XX:XXXXX ...
. 2016-11-28 09:36:08.974 Data connection opened
< 2016-11-28 09:36:09.303 500 [MLSD] not implemented yet.
. 2016-11-28 09:36:09.303 Could not retrieve directory listing
. 2016-11-28 09:36:09.303 Got reply 4 to the command 2
. 2016-11-28 09:36:09.303 Session upkeep
* 2016-11-28 09:36:09.364 (ECommand) Error listing directory '/pub'.
* 2016-11-28 09:36:09.364 Could not retrieve directory listing
* 2016-11-28 09:36:09.364 [MLSD] not implemented yet.
. 2016-11-28 09:36:10.364 Session upkeep
. 2016-11-28 09:36:11.364 Session upkeep
. 2016-11-28 09:36:12.364 Session upkeep
Hello again,
I have uploaded (using winscp) a file named 00000 for /pub/incoming of the following public ftp server ftp.swfwmd.state.fl.us:21
After that I've executed my test app (using .net assembly) and issued a session.ListDirectory() and the log shows the following:
My local time was 2016-11-28, 11:16:00 and the server time was 2016-11-28, 06:16.
< 2016-11-28 11:29:53.514 226 Directory send OK.
. 2016-11-28 11:29:53.514 Directory listing successful
. 2016-11-28 11:29:53.514 Detecting timezone difference...
. 2016-11-28 11:29:53.514 Retrieving file information...
> 2016-11-28 11:29:53.514 PWD
< 2016-11-28 11:29:53.670 257 "/pub/incoming"
> 2016-11-28 11:29:53.670 CWD /pub/incoming/00000
< 2016-11-28 11:29:53.819 550 Failed to change directory.
> 2016-11-28 11:29:53.819 TYPE I
< 2016-11-28 11:29:53.972 200 Switching to Binary mode.
> 2016-11-28 11:29:53.972 SIZE /pub/incoming/00000
< 2016-11-28 11:29:54.119 213 0
> 2016-11-28 11:29:54.119 MDTM /pub/incoming/00000
< 2016-11-28 11:29:54.268 213 20161128061617
. 2016-11-28 11:29:54.268 Retrieving file information successful
. 2016-11-28 11:29:54.268 No timezone difference detected using file /pub/incoming/00000 (Listing: 2016-11-28T06:16:00.000Z, UTF: 2016-11-28T06:16:00.000Z)
. 2016-11-28 11:29:54.268 ..;D;0;1899-12-30T00:00:00.000Z;0;"" [0];"" [0];---------;0
. 2016-11-28 11:29:54.268 00000;-;0;2016-11-28T06:16:00.000Z;1;"106" [0];"113" [0];rw-r--r--;0
. 2016-11-28 11:29:54.268 123.exe;-;673792;2016-11-26T19:16:00.000Z;1;"106" [0];"113" [0];rw-r--r--;0
. 2016-11-28 11:29:54.268 2016-11-monthly.txt;-;139;2016-11-24T08:28:00.000Z;1;"106" [0];"113" [0];rw-r--r--;0
. 2016-11-28 11:29:54.268 8orders.xml;-;1508;2016-11-27T17:06:00.000Z;1;"106" [0];"113" [0];rw-r--r--;0
. 2016-11-28 11:29:54.268 AripekaSpringshed.dbf;-;16016;2016-11-23T11:55:00.000Z;1;"106" [0];"113" [0];rw-r--r--;0
Thanks.
Please attach a complete log.
Good morning,
here is a complete log.
client time zone UTC
server time zone UTC-5
Execution steps:
1) Using winscp navigate to /pub/incoming
2) Using winscp upload a local file paris_2016_c_155.jpg into /pub/incoming
3) Using winscp to navigate to /pub/incoming and check that the time difference.
. 2016-11-30 09:28:24.419 --------------------------------------------------------------------------
. 2016-11-30 09:28:24.420 WinSCP Version 5.9.2 (Build 6958) (OS 6.1.7601 Service Pack 1 - Windows 7 Enterprise)
. 2016-11-30 09:28:24.421 Configuration: C:\Program Files (x86)\WinSCP\WinSCP.ini
. 2016-11-30 09:28:24.421 Log level: Debug 2, Logging passwords
. 2016-11-30 09:28:24.421 Local account: Domain\UserAcc
. 2016-11-30 09:28:24.421 Working directory: C:\Program Files (x86)\WinSCP
. 2016-11-30 09:28:24.421 Process ID: 7936
. 2016-11-30 09:28:24.421 Command-line: "C:\Program Files (x86)\WinSCP\WinSCP.exe"
. 2016-11-30 09:28:24.421 Time zone: Current: GMT+0, Standard: GMT+0 (GMT Standard Time), DST: GMT+1 (GMT Daylight Time), DST Start: 27-03-2016, DST End: 30-10-2016
. 2016-11-30 09:28:24.422 Login time: quaarta-feira, 30 de novembro de 2016 09:28:24
. 2016-11-30 09:28:24.422 --------------------------------------------------------------------------
. 2016-11-30 09:28:24.422 Session name: anonymous@ftp.swfwmd.state.fl.us (Site)
. 2016-11-30 09:28:24.422 Host name: ftp.swfwmd.state.fl.us (Port: 21)
. 2016-11-30 09:28:24.422 User name: anonymous (Password: test@gmail.com, Key file: No)
. 2016-11-30 09:28:24.422 Transfer Protocol: FTP
. 2016-11-30 09:28:24.422 Ping type: Dummy, Ping interval: 30 sec; Timeout: 15 sec
. 2016-11-30 09:28:24.422 Disable Nagle: No
. 2016-11-30 09:28:24.422 Proxy: None
. 2016-11-30 09:28:24.422 Send buffer: 262144
. 2016-11-30 09:28:24.422 UTF: Auto
. 2016-11-30 09:28:24.422 FTPS: None [Client certificate: No]
. 2016-11-30 09:28:24.422 FTP: Passive: Yes [Force IP: Auto]; MLSD: Auto [List all: Auto]; HOST: Auto
. 2016-11-30 09:28:24.422 Local directory: C:\Users\UserAcc\Documents, Remote directory: /pub/incoming, Update: No, Cache: Yes
. 2016-11-30 09:28:24.422 Cache directory changes: Yes, Permanent: Yes
. 2016-11-30 09:28:24.422 Recycle bin: Delete to: No, Overwritten to: No, Bin path:
. 2016-11-30 09:28:24.422 Timezone offset: 0h 0m
. 2016-11-30 09:28:24.424 Session upkeep
. 2016-11-30 09:28:24.703 Connecting to ftp.swfwmd.state.fl.us ...
. 2016-11-30 09:28:25.289 Connected with ftp.swfwmd.state.fl.us. Waiting for welcome message...
< 2016-11-30 09:28:25.448 220--------------------------------------------------------------------------
< 2016-11-30 09:28:25.448 220- Unauthorized access and/or misuse of this FTP server is strictly
< 2016-11-30 09:28:25.448 220- prohibited. All connections and activity to this server are logged,
< 2016-11-30 09:28:25.448 220- monitored, and subject to public inspection.
< 2016-11-30 09:28:25.448 220- Reverse IP-address lookups are in effect. You will not be able to
< 2016-11-30 09:28:25.448 220- access this FTP server if your internet domain name server is not
< 2016-11-30 09:28:25.448 220- properly configured to do reverse IP-address mapping. Contact your
< 2016-11-30 09:28:25.448 220- Internet Service Provider or network administrator for more infomation
< 2016-11-30 09:28:25.647 220- on this topic.
< 2016-11-30 09:28:25.647 220--------------------------------------------------------------------------
> 2016-11-30 09:28:25.647 USER anonymous
< 2016-11-30 09:28:25.795 331 Please specify the password.
> 2016-11-30 09:28:25.795 PASS test@gmail.com
< 2016-11-30 09:28:25.945 230 Login successful.
> 2016-11-30 09:28:25.945 SYST
< 2016-11-30 09:28:26.092 215 UNIX Type: L8
> 2016-11-30 09:28:26.092 FEAT
< 2016-11-30 09:28:26.240 211-Features:
< 2016-11-30 09:28:26.240 EPRT
< 2016-11-30 09:28:26.240 EPSV
< 2016-11-30 09:28:26.240 MDTM
< 2016-11-30 09:28:26.240 PASV
< 2016-11-30 09:28:26.240 REST STREAM
< 2016-11-30 09:28:26.240 SIZE
< 2016-11-30 09:28:26.240 TVFS
< 2016-11-30 09:28:26.240 UTF8
< 2016-11-30 09:28:26.240 211 End
> 2016-11-30 09:28:26.240 OPTS UTF8 ON
< 2016-11-30 09:28:26.385 200 Always in UTF8 mode.
. 2016-11-30 09:28:26.385 Session upkeep
. 2016-11-30 09:28:26.407 Connected
. 2016-11-30 09:28:26.408 Got reply 1 to the command 1
. 2016-11-30 09:28:26.408 --------------------------------------------------------------------------
. 2016-11-30 09:28:26.408 Using FTP protocol.
. 2016-11-30 09:28:26.409 Doing startup conversation with host.
> 2016-11-30 09:28:26.460 PWD
< 2016-11-30 09:28:26.607 257 "/"
. 2016-11-30 09:28:26.607 Got reply 1 to the command 16
. 2016-11-30 09:28:26.607 Changing directory to "/pub/incoming".
> 2016-11-30 09:28:26.607 CWD /pub/incoming
< 2016-11-30 09:28:26.754 250 Directory successfully changed.
. 2016-11-30 09:28:26.754 Got reply 1 to the command 16
. 2016-11-30 09:28:26.754 Getting current directory name.
> 2016-11-30 09:28:26.754 PWD
< 2016-11-30 09:28:26.901 257 "/pub/incoming"
. 2016-11-30 09:28:26.901 Got reply 1 to the command 16
. 2016-11-30 09:28:26.901 Session upkeep
. 2016-11-30 09:28:27.063 Retrieving directory listing...
> 2016-11-30 09:28:27.063 TYPE A
< 2016-11-30 09:28:27.210 200 Switching to ASCII mode.
> 2016-11-30 09:28:27.210 PASV
< 2016-11-30 09:28:27.356 227 Entering Passive Mode (204,76,241,31,58,194).
> 2016-11-30 09:28:27.356 LIST -a
. 2016-11-30 09:28:27.356 Connecting to 204.76.241.31:15042 ...
. 2016-11-30 09:28:27.507 Data connection opened
< 2016-11-30 09:28:27.649 150 Here comes the directory listing.
. 2016-11-30 09:28:27.649 Session upkeep
. 2016-11-30 09:28:27.763 Data connection closed
. 2016-11-30 09:28:27.763 drwxr-xr-x 3 106 113 1200128 Nov 30 03:59 .
. 2016-11-30 09:28:27.763 drwxr-xr-x 32 0 0 4096 Jun 30 12:11 ..
. 2016-11-30 09:28:27.763 -rw-r--r-- 1 106 113 1022048 Nov 30 02:33 286968-michael-jackson.jpg
. 2016-11-30 09:28:27.763 -rw-r--r-- 1 106 113 282902 Nov 30 02:33 325268.jpg
. 2016-11-30 09:28:27.763 -rw-r--r-- 1 106 113 623980 Nov 30 02:33 427687.jpg
. 2016-11-30 09:28:27.763 -rw-r--r-- 1 106 113 212708 Nov 30 02:33 432142.jpg
. 2016-11-30 09:28:27.763 -rw-r--r-- 1 106 113 174680 Nov 30 02:33 481483.jpg
. 2016-11-30 09:28:27.763 -rw-r--r-- 1 106 113 806951 Nov 30 02:33 539400.jpg
. 2016-11-30 09:28:27.763 -rw-r--r-- 1 106 113 3516049 Nov 30 02:34 640719.jpg
. 2016-11-30 09:28:27.763 -rw-r--r-- 1 106 113 16016 Nov 23 11:55 AripekaSpringshed.dbf
. 2016-11-30 09:28:27.763 -rw-r--r-- 1 106 113 517 Nov 23 11:55 AripekaSpringshed.prj
. 2016-11-30 09:28:27.763 -rw-r--r-- 1 106 113 132 Nov 23 11:55 AripekaSpringshed.sbn
. 2016-11-30 09:28:27.763 -rw-r--r-- 1 106 113 116 Nov 23 11:55 AripekaSpringshed.sbx
. 2016-11-30 09:28:27.763 -rw-r--r-- 1 106 113 13308 Nov 23 11:55 AripekaSpringshed.shp
. 2016-11-30 09:28:27.763 -rw-r--r-- 1 106 113 190743 Nov 23 11:55 AripekaSpringshed.shp.xml
. 2016-11-30 09:28:27.763 -rw-r--r-- 1 106 113 108 Nov 23 11:55 AripekaSpringshed.shx
. 2016-11-30 09:28:27.763 -rw-r--r-- 1 106 113 806 Nov 23 11:54 CrewsLake.dbf
. 2016-11-30 09:28:27.763 -rw-r--r-- 1 106 113 517 Nov 23 11:54 CrewsLake.prj
. 2016-11-30 09:28:27.763 -rw-r--r-- 1 106 113 156 Nov 23 11:54 CrewsLake.sbn
. 2016-11-30 09:28:27.763 -rw-r--r-- 1 106 113 124 Nov 23 11:53 CrewsLake.sbx
. 2016-11-30 09:28:27.763 -rw-r--r-- 1 106 113 18456 Nov 23 11:53 CrewsLake.shp
. 2016-11-30 09:28:27.763 -rw-r--r-- 1 106 113 11816 Nov 23 11:54 CrewsLake.shp.xml
. 2016-11-30 09:28:27.763 -rw-r--r-- 1 106 113 116 Nov 23 11:54 CrewsLake.shx
. 2016-11-30 09:28:27.763 -rw-r--r-- 1 106 113 1456 Nov 23 11:54 EmbassyHillsNWRRIB.dbf
. 2016-11-30 09:28:27.763 -rw-r--r-- 1 106 113 517 Nov 23 11:54 EmbassyHillsNWRRIB.prj
. 2016-11-30 09:28:27.763 -rw-r--r-- 1 106 113 148 Nov 23 11:54 EmbassyHillsNWRRIB.sbn
. 2016-11-30 09:28:27.763 -rw-r--r-- 1 106 113 116 Nov 23 11:54 EmbassyHillsNWRRIB.sbx
. 2016-11-30 09:28:27.763 -rw-r--r-- 1 106 113 128 Nov 23 11:54 EmbassyHillsNWRRIB.shp
. 2016-11-30 09:28:27.763 -rw-r--r-- 1 106 113 18568 Nov 23 11:54 EmbassyHillsNWRRIB.shp.xml
. 2016-11-30 09:28:27.763 -rw-r--r-- 1 106 113 108 Nov 23 11:54 EmbassyHillsNWRRIB.shx
. 2016-11-30 09:28:27.763 -rw-r--r-- 1 106 113 29288814 Nov 23 11:54 MajorRoads.dbf
. 2016-11-30 09:28:27.763 -rw-r--r-- 1 106 113 676 Nov 23 11:54 MajorRoads.prj
. 2016-11-30 09:28:27.763 -rw-r--r-- 1 106 113 304236 Nov 23 11:54 MajorRoads.sbn
. 2016-11-30 09:28:27.763 -rw-r--r-- 1 106 113 13732 Nov 23 11:54 MajorRoads.sbx
. 2016-11-30 09:28:27.763 -rw-r--r-- 1 106 113 7294260 Nov 23 11:54 MajorRoads.shp
. 2016-11-30 09:28:27.763 -rw-r--r-- 1 106 113 64851 Nov 23 11:54 MajorRoads.shp.xml
. 2016-11-30 09:28:27.763 -rw-r--r-- 1 106 113 257860 Nov 23 11:54 MajorRoads.shx
. 2016-11-30 09:28:27.763 -rw-r--r-- 1 106 113 336 Nov 23 11:54 PascoCounty.dbf
. 2016-11-30 09:28:27.763 -rw-r--r-- 1 106 113 676 Nov 23 11:54 PascoCounty.prj
. 2016-11-30 09:28:27.763 -rw-r--r-- 1 106 113 164 Nov 23 11:54 PascoCounty.sbn
. 2016-11-30 09:28:27.763 -rw-r--r-- 1 106 113 124 Nov 23 11:54 PascoCounty.sbx
. 2016-11-30 09:28:27.763 -rw-r--r-- 1 106 113 361124 Nov 23 11:54 PascoCounty.shp
. 2016-11-30 09:28:27.763 -rw-r--r-- 1 106 113 20143 Nov 23 11:54 PascoCounty.shp.xml
. 2016-11-30 09:28:27.763 -rw-r--r-- 1 106 113 116 Nov 23 11:54 PascoCounty.shx
. 2016-11-30 09:28:27.763 -rw-r--r-- 1 106 113 4272654 Nov 23 11:55 ReclaimedPipeline.dbf
. 2016-11-30 09:28:27.764 -rw-r--r-- 1 106 113 517 Nov 23 11:55 ReclaimedPipeline.prj
. 2016-11-30 09:28:27.764 -rw-r--r-- 1 106 113 31292 Nov 23 11:55 ReclaimedPipeline.sbn
. 2016-11-30 09:28:27.764 -rw-r--r-- 1 106 113 1604 Nov 23 11:55 ReclaimedPipeline.sbx
. 2016-11-30 09:28:27.764 -rw-r--r-- 1 106 113 878736 Nov 23 11:55 ReclaimedPipeline.shp
. 2016-11-30 09:28:27.764 -rw-r--r-- 1 106 113 21122 Nov 23 11:55 ReclaimedPipeline.shp.xml
. 2016-11-30 09:28:27.764 -rw-r--r-- 1 106 113 25756 Nov 23 11:55 ReclaimedPipeline.shx
. 2016-11-30 09:28:27.764 -rw-r--r-- 1 106 113 1276 Nov 23 11:55 ShadyHillsWWTP.dbf
. 2016-11-30 09:28:27.764 -rw-r--r-- 1 106 113 517 Nov 23 11:55 ShadyHillsWWTP.prj
. 2016-11-30 09:28:27.764 -rw-r--r-- 1 106 113 148 Nov 23 11:55 ShadyHillsWWTP.sbn
. 2016-11-30 09:28:27.764 -rw-r--r-- 1 106 113 116 Nov 23 11:55 ShadyHillsWWTP.sbx
. 2016-11-30 09:28:27.764 -rw-r--r-- 1 106 113 128 Nov 23 11:55 ShadyHillsWWTP.shp
. 2016-11-30 09:28:27.764 -rw-r--r-- 1 106 113 211837 Nov 23 11:55 ShadyHillsWWTP.shp.xml
. 2016-11-30 09:28:27.764 -rw-r--r-- 1 106 113 108 Nov 23 11:55 ShadyHillsWWTP.shx
. 2016-11-30 09:28:27.764 -rw-r--r-- 1 106 113 524288 Nov 22 08:54 USGS_BagleyCove_Discharge_Retrieved_11-05-2016.xlsx
. 2016-11-30 09:28:27.764 -rw-r--r-- 1 106 113 2394 Nov 23 11:55 WeekiWacheeSpringshed.dbf
. 2016-11-30 09:28:27.764 -rw-r--r-- 1 106 113 517 Nov 23 11:55 WeekiWacheeSpringshed.prj
. 2016-11-30 09:28:27.764 -rw-r--r-- 1 106 113 132 Nov 23 11:55 WeekiWacheeSpringshed.sbn
. 2016-11-30 09:28:27.764 -rw-r--r-- 1 106 113 116 Nov 23 11:55 WeekiWacheeSpringshed.sbx
. 2016-11-30 09:28:27.764 -rw-r--r-- 1 106 113 10156 Nov 23 11:55 WeekiWacheeSpringshed.shp
. 2016-11-30 09:28:27.764 -rw-r--r-- 1 106 113 95302 Nov 23 11:55 WeekiWacheeSpringshed.shp.xml
. 2016-11-30 09:28:27.764 -rw-r--r-- 1 106 113 108 Nov 23 11:55 WeekiWacheeSpringshed.shx
. 2016-11-30 09:28:27.764 -rw-r--r-- 1 106 113 4463 Nov 29 14:18 __test__00018454.txt
. 2016-11-30 09:28:27.764 -rw-r--r-- 1 106 113 4080 Nov 29 14:20 __test__00020268.txt
. 2016-11-30 09:28:27.764 -rw-r--r-- 1 106 113 587240 Nov 30 03:59 amazon-search-1.png
. 2016-11-30 09:28:27.764 drw-r--r-- 2 0 0 49152 Jul 16 2013 lost+found
. 2016-11-30 09:28:27.764 -rw-r--r-- 1 106 113 74787 Nov 30 02:34 michael-jackson-by-gottfried-helnwein.jpg
. 2016-11-30 09:28:27.764 -rw-r--r-- 1 106 113 103222 Nov 30 02:34 michael-jackson-by-robert-deutsch-rare-1995.jpg
. 2016-11-30 09:28:27.764 -rw-r--r-- 1 106 113 54389 Nov 30 02:34 michael-jackson-earth-song-rare03.jpg
. 2016-11-30 09:28:27.764 -rw-r--r-- 1 106 113 45112 Nov 30 02:34 michael-jackson-history-childhood-lollipop-rare02.jpg
. 2016-11-30 09:28:27.764 -rw-r--r-- 1 106 113 40606 Nov 30 02:34 michael-jackson-lori-stoll-rare06.jpg
. 2016-11-30 09:28:27.764 -rw-r--r-- 1 106 113 34289 Nov 30 02:34 michael-jackson-older-rare01.jpg
. 2016-11-30 09:28:27.764 -rw-r--r-- 1 106 113 173348 Nov 30 02:34 michael-jackson-with-children-rare01.jpg
. 2016-11-30 09:28:27.764 -rw-r--r-- 1 106 113 6790 Nov 30 02:34 mj1.jpg
. 2016-11-30 09:28:27.764 -rw-r--r-- 1 106 113 6642 Nov 30 02:34 mj2.jpg
. 2016-11-30 09:28:27.764 -rw-r--r-- 1 106 113 8547 Nov 30 02:34 mj3.jpg
. 2016-11-30 09:28:27.764 -rw-r--r-- 1 106 113 6771 Nov 30 02:34 mj4.jpg
. 2016-11-30 09:28:27.764 -rw-r--r-- 1 106 113 98738 Nov 30 02:34 picture132.jpg
< 2016-11-30 09:28:27.844 226 Directory send OK.
. 2016-11-30 09:28:27.844 Directory listing successful
. 2016-11-30 09:28:27.844 Got reply 1 to the command 2
. 2016-11-30 09:28:27.844 Detecting timezone difference...
. 2016-11-30 09:28:27.844 Retrieving file information...
> 2016-11-30 09:28:27.844 PWD
< 2016-11-30 09:28:27.992 257 "/pub/incoming"
> 2016-11-30 09:28:27.992 CWD /pub/incoming/286968-michael-jackson.jpg
< 2016-11-30 09:28:28.141 550 Failed to change directory.
> 2016-11-30 09:28:28.141 TYPE I
< 2016-11-30 09:28:28.289 200 Switching to Binary mode.
> 2016-11-30 09:28:28.289 SIZE /pub/incoming/286968-michael-jackson.jpg
< 2016-11-30 09:28:28.437 213 1022048
> 2016-11-30 09:28:28.437 MDTM /pub/incoming/286968-michael-jackson.jpg
< 2016-11-30 09:28:28.584 213 20161130023354
. 2016-11-30 09:28:28.584 Retrieving file information successful
. 2016-11-30 09:28:28.584 Got reply 1 to the command 1024
. 2016-11-30 09:28:28.584 No timezone difference detected using file /pub/incoming/286968-michael-jackson.jpg (Listing: 2016-11-30T02:33:00.000Z, UTF: 2016-11-30T02:33:00.000Z)
. 2016-11-30 09:28:28.584 ..;D;0;1899-12-30T00:00:00.000Z;0;"" [0];"" [0];---------;0
. 2016-11-30 09:28:28.584 286968-michael-jackson.jpg;-;1022048;2016-11-30T02:33:00.000Z;1;"106" [0];"113" [0];rw-r--r--;0
. 2016-11-30 09:28:28.584 325268.jpg;-;282902;2016-11-30T02:33:00.000Z;1;"106" [0];"113" [0];rw-r--r--;0
. 2016-11-30 09:28:28.584 427687.jpg;-;623980;2016-11-30T02:33:00.000Z;1;"106" [0];"113" [0];rw-r--r--;0
. 2016-11-30 09:28:28.584 432142.jpg;-;212708;2016-11-30T02:33:00.000Z;1;"106" [0];"113" [0];rw-r--r--;0
. 2016-11-30 09:28:28.584 481483.jpg;-;174680;2016-11-30T02:33:00.000Z;1;"106" [0];"113" [0];rw-r--r--;0
. 2016-11-30 09:28:28.584 539400.jpg;-;806951;2016-11-30T02:33:00.000Z;1;"106" [0];"113" [0];rw-r--r--;0
. 2016-11-30 09:28:28.584 640719.jpg;-;3516049;2016-11-30T02:34:00.000Z;1;"106" [0];"113" [0];rw-r--r--;0
. 2016-11-30 09:28:28.584 AripekaSpringshed.dbf;-;16016;2016-11-23T11:55:00.000Z;1;"106" [0];"113" [0];rw-r--r--;0
. 2016-11-30 09:28:28.584 AripekaSpringshed.prj;-;517;2016-11-23T11:55:00.000Z;1;"106" [0];"113" [0];rw-r--r--;0
. 2016-11-30 09:28:28.584 AripekaSpringshed.sbn;-;132;2016-11-23T11:55:00.000Z;1;"106" [0];"113" [0];rw-r--r--;0
. 2016-11-30 09:28:28.584 AripekaSpringshed.sbx;-;116;2016-11-23T11:55:00.000Z;1;"106" [0];"113" [0];rw-r--r--;0
. 2016-11-30 09:28:28.584 AripekaSpringshed.shp;-;13308;2016-11-23T11:55:00.000Z;1;"106" [0];"113" [0];rw-r--r--;0
. 2016-11-30 09:28:28.584 AripekaSpringshed.shp.xml;-;190743;2016-11-23T11:55:00.000Z;1;"106" [0];"113" [0];rw-r--r--;0
. 2016-11-30 09:28:28.585 AripekaSpringshed.shx;-;108;2016-11-23T11:55:00.000Z;1;"106" [0];"113" [0];rw-r--r--;0
. 2016-11-30 09:28:28.585 CrewsLake.dbf;-;806;2016-11-23T11:54:00.000Z;1;"106" [0];"113" [0];rw-r--r--;0
. 2016-11-30 09:28:28.585 CrewsLake.prj;-;517;2016-11-23T11:54:00.000Z;1;"106" [0];"113" [0];rw-r--r--;0
. 2016-11-30 09:28:28.585 CrewsLake.sbn;-;156;2016-11-23T11:54:00.000Z;1;"106" [0];"113" [0];rw-r--r--;0
. 2016-11-30 09:28:28.585 CrewsLake.sbx;-;124;2016-11-23T11:53:00.000Z;1;"106" [0];"113" [0];rw-r--r--;0
. 2016-11-30 09:28:28.585 CrewsLake.shp;-;18456;2016-11-23T11:53:00.000Z;1;"106" [0];"113" [0];rw-r--r--;0
. 2016-11-30 09:28:28.585 CrewsLake.shp.xml;-;11816;2016-11-23T11:54:00.000Z;1;"106" [0];"113" [0];rw-r--r--;0
. 2016-11-30 09:28:28.585 CrewsLake.shx;-;116;2016-11-23T11:54:00.000Z;1;"106" [0];"113" [0];rw-r--r--;0
. 2016-11-30 09:28:28.585 EmbassyHillsNWRRIB.dbf;-;1456;2016-11-23T11:54:00.000Z;1;"106" [0];"113" [0];rw-r--r--;0
. 2016-11-30 09:28:28.585 EmbassyHillsNWRRIB.prj;-;517;2016-11-23T11:54:00.000Z;1;"106" [0];"113" [0];rw-r--r--;0
. 2016-11-30 09:28:28.585 EmbassyHillsNWRRIB.sbn;-;148;2016-11-23T11:54:00.000Z;1;"106" [0];"113" [0];rw-r--r--;0
. 2016-11-30 09:28:28.585 EmbassyHillsNWRRIB.sbx;-;116;2016-11-23T11:54:00.000Z;1;"106" [0];"113" [0];rw-r--r--;0
. 2016-11-30 09:28:28.585 EmbassyHillsNWRRIB.shp;-;128;2016-11-23T11:54:00.000Z;1;"106" [0];"113" [0];rw-r--r--;0
. 2016-11-30 09:28:28.585 EmbassyHillsNWRRIB.shp.xml;-;18568;2016-11-23T11:54:00.000Z;1;"106" [0];"113" [0];rw-r--r--;0
. 2016-11-30 09:28:28.585 EmbassyHillsNWRRIB.shx;-;108;2016-11-23T11:54:00.000Z;1;"106" [0];"113" [0];rw-r--r--;0
. 2016-11-30 09:28:28.585 MajorRoads.dbf;-;29288814;2016-11-23T11:54:00.000Z;1;"106" [0];"113" [0];rw-r--r--;0
. 2016-11-30 09:28:28.585 MajorRoads.prj;-;676;2016-11-23T11:54:00.000Z;1;"106" [0];"113" [0];rw-r--r--;0
. 2016-11-30 09:28:28.585 MajorRoads.sbn;-;304236;2016-11-23T11:54:00.000Z;1;"106" [0];"113" [0];rw-r--r--;0
. 2016-11-30 09:28:28.585 MajorRoads.sbx;-;13732;2016-11-23T11:54:00.000Z;1;"106" [0];"113" [0];rw-r--r--;0
. 2016-11-30 09:28:28.585 MajorRoads.shp;-;7294260;2016-11-23T11:54:00.000Z;1;"106" [0];"113" [0];rw-r--r--;0
. 2016-11-30 09:28:28.585 MajorRoads.shp.xml;-;64851;2016-11-23T11:54:00.000Z;1;"106" [0];"113" [0];rw-r--r--;0
. 2016-11-30 09:28:28.585 MajorRoads.shx;-;257860;2016-11-23T11:54:00.000Z;1;"106" [0];"113" [0];rw-r--r--;0
. 2016-11-30 09:28:28.585 PascoCounty.dbf;-;336;2016-11-23T11:54:00.000Z;1;"106" [0];"113" [0];rw-r--r--;0
. 2016-11-30 09:28:28.585 PascoCounty.prj;-;676;2016-11-23T11:54:00.000Z;1;"106" [0];"113" [0];rw-r--r--;0
. 2016-11-30 09:28:28.585 PascoCounty.sbn;-;164;2016-11-23T11:54:00.000Z;1;"106" [0];"113" [0];rw-r--r--;0
. 2016-11-30 09:28:28.585 PascoCounty.sbx;-;124;2016-11-23T11:54:00.000Z;1;"106" [0];"113" [0];rw-r--r--;0
. 2016-11-30 09:28:28.585 PascoCounty.shp;-;361124;2016-11-23T11:54:00.000Z;1;"106" [0];"113" [0];rw-r--r--;0
. 2016-11-30 09:28:28.585 PascoCounty.shp.xml;-;20143;2016-11-23T11:54:00.000Z;1;"106" [0];"113" [0];rw-r--r--;0
. 2016-11-30 09:28:28.585 PascoCounty.shx;-;116;2016-11-23T11:54:00.000Z;1;"106" [0];"113" [0];rw-r--r--;0
. 2016-11-30 09:28:28.585 ReclaimedPipeline.dbf;-;4272654;2016-11-23T11:55:00.000Z;1;"106" [0];"113" [0];rw-r--r--;0
. 2016-11-30 09:28:28.585 ReclaimedPipeline.prj;-;517;2016-11-23T11:55:00.000Z;1;"106" [0];"113" [0];rw-r--r--;0
. 2016-11-30 09:28:28.585 ReclaimedPipeline.sbn;-;31292;2016-11-23T11:55:00.000Z;1;"106" [0];"113" [0];rw-r--r--;0
. 2016-11-30 09:28:28.585 ReclaimedPipeline.sbx;-;1604;2016-11-23T11:55:00.000Z;1;"106" [0];"113" [0];rw-r--r--;0
. 2016-11-30 09:28:28.585 ReclaimedPipeline.shp;-;878736;2016-11-23T11:55:00.000Z;1;"106" [0];"113" [0];rw-r--r--;0
. 2016-11-30 09:28:28.585 ReclaimedPipeline.shp.xml;-;21122;2016-11-23T11:55:00.000Z;1;"106" [0];"113" [0];rw-r--r--;0
. 2016-11-30 09:28:28.585 ReclaimedPipeline.shx;-;25756;2016-11-23T11:55:00.000Z;1;"106" [0];"113" [0];rw-r--r--;0
. 2016-11-30 09:28:28.586 ShadyHillsWWTP.dbf;-;1276;2016-11-23T11:55:00.000Z;1;"106" [0];"113" [0];rw-r--r--;0
. 2016-11-30 09:28:28.586 ShadyHillsWWTP.prj;-;517;2016-11-23T11:55:00.000Z;1;"106" [0];"113" [0];rw-r--r--;0
. 2016-11-30 09:28:28.586 ShadyHillsWWTP.sbn;-;148;2016-11-23T11:55:00.000Z;1;"106" [0];"113" [0];rw-r--r--;0
. 2016-11-30 09:28:28.586 ShadyHillsWWTP.sbx;-;116;2016-11-23T11:55:00.000Z;1;"106" [0];"113" [0];rw-r--r--;0
. 2016-11-30 09:28:28.586 ShadyHillsWWTP.shp;-;128;2016-11-23T11:55:00.000Z;1;"106" [0];"113" [0];rw-r--r--;0
. 2016-11-30 09:28:28.586 ShadyHillsWWTP.shp.xml;-;211837;2016-11-23T11:55:00.000Z;1;"106" [0];"113" [0];rw-r--r--;0
. 2016-11-30 09:28:28.586 ShadyHillsWWTP.shx;-;108;2016-11-23T11:55:00.000Z;1;"106" [0];"113" [0];rw-r--r--;0
. 2016-11-30 09:28:28.586 USGS_BagleyCove_Discharge_Retrieved_11-05-2016.xlsx;-;524288;2016-11-22T08:54:00.000Z;1;"106" [0];"113" [0];rw-r--r--;0
. 2016-11-30 09:28:28.586 WeekiWacheeSpringshed.dbf;-;2394;2016-11-23T11:55:00.000Z;1;"106" [0];"113" [0];rw-r--r--;0
. 2016-11-30 09:28:28.586 WeekiWacheeSpringshed.prj;-;517;2016-11-23T11:55:00.000Z;1;"106" [0];"113" [0];rw-r--r--;0
. 2016-11-30 09:28:28.586 WeekiWacheeSpringshed.sbn;-;132;2016-11-23T11:55:00.000Z;1;"106" [0];"113" [0];rw-r--r--;0
. 2016-11-30 09:28:28.586 WeekiWacheeSpringshed.sbx;-;116;2016-11-23T11:55:00.000Z;1;"106" [0];"113" [0];rw-r--r--;0
. 2016-11-30 09:28:28.586 WeekiWacheeSpringshed.shp;-;10156;2016-11-23T11:55:00.000Z;1;"106" [0];"113" [0];rw-r--r--;0
. 2016-11-30 09:28:28.586 WeekiWacheeSpringshed.shp.xml;-;95302;2016-11-23T11:55:00.000Z;1;"106" [0];"113" [0];rw-r--r--;0
. 2016-11-30 09:28:28.586 WeekiWacheeSpringshed.shx;-;108;2016-11-23T11:55:00.000Z;1;"106" [0];"113" [0];rw-r--r--;0
. 2016-11-30 09:28:28.586 __test__00018454.txt;-;4463;2016-11-29T14:18:00.000Z;1;"106" [0];"113" [0];rw-r--r--;0
. 2016-11-30 09:28:28.586 __test__00020268.txt;-;4080;2016-11-29T14:20:00.000Z;1;"106" [0];"113" [0];rw-r--r--;0
. 2016-11-30 09:28:28.586 amazon-search-1.png;-;587240;2016-11-30T03:59:00.000Z;1;"106" [0];"113" [0];rw-r--r--;0
. 2016-11-30 09:28:28.586 lost+found;D;0;2013-07-15T23:00:00.000Z;2;"0" [0];"0" [0];rw-r--r--;0
. 2016-11-30 09:28:28.586 michael-jackson-by-gottfried-helnwein.jpg;-;74787;2016-11-30T02:34:00.000Z;1;"106" [0];"113" [0];rw-r--r--;0
. 2016-11-30 09:28:28.586 michael-jackson-by-robert-deutsch-rare-1995.jpg;-;103222;2016-11-30T02:34:00.000Z;1;"106" [0];"113" [0];rw-r--r--;0
. 2016-11-30 09:28:28.586 michael-jackson-earth-song-rare03.jpg;-;54389;2016-11-30T02:34:00.000Z;1;"106" [0];"113" [0];rw-r--r--;0
. 2016-11-30 09:28:28.586 michael-jackson-history-childhood-lollipop-rare02.jpg;-;45112;2016-11-30T02:34:00.000Z;1;"106" [0];"113" [0];rw-r--r--;0
. 2016-11-30 09:28:28.586 michael-jackson-lori-stoll-rare06.jpg;-;40606;2016-11-30T02:34:00.000Z;1;"106" [0];"113" [0];rw-r--r--;0
. 2016-11-30 09:28:28.586 michael-jackson-older-rare01.jpg;-;34289;2016-11-30T02:34:00.000Z;1;"106" [0];"113" [0];rw-r--r--;0
. 2016-11-30 09:28:28.586 michael-jackson-with-children-rare01.jpg;-;173348;2016-11-30T02:34:00.000Z;1;"106" [0];"113" [0];rw-r--r--;0
. 2016-11-30 09:28:28.586 mj1.jpg;-;6790;2016-11-30T02:34:00.000Z;1;"106" [0];"113" [0];rw-r--r--;0
. 2016-11-30 09:28:28.586 mj2.jpg;-;6642;2016-11-30T02:34:00.000Z;1;"106" [0];"113" [0];rw-r--r--;0
. 2016-11-30 09:28:28.586 mj3.jpg;-;8547;2016-11-30T02:34:00.000Z;1;"106" [0];"113" [0];rw-r--r--;0
. 2016-11-30 09:28:28.586 mj4.jpg;-;6771;2016-11-30T02:34:00.000Z;1;"106" [0];"113" [0];rw-r--r--;0
. 2016-11-30 09:28:28.586 picture132.jpg;-;98738;2016-11-30T02:34:00.000Z;1;"106" [0];"113" [0];rw-r--r--;0
. 2016-11-30 09:28:28.586 Session upkeep
. 2016-11-30 09:28:28.664 Startup conversation with host finished.
. 2016-11-30 09:28:28.897 Session upkeep
. 2016-11-30 09:28:29.074 Session upkeep
. 2016-11-30 09:28:29.580 Session upkeep
. 2016-11-30 09:28:30.088 Session upkeep
. 2016-11-30 09:28:30.588 Session upkeep
. 2016-11-30 09:28:31.118 Session upkeep
. 2016-11-30 09:28:31.606 Session upkeep
. 2016-11-30 09:28:32.116 Session upkeep
. 2016-11-30 09:28:32.616 Session upkeep
. 2016-11-30 09:28:33.130 Session upkeep
. 2016-11-30 09:28:33.636 Session upkeep
. 2016-11-30 09:28:34.143 Session upkeep
. 2016-11-30 09:28:34.650 Session upkeep
. 2016-11-30 09:28:35.157 Session upkeep
. 2016-11-30 09:28:35.662 Session upkeep
. 2016-11-30 09:28:36.216 Session upkeep
. 2016-11-30 09:28:36.671 Session upkeep
. 2016-11-30 09:28:37.185 Session upkeep
. 2016-11-30 09:28:37.689 Session upkeep
. 2016-11-30 09:28:38.199 Session upkeep
. 2016-11-30 09:28:38.707 Session upkeep
. 2016-11-30 09:28:39.214 Session upkeep
. 2016-11-30 09:28:39.714 Session upkeep
. 2016-11-30 09:28:40.228 Session upkeep
. 2016-11-30 09:28:40.731 Session upkeep
. 2016-11-30 09:28:41.242 Session upkeep
. 2016-11-30 09:28:41.746 Session upkeep
. 2016-11-30 09:28:42.256 Session upkeep
. 2016-11-30 09:28:42.754 Copying 1 files/directories to remote directory "/pub/incoming/"
. 2016-11-30 09:28:42.754 PrTime: Yes; PrRO: No; Rght: rw-r--r--; PrR: No (No); FnCs: N; RIC: 0100; Resume: S (102400); CalcS: Yes; Mask: *.*
. 2016-11-30 09:28:42.754 TM: B; ClAr: No; RemEOF: No; RemBOM: No; CPS: 0; NewerOnly: No; InclM: ; ResumeL: 0
. 2016-11-30 09:28:42.754 AscM: *.*html; *.htm; *.txt; *.php; *.php3; *.cgi; *.c; *.cpp; *.h; *.pas; *.bas; *.tex; *.pl; *.js; .htaccess; *.xtml; *.css; *.cfg; *.ini; *.sh; *.xml
. 2016-11-30 09:28:42.755 Session upkeep
. 2016-11-30 09:28:42.756 File: 'C:\Temp\paris_2016_c_155.jpg' [2016-09-29T22:39:28.000Z] [116339]
. 2016-11-30 09:28:42.756 Copying "C:\Temp\paris_2016_c_155.jpg" to remote directory started.
. 2016-11-30 09:28:42.756 Binary transfer mode selected.
. 2016-11-30 09:28:42.756 Starting upload of C:\Temp\paris_2016_c_155.jpg
> 2016-11-30 09:28:42.756 TYPE I
< 2016-11-30 09:28:42.904 200 Switching to Binary mode.
> 2016-11-30 09:28:42.904 PASV
< 2016-11-30 09:28:43.051 227 Entering Passive Mode (204,76,241,31,146,54).
> 2016-11-30 09:28:43.051 STOR paris_2016_c_155.jpg
. 2016-11-30 09:28:43.202 Data connection opened
< 2016-11-30 09:28:43.346 150 Ok to send data.
. 2016-11-30 09:28:43.346 Data connection opened
< 2016-11-30 09:28:44.522 226 Transfer complete.
> 2016-11-30 09:28:44.522 MDTM 20160929223928 paris_2016_c_155.jpg
< 2016-11-30 09:28:44.670 550 Could not get file modification time.
. 2016-11-30 09:28:44.670 Upload successful
. 2016-11-30 09:28:44.670 Got reply 1 to the command 4
. 2016-11-30 09:28:44.671 Remembering modification time of "/pub/incoming/paris_2016_c_155.jpg" as [2016-09-29T22:39:28.000Z]
. 2016-11-30 09:28:44.672 Transfer done: 'C:\Temp\paris_2016_c_155.jpg' [116339]
. 2016-11-30 09:28:44.672 Retrieving directory listing...
> 2016-11-30 09:28:44.672 TYPE A
< 2016-11-30 09:28:44.821 200 Switching to ASCII mode.
> 2016-11-30 09:28:44.821 PASV
< 2016-11-30 09:28:44.972 227 Entering Passive Mode (204,76,241,31,200,179).
> 2016-11-30 09:28:44.972 LIST -a
. 2016-11-30 09:28:44.972 Connecting to 204.76.241.31:51379 ...
. 2016-11-30 09:28:45.123 Data connection opened
< 2016-11-30 09:28:45.269 150 Here comes the directory listing.
. 2016-11-30 09:28:45.272 Data connection closed
. 2016-11-30 09:28:45.273 drwxr-xr-x 3 106 113 1200128 Nov 30 04:15 .
. 2016-11-30 09:28:45.273 drwxr-xr-x 32 0 0 4096 Jun 30 12:11 ..
. 2016-11-30 09:28:45.273 -rw-r--r-- 1 106 113 1022048 Nov 30 02:33 286968-michael-jackson.jpg
. 2016-11-30 09:28:45.273 -rw-r--r-- 1 106 113 282902 Nov 30 02:33 325268.jpg
. 2016-11-30 09:28:45.273 -rw-r--r-- 1 106 113 623980 Nov 30 02:33 427687.jpg
. 2016-11-30 09:28:45.273 -rw-r--r-- 1 106 113 212708 Nov 30 02:33 432142.jpg
. 2016-11-30 09:28:45.273 -rw-r--r-- 1 106 113 174680 Nov 30 02:33 481483.jpg
. 2016-11-30 09:28:45.273 -rw-r--r-- 1 106 113 806951 Nov 30 02:33 539400.jpg
. 2016-11-30 09:28:45.273 -rw-r--r-- 1 106 113 3516049 Nov 30 02:34 640719.jpg
. 2016-11-30 09:28:45.273 -rw-r--r-- 1 106 113 16016 Nov 23 11:55 AripekaSpringshed.dbf
. 2016-11-30 09:28:45.273 -rw-r--r-- 1 106 113 517 Nov 23 11:55 AripekaSpringshed.prj
. 2016-11-30 09:28:45.273 -rw-r--r-- 1 106 113 132 Nov 23 11:55 AripekaSpringshed.sbn
. 2016-11-30 09:28:45.273 -rw-r--r-- 1 106 113 116 Nov 23 11:55 AripekaSpringshed.sbx
. 2016-11-30 09:28:45.273 -rw-r--r-- 1 106 113 13308 Nov 23 11:55 AripekaSpringshed.shp
. 2016-11-30 09:28:45.273 -rw-r--r-- 1 106 113 190743 Nov 23 11:55 AripekaSpringshed.shp.xml
. 2016-11-30 09:28:45.273 -rw-r--r-- 1 106 113 108 Nov 23 11:55 AripekaSpringshed.shx
. 2016-11-30 09:28:45.273 -rw-r--r-- 1 106 113 806 Nov 23 11:54 CrewsLake.dbf
. 2016-11-30 09:28:45.273 -rw-r--r-- 1 106 113 517 Nov 23 11:54 CrewsLake.prj
. 2016-11-30 09:28:45.273 -rw-r--r-- 1 106 113 156 Nov 23 11:54 CrewsLake.sbn
. 2016-11-30 09:28:45.273 -rw-r--r-- 1 106 113 124 Nov 23 11:53 CrewsLake.sbx
. 2016-11-30 09:28:45.273 -rw-r--r-- 1 106 113 18456 Nov 23 11:53 CrewsLake.shp
. 2016-11-30 09:28:45.273 -rw-r--r-- 1 106 113 11816 Nov 23 11:54 CrewsLake.shp.xml
. 2016-11-30 09:28:45.273 -rw-r--r-- 1 106 113 116 Nov 23 11:54 CrewsLake.shx
. 2016-11-30 09:28:45.273 -rw-r--r-- 1 106 113 1456 Nov 23 11:54 EmbassyHillsNWRRIB.dbf
. 2016-11-30 09:28:45.273 -rw-r--r-- 1 106 113 517 Nov 23 11:54 EmbassyHillsNWRRIB.prj
. 2016-11-30 09:28:45.273 -rw-r--r-- 1 106 113 148 Nov 23 11:54 EmbassyHillsNWRRIB.sbn
. 2016-11-30 09:28:45.273 -rw-r--r-- 1 106 113 116 Nov 23 11:54 EmbassyHillsNWRRIB.sbx
. 2016-11-30 09:28:45.273 -rw-r--r-- 1 106 113 128 Nov 23 11:54 EmbassyHillsNWRRIB.shp
. 2016-11-30 09:28:45.273 -rw-r--r-- 1 106 113 18568 Nov 23 11:54 EmbassyHillsNWRRIB.shp.xml
. 2016-11-30 09:28:45.273 -rw-r--r-- 1 106 113 108 Nov 23 11:54 EmbassyHillsNWRRIB.shx
. 2016-11-30 09:28:45.273 -rw-r--r-- 1 106 113 29288814 Nov 23 11:54 MajorRoads.dbf
. 2016-11-30 09:28:45.273 -rw-r--r-- 1 106 113 676 Nov 23 11:54 MajorRoads.prj
. 2016-11-30 09:28:45.273 -rw-r--r-- 1 106 113 304236 Nov 23 11:54 MajorRoads.sbn
. 2016-11-30 09:28:45.273 -rw-r--r-- 1 106 113 13732 Nov 23 11:54 MajorRoads.sbx
. 2016-11-30 09:28:45.273 -rw-r--r-- 1 106 113 7294260 Nov 23 11:54 MajorRoads.shp
. 2016-11-30 09:28:45.273 -rw-r--r-- 1 106 113 64851 Nov 23 11:54 MajorRoads.shp.xml
. 2016-11-30 09:28:45.273 -rw-r--r-- 1 106 113 257860 Nov 23 11:54 MajorRoads.shx
. 2016-11-30 09:28:45.273 -rw-r--r-- 1 106 113 336 Nov 23 11:54 PascoCounty.dbf
. 2016-11-30 09:28:45.273 -rw-r--r-- 1 106 113 676 Nov 23 11:54 PascoCounty.prj
. 2016-11-30 09:28:45.273 -rw-r--r-- 1 106 113 164 Nov 23 11:54 PascoCounty.sbn
. 2016-11-30 09:28:45.273 -rw-r--r-- 1 106 113 124 Nov 23 11:54 PascoCounty.sbx
. 2016-11-30 09:28:45.273 -rw-r--r-- 1 106 113 361124 Nov 23 11:54 PascoCounty.shp
. 2016-11-30 09:28:45.273 -rw-r--r-- 1 106 113 20143 Nov 23 11:54 PascoCounty.shp.xml
. 2016-11-30 09:28:45.273 -rw-r--r-- 1 106 113 116 Nov 23 11:54 PascoCounty.shx
. 2016-11-30 09:28:45.273 -rw-r--r-- 1 106 113 4272654 Nov 23 11:55 ReclaimedPipeline.dbf
. 2016-11-30 09:28:45.273 -rw-r--r-- 1 106 113 517 Nov 23 11:55 ReclaimedPipeline.prj
. 2016-11-30 09:28:45.273 -rw-r--r-- 1 106 113 31292 Nov 23 11:55 ReclaimedPipeline.sbn
. 2016-11-30 09:28:45.274 -rw-r--r-- 1 106 113 1604 Nov 23 11:55 ReclaimedPipeline.sbx
. 2016-11-30 09:28:45.274 -rw-r--r-- 1 106 113 878736 Nov 23 11:55 ReclaimedPipeline.shp
. 2016-11-30 09:28:45.274 -rw-r--r-- 1 106 113 21122 Nov 23 11:55 ReclaimedPipeline.shp.xml
. 2016-11-30 09:28:45.274 -rw-r--r-- 1 106 113 25756 Nov 23 11:55 ReclaimedPipeline.shx
. 2016-11-30 09:28:45.274 -rw-r--r-- 1 106 113 1276 Nov 23 11:55 ShadyHillsWWTP.dbf
. 2016-11-30 09:28:45.274 -rw-r--r-- 1 106 113 517 Nov 23 11:55 ShadyHillsWWTP.prj
. 2016-11-30 09:28:45.274 -rw-r--r-- 1 106 113 148 Nov 23 11:55 ShadyHillsWWTP.sbn
. 2016-11-30 09:28:45.274 -rw-r--r-- 1 106 113 116 Nov 23 11:55 ShadyHillsWWTP.sbx
. 2016-11-30 09:28:45.274 -rw-r--r-- 1 106 113 128 Nov 23 11:55 ShadyHillsWWTP.shp
. 2016-11-30 09:28:45.274 -rw-r--r-- 1 106 113 211837 Nov 23 11:55 ShadyHillsWWTP.shp.xml
. 2016-11-30 09:28:45.274 -rw-r--r-- 1 106 113 108 Nov 23 11:55 ShadyHillsWWTP.shx
. 2016-11-30 09:28:45.274 -rw-r--r-- 1 106 113 524288 Nov 22 08:54 USGS_BagleyCove_Discharge_Retrieved_11-05-2016.xlsx
. 2016-11-30 09:28:45.274 -rw-r--r-- 1 106 113 2394 Nov 23 11:55 WeekiWacheeSpringshed.dbf
. 2016-11-30 09:28:45.274 -rw-r--r-- 1 106 113 517 Nov 23 11:55 WeekiWacheeSpringshed.prj
. 2016-11-30 09:28:45.274 -rw-r--r-- 1 106 113 132 Nov 23 11:55 WeekiWacheeSpringshed.sbn
. 2016-11-30 09:28:45.274 -rw-r--r-- 1 106 113 116 Nov 23 11:55 WeekiWacheeSpringshed.sbx
. 2016-11-30 09:28:45.274 -rw-r--r-- 1 106 113 10156 Nov 23 11:55 WeekiWacheeSpringshed.shp
. 2016-11-30 09:28:45.274 -rw-r--r-- 1 106 113 95302 Nov 23 11:55 WeekiWacheeSpringshed.shp.xml
. 2016-11-30 09:28:45.274 -rw-r--r-- 1 106 113 108 Nov 23 11:55 WeekiWacheeSpringshed.shx
. 2016-11-30 09:28:45.274 -rw-r--r-- 1 106 113 4463 Nov 29 14:18 __test__00018454.txt
. 2016-11-30 09:28:45.274 -rw-r--r-- 1 106 113 4080 Nov 29 14:20 __test__00020268.txt
. 2016-11-30 09:28:45.274 -rw-r--r-- 1 106 113 587240 Nov 30 03:59 amazon-search-1.png
. 2016-11-30 09:28:45.274 drw-r--r-- 2 0 0 49152 Jul 16 2013 lost+found
. 2016-11-30 09:28:45.274 -rw-r--r-- 1 106 113 74787 Nov 30 02:34 michael-jackson-by-gottfried-helnwein.jpg
. 2016-11-30 09:28:45.274 -rw-r--r-- 1 106 113 103222 Nov 30 02:34 michael-jackson-by-robert-deutsch-rare-1995.jpg
. 2016-11-30 09:28:45.274 -rw-r--r-- 1 106 113 54389 Nov 30 02:34 michael-jackson-earth-song-rare03.jpg
. 2016-11-30 09:28:45.274 -rw-r--r-- 1 106 113 45112 Nov 30 02:34 michael-jackson-history-childhood-lollipop-rare02.jpg
. 2016-11-30 09:28:45.274 -rw-r--r-- 1 106 113 40606 Nov 30 02:34 michael-jackson-lori-stoll-rare06.jpg
. 2016-11-30 09:28:45.274 -rw-r--r-- 1 106 113 34289 Nov 30 02:34 michael-jackson-older-rare01.jpg
. 2016-11-30 09:28:45.274 -rw-r--r-- 1 106 113 173348 Nov 30 02:34 michael-jackson-with-children-rare01.jpg
. 2016-11-30 09:28:45.274 -rw-r--r-- 1 106 113 6790 Nov 30 02:34 mj1.jpg
. 2016-11-30 09:28:45.274 -rw-r--r-- 1 106 113 6642 Nov 30 02:34 mj2.jpg
. 2016-11-30 09:28:45.274 -rw-r--r-- 1 106 113 8547 Nov 30 02:34 mj3.jpg
. 2016-11-30 09:28:45.274 -rw-r--r-- 1 106 113 6771 Nov 30 02:34 mj4.jpg
. 2016-11-30 09:28:45.274 -rw-r--r-- 1 106 113 116339 Nov 30 04:15 paris_2016_c_155.jpg
. 2016-11-30 09:28:45.274 -rw-r--r-- 1 106 113 98738 Nov 30 02:34 picture132.jpg
< 2016-11-30 09:28:45.473 226 Directory send OK.
. 2016-11-30 09:28:45.473 Directory listing successful
. 2016-11-30 09:28:45.473 Got reply 1 to the command 2
. 2016-11-30 09:28:45.473 Remembered modification time [2016-09-29T22:39:28.000Z]/[2016-09-29T22:39:00.000Z] of "/pub/incoming/paris_2016_c_155.jpg" is obsolete, keeping [2016-11-30T04:15:00.000Z]
. 2016-11-30 09:28:45.473 ..;D;0;1899-12-30T00:00:00.000Z;0;"" [0];"" [0];---------;0
. 2016-11-30 09:28:45.473 286968-michael-jackson.jpg;-;1022048;2016-11-30T02:33:00.000Z;1;"106" [0];"113" [0];rw-r--r--;0
. 2016-11-30 09:28:45.473 325268.jpg;-;282902;2016-11-30T02:33:00.000Z;1;"106" [0];"113" [0];rw-r--r--;0
. 2016-11-30 09:28:45.474 427687.jpg;-;623980;2016-11-30T02:33:00.000Z;1;"106" [0];"113" [0];rw-r--r--;0
. 2016-11-30 09:28:45.474 432142.jpg;-;212708;2016-11-30T02:33:00.000Z;1;"106" [0];"113" [0];rw-r--r--;0
. 2016-11-30 09:28:45.474 481483.jpg;-;174680;2016-11-30T02:33:00.000Z;1;"106" [0];"113" [0];rw-r--r--;0
. 2016-11-30 09:28:45.474 539400.jpg;-;806951;2016-11-30T02:33:00.000Z;1;"106" [0];"113" [0];rw-r--r--;0
. 2016-11-30 09:28:45.474 640719.jpg;-;3516049;2016-11-30T02:34:00.000Z;1;"106" [0];"113" [0];rw-r--r--;0
. 2016-11-30 09:28:45.474 AripekaSpringshed.dbf;-;16016;2016-11-23T11:55:00.000Z;1;"106" [0];"113" [0];rw-r--r--;0
. 2016-11-30 09:28:45.474 AripekaSpringshed.prj;-;517;2016-11-23T11:55:00.000Z;1;"106" [0];"113" [0];rw-r--r--;0
. 2016-11-30 09:28:45.474 AripekaSpringshed.sbn;-;132;2016-11-23T11:55:00.000Z;1;"106" [0];"113" [0];rw-r--r--;0
. 2016-11-30 09:28:45.474 AripekaSpringshed.sbx;-;116;2016-11-23T11:55:00.000Z;1;"106" [0];"113" [0];rw-r--r--;0
. 2016-11-30 09:28:45.474 AripekaSpringshed.shp;-;13308;2016-11-23T11:55:00.000Z;1;"106" [0];"113" [0];rw-r--r--;0
. 2016-11-30 09:28:45.474 AripekaSpringshed.shp.xml;-;190743;2016-11-23T11:55:00.000Z;1;"106" [0];"113" [0];rw-r--r--;0
. 2016-11-30 09:28:45.474 AripekaSpringshed.shx;-;108;2016-11-23T11:55:00.000Z;1;"106" [0];"113" [0];rw-r--r--;0
. 2016-11-30 09:28:45.474 CrewsLake.dbf;-;806;2016-11-23T11:54:00.000Z;1;"106" [0];"113" [0];rw-r--r--;0
. 2016-11-30 09:28:45.474 CrewsLake.prj;-;517;2016-11-23T11:54:00.000Z;1;"106" [0];"113" [0];rw-r--r--;0
. 2016-11-30 09:28:45.474 CrewsLake.sbn;-;156;2016-11-23T11:54:00.000Z;1;"106" [0];"113" [0];rw-r--r--;0
. 2016-11-30 09:28:45.474 CrewsLake.sbx;-;124;2016-11-23T11:53:00.000Z;1;"106" [0];"113" [0];rw-r--r--;0
. 2016-11-30 09:28:45.474 CrewsLake.shp;-;18456;2016-11-23T11:53:00.000Z;1;"106" [0];"113" [0];rw-r--r--;0
. 2016-11-30 09:28:45.474 CrewsLake.shp.xml;-;11816;2016-11-23T11:54:00.000Z;1;"106" [0];"113" [0];rw-r--r--;0
. 2016-11-30 09:28:45.474 CrewsLake.shx;-;116;2016-11-23T11:54:00.000Z;1;"106" [0];"113" [0];rw-r--r--;0
. 2016-11-30 09:28:45.474 EmbassyHillsNWRRIB.dbf;-;1456;2016-11-23T11:54:00.000Z;1;"106" [0];"113" [0];rw-r--r--;0
. 2016-11-30 09:28:45.474 EmbassyHillsNWRRIB.prj;-;517;2016-11-23T11:54:00.000Z;1;"106" [0];"113" [0];rw-r--r--;0
. 2016-11-30 09:28:45.474 EmbassyHillsNWRRIB.sbn;-;148;2016-11-23T11:54:00.000Z;1;"106" [0];"113" [0];rw-r--r--;0
. 2016-11-30 09:28:45.474 EmbassyHillsNWRRIB.sbx;-;116;2016-11-23T11:54:00.000Z;1;"106" [0];"113" [0];rw-r--r--;0
. 2016-11-30 09:28:45.474 EmbassyHillsNWRRIB.shp;-;128;2016-11-23T11:54:00.000Z;1;"106" [0];"113" [0];rw-r--r--;0
. 2016-11-30 09:28:45.474 EmbassyHillsNWRRIB.shp.xml;-;18568;2016-11-23T11:54:00.000Z;1;"106" [0];"113" [0];rw-r--r--;0
. 2016-11-30 09:28:45.474 EmbassyHillsNWRRIB.shx;-;108;2016-11-23T11:54:00.000Z;1;"106" [0];"113" [0];rw-r--r--;0
. 2016-11-30 09:28:45.474 MajorRoads.dbf;-;29288814;2016-11-23T11:54:00.000Z;1;"106" [0];"113" [0];rw-r--r--;0
. 2016-11-30 09:28:45.474 MajorRoads.prj;-;676;2016-11-23T11:54:00.000Z;1;"106" [0];"113" [0];rw-r--r--;0
. 2016-11-30 09:28:45.474 MajorRoads.sbn;-;304236;2016-11-23T11:54:00.000Z;1;"106" [0];"113" [0];rw-r--r--;0
. 2016-11-30 09:28:45.474 MajorRoads.sbx;-;13732;2016-11-23T11:54:00.000Z;1;"106" [0];"113" [0];rw-r--r--;0
. 2016-11-30 09:28:45.474 MajorRoads.shp;-;7294260;2016-11-23T11:54:00.000Z;1;"106" [0];"113" [0];rw-r--r--;0
. 2016-11-30 09:28:45.474 MajorRoads.shp.xml;-;64851;2016-11-23T11:54:00.000Z;1;"106" [0];"113" [0];rw-r--r--;0
. 2016-11-30 09:28:45.474 MajorRoads.shx;-;257860;2016-11-23T11:54:00.000Z;1;"106" [0];"113" [0];rw-r--r--;0
. 2016-11-30 09:28:45.474 PascoCounty.dbf;-;336;2016-11-23T11:54:00.000Z;1;"106" [0];"113" [0];rw-r--r--;0
. 2016-11-30 09:28:45.474 PascoCounty.prj;-;676;2016-11-23T11:54:00.000Z;1;"106" [0];"113" [0];rw-r--r--;0
. 2016-11-30 09:28:45.474 PascoCounty.sbn;-;164;2016-11-23T11:54:00.000Z;1;"106" [0];"113" [0];rw-r--r--;0
. 2016-11-30 09:28:45.475 PascoCounty.sbx;-;124;2016-11-23T11:54:00.000Z;1;"106" [0];"113" [0];rw-r--r--;0
. 2016-11-30 09:28:45.475 PascoCounty.shp;-;361124;2016-11-23T11:54:00.000Z;1;"106" [0];"113" [0];rw-r--r--;0
. 2016-11-30 09:28:45.475 PascoCounty.shp.xml;-;20143;2016-11-23T11:54:00.000Z;1;"106" [0];"113" [0];rw-r--r--;0
. 2016-11-30 09:28:45.475 PascoCounty.shx;-;116;2016-11-23T11:54:00.000Z;1;"106" [0];"113" [0];rw-r--r--;0
. 2016-11-30 09:28:45.475 ReclaimedPipeline.dbf;-;4272654;2016-11-23T11:55:00.000Z;1;"106" [0];"113" [0];rw-r--r--;0
. 2016-11-30 09:28:45.475 ReclaimedPipeline.prj;-;517;2016-11-23T11:55:00.000Z;1;"106" [0];"113" [0];rw-r--r--;0
. 2016-11-30 09:28:45.475 ReclaimedPipeline.sbn;-;31292;2016-11-23T11:55:00.000Z;1;"106" [0];"113" [0];rw-r--r--;0
. 2016-11-30 09:28:45.475 ReclaimedPipeline.sbx;-;1604;2016-11-23T11:55:00.000Z;1;"106" [0];"113" [0];rw-r--r--;0
. 2016-11-30 09:28:45.475 ReclaimedPipeline.shp;-;878736;2016-11-23T11:55:00.000Z;1;"106" [0];"113" [0];rw-r--r--;0
. 2016-11-30 09:28:45.475 ReclaimedPipeline.shp.xml;-;21122;2016-11-23T11:55:00.000Z;1;"106" [0];"113" [0];rw-r--r--;0
. 2016-11-30 09:28:45.475 ReclaimedPipeline.shx;-;25756;2016-11-23T11:55:00.000Z;1;"106" [0];"113" [0];rw-r--r--;0
. 2016-11-30 09:28:45.475 ShadyHillsWWTP.dbf;-;1276;2016-11-23T11:55:00.000Z;1;"106" [0];"113" [0];rw-r--r--;0
. 2016-11-30 09:28:45.475 ShadyHillsWWTP.prj;-;517;2016-11-23T11:55:00.000Z;1;"106" [0];"113" [0];rw-r--r--;0
. 2016-11-30 09:28:45.475 ShadyHillsWWTP.sbn;-;148;2016-11-23T11:55:00.000Z;1;"106" [0];"113" [0];rw-r--r--;0
. 2016-11-30 09:28:45.475 ShadyHillsWWTP.sbx;-;116;2016-11-23T11:55:00.000Z;1;"106" [0];"113" [0];rw-r--r--;0
. 2016-11-30 09:28:45.475 ShadyHillsWWTP.shp;-;128;2016-11-23T11:55:00.000Z;1;"106" [0];"113" [0];rw-r--r--;0
. 2016-11-30 09:28:45.475 ShadyHillsWWTP.shp.xml;-;211837;2016-11-23T11:55:00.000Z;1;"106" [0];"113" [0];rw-r--r--;0
. 2016-11-30 09:28:45.475 ShadyHillsWWTP.shx;-;108;2016-11-23T11:55:00.000Z;1;"106" [0];"113" [0];rw-r--r--;0
. 2016-11-30 09:28:45.475 USGS_BagleyCove_Discharge_Retrieved_11-05-2016.xlsx;-;524288;2016-11-22T08:54:00.000Z;1;"106" [0];"113" [0];rw-r--r--;0
. 2016-11-30 09:28:45.475 WeekiWacheeSpringshed.dbf;-;2394;2016-11-23T11:55:00.000Z;1;"106" [0];"113" [0];rw-r--r--;0
. 2016-11-30 09:28:45.475 WeekiWacheeSpringshed.prj;-;517;2016-11-23T11:55:00.000Z;1;"106" [0];"113" [0];rw-r--r--;0
. 2016-11-30 09:28:45.475 WeekiWacheeSpringshed.sbn;-;132;2016-11-23T11:55:00.000Z;1;"106" [0];"113" [0];rw-r--r--;0
. 2016-11-30 09:28:45.475 WeekiWacheeSpringshed.sbx;-;116;2016-11-23T11:55:00.000Z;1;"106" [0];"113" [0];rw-r--r--;0
. 2016-11-30 09:28:45.475 WeekiWacheeSpringshed.shp;-;10156;2016-11-23T11:55:00.000Z;1;"106" [0];"113" [0];rw-r--r--;0
. 2016-11-30 09:28:45.475 WeekiWacheeSpringshed.shp.xml;-;95302;2016-11-23T11:55:00.000Z;1;"106" [0];"113" [0];rw-r--r--;0
. 2016-11-30 09:28:45.475 WeekiWacheeSpringshed.shx;-;108;2016-11-23T11:55:00.000Z;1;"106" [0];"113" [0];rw-r--r--;0
. 2016-11-30 09:28:45.475 __test__00018454.txt;-;4463;2016-11-29T14:18:00.000Z;1;"106" [0];"113" [0];rw-r--r--;0
. 2016-11-30 09:28:45.475 __test__00020268.txt;-;4080;2016-11-29T14:20:00.000Z;1;"106" [0];"113" [0];rw-r--r--;0
. 2016-11-30 09:28:45.475 amazon-search-1.png;-;587240;2016-11-30T03:59:00.000Z;1;"106" [0];"113" [0];rw-r--r--;0
. 2016-11-30 09:28:45.475 lost+found;D;0;2013-07-15T23:00:00.000Z;2;"0" [0];"0" [0];rw-r--r--;0
. 2016-11-30 09:28:45.475 michael-jackson-by-gottfried-helnwein.jpg;-;74787;2016-11-30T02:34:00.000Z;1;"106" [0];"113" [0];rw-r--r--;0
. 2016-11-30 09:28:45.475 michael-jackson-by-robert-deutsch-rare-1995.jpg;-;103222;2016-11-30T02:34:00.000Z;1;"106" [0];"113" [0];rw-r--r--;0
. 2016-11-30 09:28:45.475 michael-jackson-earth-song-rare03.jpg;-;54389;2016-11-30T02:34:00.000Z;1;"106" [0];"113" [0];rw-r--r--;0
. 2016-11-30 09:28:45.476 michael-jackson-history-childhood-lollipop-rare02.jpg;-;45112;2016-11-30T02:34:00.000Z;1;"106" [0];"113" [0];rw-r--r--;0
. 2016-11-30 09:28:45.476 michael-jackson-lori-stoll-rare06.jpg;-;40606;2016-11-30T02:34:00.000Z;1;"106" [0];"113" [0];rw-r--r--;0
. 2016-11-30 09:28:45.476 michael-jackson-older-rare01.jpg;-;34289;2016-11-30T02:34:00.000Z;1;"106" [0];"113" [0];rw-r--r--;0
. 2016-11-30 09:28:45.476 michael-jackson-with-children-rare01.jpg;-;173348;2016-11-30T02:34:00.000Z;1;"106" [0];"113" [0];rw-r--r--;0
. 2016-11-30 09:28:45.476 mj1.jpg;-;6790;2016-11-30T02:34:00.000Z;1;"106" [0];"113" [0];rw-r--r--;0
. 2016-11-30 09:28:45.476 mj2.jpg;-;6642;2016-11-30T02:34:00.000Z;1;"106" [0];"113" [0];rw-r--r--;0
. 2016-11-30 09:28:45.476 mj3.jpg;-;8547;2016-11-30T02:34:00.000Z;1;"106" [0];"113" [0];rw-r--r--;0
. 2016-11-30 09:28:45.476 mj4.jpg;-;6771;2016-11-30T02:34:00.000Z;1;"106" [0];"113" [0];rw-r--r--;0
. 2016-11-30 09:28:45.476 paris_2016_c_155.jpg;-;116339;2016-11-30T04:15:00.000Z;1;"106" [0];"113" [0];rw-r--r--;0
. 2016-11-30 09:28:45.476 picture132.jpg;-;98738;2016-11-30T02:34:00.000Z;1;"106" [0];"113" [0];rw-r--r--;0
. 2016-11-30 09:28:45.813 Session upkeep
. 2016-11-30 09:28:46.525 Session upkeep
. 2016-11-30 09:28:46.827 Session upkeep
. 2016-11-30 09:28:47.329 Session upkeep
. 2016-11-30 09:28:47.841 Session upkeep
. 2016-11-30 09:28:48.237 Getting current directory name.
. 2016-11-30 09:28:48.242 Retrieving directory listing...
> 2016-11-30 09:28:48.243 TYPE A
< 2016-11-30 09:28:48.390 200 Switching to ASCII mode.
> 2016-11-30 09:28:48.390 PASV
< 2016-11-30 09:28:48.538 227 Entering Passive Mode (204,76,241,31,84,190).
> 2016-11-30 09:28:48.538 LIST -a
. 2016-11-30 09:28:48.538 Connecting to 204.76.241.31:21694 ...
. 2016-11-30 09:28:48.691 Data connection opened
< 2016-11-30 09:28:48.832 150 Here comes the directory listing.
. 2016-11-30 09:28:48.835 Data connection closed
. 2016-11-30 09:28:48.835 drwxr-xr-x 3 106 113 1200128 Nov 30 04:15 .
. 2016-11-30 09:28:48.835 drwxr-xr-x 32 0 0 4096 Jun 30 12:11 ..
. 2016-11-30 09:28:48.835 -rw-r--r-- 1 106 113 1022048 Nov 30 02:33 286968-michael-jackson.jpg
. 2016-11-30 09:28:48.835 -rw-r--r-- 1 106 113 282902 Nov 30 02:33 325268.jpg
. 2016-11-30 09:28:48.835 -rw-r--r-- 1 106 113 623980 Nov 30 02:33 427687.jpg
. 2016-11-30 09:28:48.835 -rw-r--r-- 1 106 113 212708 Nov 30 02:33 432142.jpg
. 2016-11-30 09:28:48.835 -rw-r--r-- 1 106 113 174680 Nov 30 02:33 481483.jpg
. 2016-11-30 09:28:48.835 -rw-r--r-- 1 106 113 806951 Nov 30 02:33 539400.jpg
. 2016-11-30 09:28:48.835 -rw-r--r-- 1 106 113 3516049 Nov 30 02:34 640719.jpg
. 2016-11-30 09:28:48.835 -rw-r--r-- 1 106 113 16016 Nov 23 11:55 AripekaSpringshed.dbf
. 2016-11-30 09:28:48.835 -rw-r--r-- 1 106 113 517 Nov 23 11:55 AripekaSpringshed.prj
. 2016-11-30 09:28:48.836 -rw-r--r-- 1 106 113 132 Nov 23 11:55 AripekaSpringshed.sbn
. 2016-11-30 09:28:48.836 -rw-r--r-- 1 106 113 116 Nov 23 11:55 AripekaSpringshed.sbx
. 2016-11-30 09:28:48.836 -rw-r--r-- 1 106 113 13308 Nov 23 11:55 AripekaSpringshed.shp
. 2016-11-30 09:28:48.836 -rw-r--r-- 1 106 113 190743 Nov 23 11:55 AripekaSpringshed.shp.xml
. 2016-11-30 09:28:48.836 -rw-r--r-- 1 106 113 108 Nov 23 11:55 AripekaSpringshed.shx
. 2016-11-30 09:28:48.836 -rw-r--r-- 1 106 113 806 Nov 23 11:54 CrewsLake.dbf
. 2016-11-30 09:28:48.836 -rw-r--r-- 1 106 113 517 Nov 23 11:54 CrewsLake.prj
. 2016-11-30 09:28:48.836 -rw-r--r-- 1 106 113 156 Nov 23 11:54 CrewsLake.sbn
. 2016-11-30 09:28:48.836 -rw-r--r-- 1 106 113 124 Nov 23 11:53 CrewsLake.sbx
. 2016-11-30 09:28:48.836 -rw-r--r-- 1 106 113 18456 Nov 23 11:53 CrewsLake.shp
. 2016-11-30 09:28:48.836 -rw-r--r-- 1 106 113 11816 Nov 23 11:54 CrewsLake.shp.xml
. 2016-11-30 09:28:48.836 -rw-r--r-- 1 106 113 116 Nov 23 11:54 CrewsLake.shx
. 2016-11-30 09:28:48.836 -rw-r--r-- 1 106 113 1456 Nov 23 11:54 EmbassyHillsNWRRIB.dbf
. 2016-11-30 09:28:48.836 -rw-r--r-- 1 106 113 517 Nov 23 11:54 EmbassyHillsNWRRIB.prj
. 2016-11-30 09:28:48.836 -rw-r--r-- 1 106 113 148 Nov 23 11:54 EmbassyHillsNWRRIB.sbn
. 2016-11-30 09:28:48.836 -rw-r--r-- 1 106 113 116 Nov 23 11:54 EmbassyHillsNWRRIB.sbx
. 2016-11-30 09:28:48.836 -rw-r--r-- 1 106 113 128 Nov 23 11:54 EmbassyHillsNWRRIB.shp
. 2016-11-30 09:28:48.836 -rw-r--r-- 1 106 113 18568 Nov 23 11:54 EmbassyHillsNWRRIB.shp.xml
. 2016-11-30 09:28:48.836 -rw-r--r-- 1 106 113 108 Nov 23 11:54 EmbassyHillsNWRRIB.shx
. 2016-11-30 09:28:48.836 -rw-r--r-- 1 106 113 29288814 Nov 23 11:54 MajorRoads.dbf
. 2016-11-30 09:28:48.836 -rw-r--r-- 1 106 113 676 Nov 23 11:54 MajorRoads.prj
. 2016-11-30 09:28:48.836 -rw-r--r-- 1 106 113 304236 Nov 23 11:54 MajorRoads.sbn
. 2016-11-30 09:28:48.836 -rw-r--r-- 1 106 113 13732 Nov 23 11:54 MajorRoads.sbx
. 2016-11-30 09:28:48.836 -rw-r--r-- 1 106 113 7294260 Nov 23 11:54 MajorRoads.shp
. 2016-11-30 09:28:48.836 -rw-r--r-- 1 106 113 64851 Nov 23 11:54 MajorRoads.shp.xml
. 2016-11-30 09:28:48.836 -rw-r--r-- 1 106 113 257860 Nov 23 11:54 MajorRoads.shx
. 2016-11-30 09:28:48.836 -rw-r--r-- 1 106 113 336 Nov 23 11:54 PascoCounty.dbf
. 2016-11-30 09:28:48.836 -rw-r--r-- 1 106 113 676 Nov 23 11:54 PascoCounty.prj
. 2016-11-30 09:28:48.836 -rw-r--r-- 1 106 113 164 Nov 23 11:54 PascoCounty.sbn
. 2016-11-30 09:28:48.836 -rw-r--r-- 1 106 113 124 Nov 23 11:54 PascoCounty.sbx
. 2016-11-30 09:28:48.836 -rw-r--r-- 1 106 113 361124 Nov 23 11:54 PascoCounty.shp
. 2016-11-30 09:28:48.836 -rw-r--r-- 1 106 113 20143 Nov 23 11:54 PascoCounty.shp.xml
. 2016-11-30 09:28:48.836 -rw-r--r-- 1 106 113 116 Nov 23 11:54 PascoCounty.shx
. 2016-11-30 09:28:48.836 -rw-r--r-- 1 106 113 4272654 Nov 23 11:55 ReclaimedPipeline.dbf
. 2016-11-30 09:28:48.836 -rw-r--r-- 1 106 113 517 Nov 23 11:55 ReclaimedPipeline.prj
. 2016-11-30 09:28:48.836 -rw-r--r-- 1 106 113 31292 Nov 23 11:55 ReclaimedPipeline.sbn
. 2016-11-30 09:28:48.836 -rw-r--r-- 1 106 113 1604 Nov 23 11:55 ReclaimedPipeline.sbx
. 2016-11-30 09:28:48.836 -rw-r--r-- 1 106 113 878736 Nov 23 11:55 ReclaimedPipeline.shp
. 2016-11-30 09:28:48.836 -rw-r--r-- 1 106 113 21122 Nov 23 11:55 ReclaimedPipeline.shp.xml
. 2016-11-30 09:28:48.836 -rw-r--r-- 1 106 113 25756 Nov 23 11:55 ReclaimedPipeline.shx
. 2016-11-30 09:28:48.836 -rw-r--r-- 1 106 113 1276 Nov 23 11:55 ShadyHillsWWTP.dbf
. 2016-11-30 09:28:48.836 -rw-r--r-- 1 106 113 517 Nov 23 11:55 ShadyHillsWWTP.prj
. 2016-11-30 09:28:48.836 -rw-r--r-- 1 106 113 148 Nov 23 11:55 ShadyHillsWWTP.sbn
. 2016-11-30 09:28:48.836 -rw-r--r-- 1 106 113 116 Nov 23 11:55 ShadyHillsWWTP.sbx
. 2016-11-30 09:28:48.836 -rw-r--r-- 1 106 113 128 Nov 23 11:55 ShadyHillsWWTP.shp
. 2016-11-30 09:28:48.836 -rw-r--r-- 1 106 113 211837 Nov 23 11:55 ShadyHillsWWTP.shp.xml
. 2016-11-30 09:28:48.836 -rw-r--r-- 1 106 113 108 Nov 23 11:55 ShadyHillsWWTP.shx
. 2016-11-30 09:28:48.836 -rw-r--r-- 1 106 113 524288 Nov 22 08:54 USGS_BagleyCove_Discharge_Retrieved_11-05-2016.xlsx
. 2016-11-30 09:28:48.836 -rw-r--r-- 1 106 113 2394 Nov 23 11:55 WeekiWacheeSpringshed.dbf
. 2016-11-30 09:28:48.836 -rw-r--r-- 1 106 113 517 Nov 23 11:55 WeekiWacheeSpringshed.prj
. 2016-11-30 09:28:48.836 -rw-r--r-- 1 106 113 132 Nov 23 11:55 WeekiWacheeSpringshed.sbn
. 2016-11-30 09:28:48.836 -rw-r--r-- 1 106 113 116 Nov 23 11:55 WeekiWacheeSpringshed.sbx
. 2016-11-30 09:28:48.836 -rw-r--r-- 1 106 113 10156 Nov 23 11:55 WeekiWacheeSpringshed.shp
. 2016-11-30 09:28:48.836 -rw-r--r-- 1 106 113 95302 Nov 23 11:55 WeekiWacheeSpringshed.shp.xml
. 2016-11-30 09:28:48.836 -rw-r--r-- 1 106 113 108 Nov 23 11:55 WeekiWacheeSpringshed.shx
. 2016-11-30 09:28:48.836 -rw-r--r-- 1 106 113 4463 Nov 29 14:18 __test__00018454.txt
. 2016-11-30 09:28:48.837 -rw-r--r-- 1 106 113 4080 Nov 29 14:20 __test__00020268.txt
. 2016-11-30 09:28:48.837 -rw-r--r-- 1 106 113 587240 Nov 30 03:59 amazon-search-1.png
. 2016-11-30 09:28:48.837 drw-r--r-- 2 0 0 49152 Jul 16 2013 lost+found
. 2016-11-30 09:28:48.837 -rw-r--r-- 1 106 113 74787 Nov 30 02:34 michael-jackson-by-gottfried-helnwein.jpg
. 2016-11-30 09:28:48.837 -rw-r--r-- 1 106 113 103222 Nov 30 02:34 michael-jackson-by-robert-deutsch-rare-1995.jpg
. 2016-11-30 09:28:48.837 -rw-r--r-- 1 106 113 54389 Nov 30 02:34 michael-jackson-earth-song-rare03.jpg
. 2016-11-30 09:28:48.837 -rw-r--r-- 1 106 113 45112 Nov 30 02:34 michael-jackson-history-childhood-lollipop-rare02.jpg
. 2016-11-30 09:28:48.837 -rw-r--r-- 1 106 113 40606 Nov 30 02:34 michael-jackson-lori-stoll-rare06.jpg
. 2016-11-30 09:28:48.837 -rw-r--r-- 1 106 113 34289 Nov 30 02:34 michael-jackson-older-rare01.jpg
. 2016-11-30 09:28:48.837 -rw-r--r-- 1 106 113 173348 Nov 30 02:34 michael-jackson-with-children-rare01.jpg
. 2016-11-30 09:28:48.837 -rw-r--r-- 1 106 113 6790 Nov 30 02:34 mj1.jpg
. 2016-11-30 09:28:48.837 -rw-r--r-- 1 106 113 6642 Nov 30 02:34 mj2.jpg
. 2016-11-30 09:28:48.837 -rw-r--r-- 1 106 113 8547 Nov 30 02:34 mj3.jpg
. 2016-11-30 09:28:48.837 -rw-r--r-- 1 106 113 6771 Nov 30 02:34 mj4.jpg
. 2016-11-30 09:28:48.837 -rw-r--r-- 1 106 113 116339 Nov 30 04:15 paris_2016_c_155.jpg
. 2016-11-30 09:28:48.837 -rw-r--r-- 1 106 113 98738 Nov 30 02:34 picture132.jpg
< 2016-11-30 09:28:49.045 226 Directory send OK.
. 2016-11-30 09:28:49.045 Directory listing successful
. 2016-11-30 09:28:49.045 Got reply 1 to the command 2
. 2016-11-30 09:28:49.045 ..;D;0;1899-12-30T00:00:00.000Z;0;"" [0];"" [0];---------;0
. 2016-11-30 09:28:49.045 286968-michael-jackson.jpg;-;1022048;2016-11-30T02:33:00.000Z;1;"106" [0];"113" [0];rw-r--r--;0
. 2016-11-30 09:28:49.045 325268.jpg;-;282902;2016-11-30T02:33:00.000Z;1;"106" [0];"113" [0];rw-r--r--;0
. 2016-11-30 09:28:49.045 427687.jpg;-;623980;2016-11-30T02:33:00.000Z;1;"106" [0];"113" [0];rw-r--r--;0
. 2016-11-30 09:28:49.045 432142.jpg;-;212708;2016-11-30T02:33:00.000Z;1;"106" [0];"113" [0];rw-r--r--;0
. 2016-11-30 09:28:49.045 481483.jpg;-;174680;2016-11-30T02:33:00.000Z;1;"106" [0];"113" [0];rw-r--r--;0
. 2016-11-30 09:28:49.045 539400.jpg;-;806951;2016-11-30T02:33:00.000Z;1;"106" [0];"113" [0];rw-r--r--;0
. 2016-11-30 09:28:49.045 640719.jpg;-;3516049;2016-11-30T02:34:00.000Z;1;"106" [0];"113" [0];rw-r--r--;0
. 2016-11-30 09:28:49.045 AripekaSpringshed.dbf;-;16016;2016-11-23T11:55:00.000Z;1;"106" [0];"113" [0];rw-r--r--;0
. 2016-11-30 09:28:49.045 AripekaSpringshed.prj;-;517;2016-11-23T11:55:00.000Z;1;"106" [0];"113" [0];rw-r--r--;0
. 2016-11-30 09:28:49.045 AripekaSpringshed.sbn;-;132;2016-11-23T11:55:00.000Z;1;"106" [0];"113" [0];rw-r--r--;0
. 2016-11-30 09:28:49.045 AripekaSpringshed.sbx;-;116;2016-11-23T11:55:00.000Z;1;"106" [0];"113" [0];rw-r--r--;0
. 2016-11-30 09:28:49.046 AripekaSpringshed.shp;-;13308;2016-11-23T11:55:00.000Z;1;"106" [0];"113" [0];rw-r--r--;0
. 2016-11-30 09:28:49.046 AripekaSpringshed.shp.xml;-;190743;2016-11-23T11:55:00.000Z;1;"106" [0];"113" [0];rw-r--r--;0
. 2016-11-30 09:28:49.046 AripekaSpringshed.shx;-;108;2016-11-23T11:55:00.000Z;1;"106" [0];"113" [0];rw-r--r--;0
. 2016-11-30 09:28:49.046 CrewsLake.dbf;-;806;2016-11-23T11:54:00.000Z;1;"106" [0];"113" [0];rw-r--r--;0
. 2016-11-30 09:28:49.046 CrewsLake.prj;-;517;2016-11-23T11:54:00.000Z;1;"106" [0];"113" [0];rw-r--r--;0
. 2016-11-30 09:28:49.046 CrewsLake.sbn;-;156;2016-11-23T11:54:00.000Z;1;"106" [0];"113" [0];rw-r--r--;0
. 2016-11-30 09:28:49.046 CrewsLake.sbx;-;124;2016-11-23T11:53:00.000Z;1;"106" [0];"113" [0];rw-r--r--;0
. 2016-11-30 09:28:49.046 CrewsLake.shp;-;18456;2016-11-23T11:53:00.000Z;1;"106" [0];"113" [0];rw-r--r--;0
. 2016-11-30 09:28:49.046 CrewsLake.shp.xml;-;11816;2016-11-23T11:54:00.000Z;1;"106" [0];"113" [0];rw-r--r--;0
. 2016-11-30 09:28:49.046 CrewsLake.shx;-;116;2016-11-23T11:54:00.000Z;1;"106" [0];"113" [0];rw-r--r--;0
. 2016-11-30 09:28:49.046 EmbassyHillsNWRRIB.dbf;-;1456;2016-11-23T11:54:00.000Z;1;"106" [0];"113" [0];rw-r--r--;0
. 2016-11-30 09:28:49.046 EmbassyHillsNWRRIB.prj;-;517;2016-11-23T11:54:00.000Z;1;"106" [0];"113" [0];rw-r--r--;0
. 2016-11-30 09:28:49.046 EmbassyHillsNWRRIB.sbn;-;148;2016-11-23T11:54:00.000Z;1;"106" [0];"113" [0];rw-r--r--;0
. 2016-11-30 09:28:49.046 EmbassyHillsNWRRIB.sbx;-;116;2016-11-23T11:54:00.000Z;1;"106" [0];"113" [0];rw-r--r--;0
. 2016-11-30 09:28:49.046 EmbassyHillsNWRRIB.shp;-;128;2016-11-23T11:54:00.000Z;1;"106" [0];"113" [0];rw-r--r--;0
. 2016-11-30 09:28:49.046 EmbassyHillsNWRRIB.shp.xml;-;18568;2016-11-23T11:54:00.000Z;1;"106" [0];"113" [0];rw-r--r--;0
. 2016-11-30 09:28:49.046 EmbassyHillsNWRRIB.shx;-;108;2016-11-23T11:54:00.000Z;1;"106" [0];"113" [0];rw-r--r--;0
. 2016-11-30 09:28:49.046 MajorRoads.dbf;-;29288814;2016-11-23T11:54:00.000Z;1;"106" [0];"113" [0];rw-r--r--;0
. 2016-11-30 09:28:49.046 MajorRoads.prj;-;676;2016-11-23T11:54:00.000Z;1;"106" [0];"113" [0];rw-r--r--;0
. 2016-11-30 09:28:49.046 MajorRoads.sbn;-;304236;2016-11-23T11:54:00.000Z;1;"106" [0];"113" [0];rw-r--r--;0
. 2016-11-30 09:28:49.046 MajorRoads.sbx;-;13732;2016-11-23T11:54:00.000Z;1;"106" [0];"113" [0];rw-r--r--;0
. 2016-11-30 09:28:49.046 MajorRoads.shp;-;7294260;2016-11-23T11:54:00.000Z;1;"106" [0];"113" [0];rw-r--r--;0
. 2016-11-30 09:28:49.046 MajorRoads.shp.xml;-;64851;2016-11-23T11:54:00.000Z;1;"106" [0];"113" [0];rw-r--r--;0
. 2016-11-30 09:28:49.046 MajorRoads.shx;-;257860;2016-11-23T11:54:00.000Z;1;"106" [0];"113" [0];rw-r--r--;0
. 2016-11-30 09:28:49.046 PascoCounty.dbf;-;336;2016-11-23T11:54:00.000Z;1;"106" [0];"113" [0];rw-r--r--;0
. 2016-11-30 09:28:49.046 PascoCounty.prj;-;676;2016-11-23T11:54:00.000Z;1;"106" [0];"113" [0];rw-r--r--;0
. 2016-11-30 09:28:49.046 PascoCounty.sbn;-;164;2016-11-23T11:54:00.000Z;1;"106" [0];"113" [0];rw-r--r--;0
. 2016-11-30 09:28:49.046 PascoCounty.sbx;-;124;2016-11-23T11:54:00.000Z;1;"106" [0];"113" [0];rw-r--r--;0
I've been testing the following code to generate proper values to TimeDifference raw settings and it seems to do the job.
Invoke with:
TimeSpan offset = new TimeSpan(1, 15, 0);
string TimeDifference = GetTimeDifference(offset);
The server behaves as if it is in UTC zone. If not, it's broken or misconfigured.
And I also do not understand the upload test. At 09:28:42, you upload a file modified at 22:39:28 file (both UTC).
The server does not seem to support changing a modification time:
So the file should have modification time set to the upload time (09:28:42).
But after upload the time is 04:15. I do not, see where that time comes from. It cannot be explained by a -5 zone.
